Old 05-30-2007, 09:31 PM
mkanet's Avatar
mkanet mkanet is offline
What's the highest quality dual tuner PCIe card?
I noticed the Cat's eye card is supported in SageTV. Someone old me they suck when it comes to reception. Can someone please recommend me the best one I can get for SageTV?
***RIP SageTV***
Old 05-30-2007, 10:12 PM
mikesm mikesm is offline
QAM tuner or analog hook up? Do you really mean PCIe? Not too many tuners in that form factor yet...
mike
Old 05-30-2007, 10:15 PM
mkanet's Avatar
Hey Mike, Im going to buy a new Vista based PC. Im going to get rid of my old Avermedia cards and looking for a dual tuner ATSC OTA PCIe card.
mike
***RIP SageTV***
Old 05-30-2007, 11:06 PM
Ah... Well, I'd very much recommend a no PCI(E) slot solution, the HDHomeRun. The price is right, has great support forums, and doesn't take up a slot. And it can act as a QAM tuner too, your choice for OTA or QAM.
mike
Old 05-31-2007, 10:17 AM
UFGrayMatter's Avatar
UFGrayMatter UFGrayMatter is offline
#2 for HDHomeRun
Old 05-31-2007, 10:47 AM
TakeFlight's Avatar
TakeFlight TakeFlight is offline
Pegasus - SageTV/HomeSeer Server: Core2Duo 1.8GHz, 1GB, 1.5TB RAID5, 2.25TB RAID5, Radeon X1050, (2) Hauppauge PVR250 (only used for security cameras now), SiliconDust HDHomeRun, Hauppauge HD-PVR, WinXP Pro
Prometheus - SageTV Client: Core2Duo 2.66GHz, 1GB, 500GB, GeForce 8400GS, WinXP Pro, 848x480 to InFocus SP4805 projector on a 78" screen
HD Theater (HD200) connected via HDMI to Panasonic TH-42PX60U 42" plasma
web server plugin | 2 MediaMVP Extenders | FiOS TV
Old 05-31-2007, 11:13 AM
Jesse's Avatar
Jesse Jesse is offline
Hi,
Well, I get what I call good reception of OTA HD with my Vbox USB tuners. That said, I do not know if the USB version uses the same tuner as the pcie version.
It was pretty tricky getting HD reception nailed down (and I still loose a channel once in a while..). as I have a very dense, tall treeline between my antenna and the towers. Winter is no problem, and I am about 95% good even in the summer. On top of that my cable run is close to 100'.
Where did you hear that the vbox tuners were bad?
Jesse
Server: Asus P5Q-EM DO, Q6600, 8 Gigs ram, WHS 2011, 1 HDHomerun(x2 OTA), 1 HD-PVR, 1 Colossus, V7.1.9 sage, 3.3 TB vid storage.
HD100 X1
HD200 X2
HD300 X1
Old 05-31-2007, 11:55 AM
KJake KJake is offline
Another vote for the HDHomeRun from me! I believe you can run it in dual ATSC, dual QAM, or one of each. I first ran it as dual ATSC and now it is in dual QAM. Word to the wise, make sure you follow their instructions to the word - it will save you a little time.
Old 05-31-2007, 02:15 PM
mkanet's Avatar
Doesnt the HDHomeRun require an external network encoder app to run? I already have 2 separate network encoder apps running on my setup currently already. I dont want to end up running a third one. Hence, why I'm looking for a non-network encoder type dual tuner; preferably internal.
***RIP SageTV***
Old 05-31-2007, 02:27 PM
Yup, they have a manager app that needs to run on the SageTV server so that Sage sees the two tuners. I'm not sure that there is any extra load on the PC, but I can't confirm that.
Old 05-31-2007, 03:21 PM
TakeFlight's Avatar
I always like things to be streamlined as well, but I've had no problems so far with the network encoder app. It's a relatively small app that really shouldn't be the deciding factor IMO.
Also, my understanding is eventually it may not be needed (although I have no idea what the timeframe is).
Old 05-31-2007, 03:33 PM
Yeah, if Sage supported it's BDA drivers naitively then the manager app wouldn't be needed.
Dual Tuner issues kck SageTV Software 4 05-25-2007 12:18 PM
Best DVB-T Dual Tuner dingers SageTV United Kingdom 4 05-16-2007 09:35 AM
Catís Eye 164e PCI-e dual tuner wheelrandolph Hardware Support 12 09-08-2006 05:13 PM
What Video Card and TV Tuner Cards are required for my setup? darrennye Hardware Support 0 01-01-2006 04:09 PM
Second tuner card disapeared LostInSpace SageTV Software 3 11-04-2005 10:36 AM
