Old 11-09-2013, 09:59 PM
pjpjpjpj pjpjpjpj is offline
HD200 Replacement power cord/transformer?
Anyone have a link to a new power plug/wall-wart transformer that works with the HD200? Mine died and I don't want to go fishing on amazon or whatever, hoping I get the correct plug tip size....
TIA.
Server: AMD Athlon II x4 635 2.9GHz, 8 Gb RAM, Win 8.1 x64, Java 8, Gigabit network
Software: SageTV v9, stock STV with ADM.
Old 11-10-2013, 05:14 AM
KryptoNyte's Avatar
http://forums.sagetv.com/forums/showthread.php?t=49110
You'll have to find a similar power adapter on Ebay.
Old 11-10-2013, 10:55 AM
HD200 fixes?
I have an HD200 that won't show any signs of life. No LED lights, nothing. I tested a power supply from a working HD200 and still nothing, so it's not the power supply. I opened it up and there is nothing visible to my untrained eye that looks like a culprit (no bulging caps or anything).
1) Has anyone experienced this behavior and fixed it?
2) Likely culprit? First thing(s) to check?
I have a multitester, are the solder points below the power jack on the circuit board a place to start?
Replacement Power Chord atchoo SageTV HD Theater - Media Player 5 07-31-2012 07:48 PM
Replacement Power Adapters for HD-PVR - Toronto area kpbrwn SageTV Canada 0 12-28-2011 03:00 PM
Anyone with kids cut the Cable/D* cord? IVB General Discussion 16 06-26-2011 09:14 PM
HD-PVR replacement power supply dead_ferrets Hardware Support 5 05-26-2011 07:59 AM
Replacement power supply/adapter for SageTV Media Extender moakes Hardware Support 2 06-14-2009 09:11 PM
