Old 12-27-2018, 12:04 AM
xjim1's Avatar
xjim1 xjim1 is offline
Customized Thumbnails
I've been converting my DVD's to MP4's and importing them into Sage so I can watch them as videos.
I see it generates thumbnails next to the name. It looks like it creates the image w/in the first second or so of the video.
Is there a way to customize them to generate an image, say, x amount of seconds into a video instead?
Thanks for any help.
Jim
Old 12-27-2018, 10:15 AM
MattHelm MattHelm is offline
There is a setting for that, not sure off the name.
You can also add a jpg with the same name, in the same folder, as the video file, and it will show that instead.
Example:
Movie.mp4
Old 12-27-2018, 11:18 AM
wnjj wnjj is offline
video_thumbnail_extraction_time_offset_sec in sage.properties. You’ll have to delete any existing thumbnails that you want redone.
Old 12-27-2018, 06:09 PM
xjim1's Avatar
Yeah I found the folder where the thumbnails reside, but doing it one by one would be too much work. Thanks for the suggestion, though.
Yes! The properties file. I should have known to look at it. I'll give it a try.
Old 12-27-2018, 07:17 PM
In theory you can change the setting then delete every thumbnail and eventually SageTV will rebuild them. In other words if you don't delete the ones you don't like the setting won't get used as it will not be generating anything.
Old 12-27-2018, 09:17 PM
xjim1's Avatar
The more I think about it, I like both ideas. Create custom thumbnails for movies (a lot of DVD's even have a jacket folder with such images), and use Sage created ones for TV episodes.
I just want to delete the ones I don't like. That will work, yes?
I guess I'll find out soon enough once I restart.
Cheers
customized theme within STV SageTV7 Galaxysurfer Gemstone for v9 2 09-21-2018 06:21 AM
Want to have customized view of airings by Title pseudonym SageTV Customizations 7 01-01-2008 02:35 PM
Can MCE Remote configuration be customized? TwistedMelon Hardware Support 6 04-25-2006 08:45 PM
feature req: Customized Marks snoopy SageTV Software 4 09-25-2005 09:44 PM
Customized UI dballer1 SageTV Software 5 08-13-2003 12:26 PM
