Old 01-09-2022, 08:20 PM
jusjoken jusjoken is offline
New Dockers available
New dockers now available in Unraid and Docker Hub for SageTV and OpenDCT with a number of options included.
Change log here...
Thanks to Stuckless for the original foundational work on these as well as other users such as Madz whom I borrowed some updates from and Hvymetal for other inspiration to pull this together.
Setting your own hostname for a docker
Github source
Docker Hub link
Unraid template source
Old 01-09-2022, 08:22 PM
More pics
Docker Change Log
Change Log
### 2.0.5
- ServerJ11 - moved JDK from 11.0.2 to 11.0.15 to resolve TLS 1.3 error
- Note: other dockers were not changed
### 2.0.4
- ODCT - now uses ubuntu 20.04
- ODCT - removed changing properties to force media server as that is the default anyway
### 2.0.3
- ODCT - exposed ports 9091 and 8271
### 2.0.2
- ServerODCTJ11 - fix to path for JVM
- ServerODCTJ16 - fix to path for JVM
- template changes for changelog, versioning and support link
### 2.0.1
- initial release: setup Docker Hub and Github repositories
- Server: change base os to ubuntu 20.04
- Server: fix gentuner and commandir old bintray links
- ServerJ8: fix to cacert issue blocking placeshifter connection
- ServerODCT: add 8,11,16 containers embedding OpenDCT
- Server: fix to get latest SageTV release from Github
- ServerODCT: fix to get latest SageTV/OpenDCT releases from Github
- ODCT: update to get latest ODCT release from Github
- Templates: update to support all new containers
- BuildScripts: updated to include all containers
Old 01-09-2022, 08:54 PM
Wow, it looks like Christmas came a couple of weeks late this year! So if I want to try this out before I decide to fully migrate, can I stop my stuckless-sagetv-server-java11 and crazifuzzy-opendct dockers, install the sagetvopen-sagetv-server-opendct-java11 and start it up? Then, to switch back to my existing docker(s), I just stop the new docker and start the old ones back up. Is it that simple, or is it more complicated than that?
Also, if I am currently using the stuckless-sagetv-server-java11 docker, does it make sense for me to stick with your sagetvopen-sagetv-server-opendct-java11 docker? I had tried Sean's java16 docker, but some of the web UI was not functioning properly.
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, Unraid 6.10.3, sagetvopen-sagetv-server-opendct-java11 Docker (version 2.0.6)
Old 01-09-2022, 10:05 PM
Yes that will work. I run sometimes 4 or 5 SageTV dockers at a time for testing. In the template I change Host to br0 and set an unused IP and then I change the appdata path to something different so it doesn't touch my prod docker data...then start it up...even with the prod one running.
K
Old 01-10-2022, 08:32 AM
technazz's Avatar
technazz technazz is offline
Might want to update the links for the Support Link in the Unraid Docker.
I see there is an update to the docker. Is there a changelog I can see prior to updating?
Thx!
SageTV V9.xx 2 x HD300's, 2 x Nvidia Shields Running Mini Client
Old 01-10-2022, 12:11 PM
Originally Posted by technazz View Post
Thx!
I have a change log on my todo list and will try to post here as well. Part of the change was to build a process so each docker change will cause an update notice but for those interested I will create a technical post outlining what I did to get these new dockers published
But keep in mind, these dockers do not change SageTV nor openDCT...they just install the current posted versions inside.
Hope that helps for now.
K
Old 01-10-2022, 01:56 PM
If I wanted to add opendct to an existing docker could I just change the repository name, assuming that I am using the same Java version?
Old 01-10-2022, 02:07 PM
K
So I would change the appdata path from /mnt/user/appdata/sagetv/ to something like /mnt/user/appdata/sagetv-opendct/, correct? Does that directory need to exist before starting the docker, or will it create it automatically?
Also, if I am currently running the crazifuzzy-opendct docker for my production SageTV instance, will your docker play nicely with it since both dockers seem to be pointing to the same configuration, log and home paths? Both dockers can be running simultaneously?
Old 01-10-2022, 03:29 PM
Correct, and if it does not exist then unraid will create it. It could just be something like: /mnt/user/appdata/sagetv2/. Keep in mind, this path is where the SageTV part of the install will be located (not the opendct part...see below).
The opendct paths in the config need to point to the appdata paths you want the opendct part of the install to be located (3 paths). If you leave them at the default which is the same as the separate opendct container then it will overwrite (perhaps conflict) with the other container.
