Old 01-20-2022, 12:21 PM
Disabling channels is a pain in the butt
Does anyone have a way of quickly disabling channels on your system. It is a pain in the putt to go into the source setup and manually disable hundreds of channels.
I see that in the sage.properties that there is an entry like this:
epg_data_sources/838481/unavailable_channel_nums=394,395,351,396,473,550,352,551,354,398,431,552,355,399,432,553,356,433,554,357,434,555,358,435,359,436,437,438,19,360,361,362,364,1,365,366,367,400,565,368,401,369,402,403,404,602,405,406,407,608,490,371,372,333,410,179,411,653,412,610,413,414,612,419,341,100,102,663,346,500,666,667,668,428,509,
Could you just use something like Excel to create a list of dozens or hundreds of numbers and just append this to this entry in the properties file? In an ideal world it would be nice to dump a list of the channel nums and names into a spreadsheet and then just be able to do a quick copy and paste to disable channels. Or even a channel management page in the web UI where it was easy to quickly
There is also an entry for unavailable stations, does that have to be populated in conjunction with the unavailable channel nums?
Or does anyone have another idea on how to do this?
This is almost analagous to BMT, but it is Batch Channel Tools.
Old 01-20-2022, 12:43 PM
There is an option to disable all channels, but then you'll need to go through & enable the ones you want again.
Old 01-20-2022, 12:56 PM
Yes, so depending on how many channels you use that may not be much easier.
I am looking at pulling the JSON data from a Sagex GetChannels query into Excel and then having a binary field for channel enabled. That could be used to create a csv list of channels that you want disabled which could be pasted into the properties file.
Assuming that I understand how this works correctly. Not sure if there would be issues with logical/physical channel.
Old 01-20-2022, 05:26 PM
UgaData's Avatar
UgaData UgaData is offline
F.W.I.W. Not exactly what you're looking for but there is a plug-in for Exporting and Importing channel line-ups.
Old 01-20-2022, 06:26 PM
deanm deanm is offline
I have done something very similar but in a MySQL DB. Wrote my own SDEPG Importer then I write the data in to STV using my custom master list.
Mainly done this for IPTV to combining multiple lineups.
Dean
Darkside: DVB-C x4 DVB-T2 x2 HD-300 x4
Lightside: DVB-C x2 DVB-T2 x4 HD-300 x3
Old 01-20-2022, 10:35 PM
I used that in the past but if I remember correctly, it had some limitations. And I want to do a more wholesale job with disabling a bunch of channels that I would never watch.
Old 01-20-2022, 10:40 PM
tvmaster2's Avatar
It works fine, but you need to do a tiny amount of manual manipulation to the saved files. I use it, because I have three different tuning sources, aka lots of blacked-out channels.
Old 01-21-2022, 04:41 AM
BMT has a channel editor for enabling/disabling channels in batch. I used it all the time.
Old 01-21-2022, 09:24 AM
tvmaster2's Avatar
Cool. Is it easy to find in BMT, and can you save the lists?
Old 01-21-2022, 10:03 AM
I'm going to guess, no, if you are asking the question
I actually don't have BMT or sagetv setup at all right now, so I can't say for sure where it is in the menu... it's one of the tools like viewing system messages, packages, etc.
I used to use it quite often because I only wanted to see channels on my system that I actually watched instead of the 100s of useless ones that I'd never watch, etc.
Old 01-21-2022, 10:48 AM
tvmaster2's Avatar
oops, lol - forgot you are an ex-Sager. Sorry
Old 01-21-2022, 12:58 PM
I have used that in the past, but it appears that it is broken for me, at least it is on 2 of my 3 servers. When I click on Configure-Channels I get failed to load on two of my systems. On another system it works. There doesn't seem to much rhyme or reason - it fails on a Java 8(old jetty) and Java 11(new jetty). The system that works is Java 8 with new Jetty.
The systems that don't work have both OTA and cable lineups as they both have HD-PVRs and HDHRs as tuners. The one that works only has the HDHR as a tuner. I wonder if there is an issue with loading multiple lineups? I took a look in the logs and can't see an obvious issue.
Even if it did work you still have to click individually for every channel. In a spreadsheet you could do a copy and paste to a few hundred cells in like two seconds, or make a large selection and press Ctrl-D to do a fill down?
But I have been a spreadsheet jockey since Lotus 123 in 1986 so when your tool is a hammer, every problem is a nail!
Old 01-21-2022, 03:27 PM
tvmaster2's Avatar
yeah, same here - just tried it, and all I got was ‘no channels available’ or the like.
Enabling/Disabling Channels in Sage wayner SageTV EPG Service 0 08-27-2009 07:13 AM
SkyStar HD 2 - WHAT A PAIN! routerunner Hardware Support 10 07-08-2009 05:54 AM
Tell Me Why Install Is Such A Pain? Same Slow Scan Issue! Crunch SageTV Beta Test Software 12 12-30-2008 08:42 PM
Thanks Sage - you guys kick butt! rotaryracer General Discussion 0 01-29-2004 01:22 PM
