Old 02-09-2007, 11:50 PM
ARMYB77 ARMYB77 is offline
Avertv Combo PCIe M780 Tuner Card Supported?
Does anyone know if the Avertv Combo PCIe M780 is supported in SageTV? The card looks really interesting to me. I can't quite tell the specs for the card though. I believe that it supports the following (1 digital, 1 analog; or 2 digital; or 2analog) but I was wondering if someone can confirm this for me. It supports QAM, and OTA, plus analog.
This seems like the card to get as long as it can record 2 analog sources or 2 digital sources at the same time.
If anyone has insight on the card please provide it. Lastly of course please confirm that it is supported under SageTV.
Armyb77
Old 02-10-2007, 11:37 AM
jmiddleton jmiddleton is offline
A list of supported tuners can be found at http://www.sage.tv/requirements.html?sageSub=tv
If you choose a card (like the M780) that is not on the list it probably won't support hardware encoding - "you pays your money and takes your chances".
When I needed a PCIe card I chose the VistaView Saber 2020 partly because there were a couple of threads discussing it at this forum and partly because the VistaView.com FAQ claimed support for SageTV (still does for that matter). Turns out they were wrong. I expect my story to have a happy ending because support for the Saber 2020 is promised in Sage 6.1 but that's more good luck than good management on my part.
Old 02-15-2007, 04:09 PM
lobosrul's Avatar
lobosrul lobosrul is offline
Just FYI to sage, i'd like to see support for this card too!
Old 02-15-2007, 09:11 PM
sleonard's Avatar
sleonard sleonard is offline
Originally Posted by ARMYB77
... I believe that it supports the following (1 digital, 1 analog; or 2 digital; or 2analog) but I was wondering if someone can confirm this for me.
Armyb77
It has 1 digital ATSC/QAM tuner and 1 analog NTSC tuner w/ a hardware encoder.
I'd like to put 3 of these into my server and get rid of the 3 Hauppage 250's that are showing signs of age.
Scott
Old 02-16-2007, 07:19 AM
lovingHDTV's Avatar
For me this is the card of choice. I'm just waiting for it to be supported.
Old 02-16-2007, 09:05 AM
heffe2001's Avatar
Has anybody tried it with Sage yet? I have one of my analog tuners crapping out on me, and I'd much rather replace it with something like this. My only problem would be having to use it on a different PC from my main server, as it has no PCIE slots. That would also entail another Sage server license :P.
Hmm, it's MCE/Vista ready, may pick one up even if it's NOT sage compliant, play with it on my vista box :P.
Old 02-16-2007, 10:37 AM
Narflex's Avatar
Narflex Narflex is offline
Sage
It'll most likely work with SageTV w/ a simple registry modification. If it doesn't just send in a bug report and we'll add support for it in; we usually just need to see your log file and properties file from after you had the card installed. We've already requested a sample of this card so either way it'll be supported at some point in the future.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 04-20-2007, 09:30 AM
Dekard's Avatar
Dekard Dekard is offline
Would hoping this supports QAM within Sage be too much to ask?
www.overclockingwiki.org
Old 05-22-2007, 06:57 AM
dagar dagar is offline
Anybody had success with this card?
Old 05-22-2007, 11:20 AM
Dekard's Avatar
I've not used Sage in a while and I'm now using Vista MCE. At least its stable enough to use on a daily basis. I've lost a lot of features compared to Sage, but at least the features I do have work stably.
Old 05-22-2007, 01:27 PM
In this forum it links to a review of the M780 and in that review it states it is Sage compatible.
http://forums.sagetv.com/forums/showthread.php?t=25475
Old 09-09-2007, 09:46 AM
kricker's Avatar
kricker kricker is offline
Send a message via AIM to kricker Send a message via MSN to kricker
Any news on the support for this card? More specifically QAM.
Old 09-09-2007, 06:29 PM
BFisher BFisher is offline
don't know about QAM, but I have 2 connected to DirecTV receivers without issue. Antenna connections come next...
Old 09-10-2007, 09:54 AM
bjterry62's Avatar
bjterry62 bjterry62 is offline
I suppose they are connected via s-video/component? Are you recording HD or SD? I was curious about the PQ, especially if it was HD.
BT
Main HTPC: Antec NSK2400, Biostar TA790GX-XE, Athlon X2 7750, OCZ Raptor DDR2 800 2gb x2, WD Black 2.5", WD Green 1tb, Asus BD DVD, XFX 8500GT, Avermedia A180, HDHR, Win 7 64, SageTV v7.
Client 1: Custom Wood Case, Asus E35M1-M Pro, Kingston HyperX 2gb 1333, WD Black 2.5", Samsung SM DVD, Win 7 64, SageTV Client v7.
Old 09-10-2007, 11:16 AM
DirecTV receivers are indeed svideo. Antenna will be HD... haven't done it yet (plan to this weekend if everything goes as planned).
Picture Quality for SD via svideo looks very good - no complaints. I use the 3.2GB/hour recording speed.
Old 01-25-2009, 01:52 PM
HookedOnTV HookedOnTV is offline
I'm having trouble getting two of these to work. Only one shows up in sage. Device Manager has them setup correctly and they both appear in graphedit under the appropriate bda sections. Only thing I can see that I question is that they both have the same name. ie.
"AVerMedia M780 PCIe Digital Video Capture 2"
I see other references to having more than one of these in the same system so I think it should work.
Old 01-25-2009, 02:15 PM
Graygeek Graygeek is offline
Sage should find both cards, the first card and capture 2. You will have two analog and two digital tunners. I had good luck with either Avermedia .19 or .30 Beta drivers. Sage below 6.5.x will have a crash issue without a patch, see sticky at top in hardware section of this forum.
Hope this helps.
Old 01-25-2009, 03:55 PM
I have driver 2.5.0.29. Don't see any beta versions. After removing all sources here's what I see in Sage:
When I click the Add New Source button:
AVerMedia M780 PCIe Audio/Video Capture 1
These are listed only once. If I completed the setup for Digital Video Capture 2 I then have one item listed on the wizard summary page. Running through again and I still end up with just a single source. Should each of these items be listed twice after clicking the add new source button?
Old 01-25-2009, 05:02 PM
Found the .30 beta. No change.
Old 01-25-2009, 05:47 PM
Ok ... looking at my setup if I go to add tuner I show:
Avermedia M780 PCIe Audio/Video Capture 1
Avermedia M780 PCIe Digital Video Capture 2
Avermedia M780 PCIe Audio/Video Capture 1 #2
Avermedia M780 PCIe Digital Video Capture 2 #2
These are not listed in order, they are randomly dispersed with other devices .
Also in Device manager I show the following:
"..... Combo TV Tuner (Bridge)" listed twice
"..... Combo TV Tuner (Capture)" listed twice
"..... Combo TV Tuner (Tuner)" listed twice