* perhaps I should change these defaults so they do not conflict...I will review in future docker releases
Note: I do not use opendct so cannot really comment on if the 2 containers would conflict but my gut would say they should at minimum have a different appdata path (for all 3 path settings) like I suggested for SageTV.
Example...
Hope that helps
K
Old 01-10-2022, 03:33 PM
I don't think I would as the template would not have all the opendct settings (paths).
I would tend to stop the existing dockers (turn off autostart too) then go to apps and select the new combined docker and when configuring it just point it to the same sagetv and opendct paths as the 2 previous dockers used (making sure you had a backup just in case).
Then start the new docker...and if all is good, do a remove on the old dockers.
Hope that helps.
K
Old 01-10-2022, 04:09 PM
Hope that helps.
K
Following these steps, the new combined docker would utilize the existing sage.properties and wiz.bin properties, correct? Would existing plugins just work, or would they need to be re-installed?
Old 01-10-2022, 05:47 PM
Correct. No change to plugins needed. Inside the docker it sees no change.
K
Old 01-10-2022, 08:07 PM
I'm trying to get sagetvopen-sagetv-server-opendct-java11 docker going as a test environment, but I am running into an issue. From what I can tell, OpenDCT is unable to start the JVM. SageTV appears to successfully start, although without tuners it doesn't do much good. However, it does playback previously recorded shows without an issue. I've attached the log file.
File Type: txt sagetvopen-sagetv-server-opendct-java11.log.txt (35.8 KB, 36 views)
Old 01-10-2022, 10:02 PM
I have an idea what the problem might be. There is a part in the Java 8 docker that is not part of the 11 and 16. I will review tomorrow morning and see how to resolve.
If you want you could change the 11 to and 8 in the docker registry name and apply and it will load the Java 8 docker instead to see if it makes a difference
K
Old 01-11-2022, 09:56 AM
This should now be resolved. Use the force update option on the docker in unraid and it should pull the new docker and load OpenDCT within the container properly.
Let me know how it goes.
K
Old 01-11-2022, 09:57 AM
Dockers updated to 2.0.2
2.0.2
2.0.1
Old 01-11-2022, 11:41 AM
K
It appears to be working now, I was able to add one of my HDHR Prime tuners, and am able to view live channels. Since it is a test environment, I ran into a tuner locking issue with the HDHRs, so I had to shut down my production environment temporarily to successfully test. I think that is just a properties setting in OpenDCT, if I really wanted to maintain a test environment I would spend time chasing it down. I am a bit surprised, it didn't find any of my HDHR OTA tuners, but I'm also not going to spend much time figuring that out either.
I'll probably look for an opportunity to do the in-place upgrade that you described earlier, which should retain all of my tuners, channel lineups, plugins, etc.
Old 01-11-2022, 05:58 PM
Hope that helps.
K
No doubt I would take a backup of appdata prior to switching over to the new combined docker, as described above. If things really went haywire, I could restore from the appdata backup. But I am curious: instead of restoring from the backup, could I just reverse the steps and revert back to the existing stuckless and crazifuzzy dockers?
Old 01-11-2022, 10:17 PM
Sure...and likely pointing them back at the copy of appdata folders prior to your test. The copy is entirely a safety net that I always do and recommend but I often for testing purposes completely setup a test system with tuners and plugins and then copy the appdata folders and point another docker at the copy so I can skip the configuration step.
Just keep in mind that there is really no data in the docker... The dockers point to data outside of the docker. The difference inside the docker is OS and Java versions, defaults, etc. But the new docker could change data in the appdata folder like a default property etc that we may need to review and fix. Hence the copy and test. But I think the potential is low. Sage and opendct should see an already configured system and just use that configuration
K
Running multiple SageTV dockers on one server wayner SageTV for unRAID/Docker 4 12-26-2021 10:04 AM
New dockers for Java 9 and 10 wayner SageTV for unRAID/Docker 1 09-02-2019 05:29 AM
What other dockers are you using? wayner SageTV for unRAID/Docker 11 02-25-2018 02:08 PM
250gb SSD cache big enough for sage, dockers, VMs? Pool? btrcp2000 SageTV for unRAID/Docker 2 08-13-2017 11:57 AM
Can you run multiple SageTV Dockers on one unRAID server? wayner SageTV for unRAID/Docker 5 06-20-2017 10:16 PM
