Old 07-01-2010, 06:46 PM
tmiranda Recently Watched SageV7
tmiranda,
You need to include a dependency on the Phoenix Api. I loaded it into a clean SageTV7 install and it has errors and verrrrrry sluggish. Most people already have a version of the Phoenix Api so will not notice this. Installing Phoenix API corrected this.
PS you can test this by uninstalling all plugins and just installing this one.
Old 07-02-2010, 05:00 AM
tmiranda's Avatar
tmiranda tmiranda is offline
I did test it that way There is no dependency on the phoenix API's so something else is wrong if it's not working. Please post a debug log and I'll take a look at it.
Old 07-02-2010, 10:40 AM
Tom,
Here is the debug log... no phoenix api.
Old 07-02-2010, 10:59 AM
tmiranda's Avatar
Thanks. Obviously there is something going on with phoenix but I really did not think there was a dependency on it. I'll take a look at the code when I get home tonight. Thanks for bringing this to my attention.
If you install the phoenix jars does it work?
Old 07-02-2010, 11:00 AM
Tom
Yes It works. Thanks for your time.
Old 07-02-2010, 01:06 PM
PLUCKYHD PLUCKYHD is offline
Tom like is sagex errors I am seeing do you have it listed as a dependency? Phoenix api would fix it because it relies on sagex.
Old 07-02-2010, 01:34 PM
tmiranda's Avatar
Plucky,
The most likely problem is that I forgot to add a dependency on sagex to my "utilities" jar file. (I use it to access GetProperty() and SetProperty()) I thought I did that, but I guess not. I'll find out for sure tomorrow when I have time to look at things.
Tom
Old 07-02-2010, 02:04 PM
If installing phoenix fixes the issue though then I would think you aren't listing sagex as a dependencie in your manifest. Of course that is me talking without seeing your manifest
Old 07-02-2010, 03:45 PM
tmiranda's Avatar
Yes, I did forget to put sagex as a dependency in the utility jar that I use. I changed the manifest on the utility jar, as well as for the RecentlyWatched and Select and Batch Delete STVi's.
Thank you nyplayer for catching this.
Old 07-02-2010, 04:25 PM
That fixed it thanks.
STV Import: Recently Watched for the Default STV tmiranda SageTV Customizations 45 01-21-2016 11:20 AM
STV Import: Recently Watched for the Default STV tmiranda Customization Announcements 1 07-01-2010 05:12 PM
Clean install windows7 of Sagev7 - v7 doing slow scan for HDHR channels !? Crunch SageTV Beta Test Software 5 06-01-2010 08:20 PM
Recently Watched / Played queue? heffneil SageMC Custom Interface 2 11-21-2009 04:45 PM
Tivo - Recently Deleted Feature? mike1961 SageTV Software 26 03-26-2009 08:35 PM
