Old 01-10-2019, 04:45 AM
domotics domotics is offline
Encode records with multiple audio streams
Hello,
In Belgium and France, and probably in many others countries, records contain multiple audio streams (e.g. french, english, audio description,...).
When I encode record, only first audio stream is encoded in the result file, unfortunately often english stream.
Parameters in sage.properties file aren't documented and I don't know how to do to encode all audio streams (and subtitles if possible).
Thanks for your help.
Server: SageTV 9.1.9, Windows 10 Pro, Gigabyte GA-H170M HD3 DDR3, CPU i3-6100 @ 3.7GHz, RAM 8GB, SSD 120GB (OS), HDD 2x4TB (media), 1x TBS 6205 PCIe Quad DVB-C TV Tuner.
Client: 1x HD200 extender on 47" LCD TV.
Old 01-10-2019, 09:48 AM
MattHelm MattHelm is offline
This is also done here in the US. SageTV "records" the entire stream the tuner provides, so you need to look at the setup of the turner.
Old 01-10-2019, 12:39 PM
Convert records with multiple audio streams
Sorry I used "encode" instead "convert".
Records contain all audio streams, it works fine, but when I convert them (with function "convert" in SageTV), only the first audio stream is in the converted records. I would like all audio streams and subtitles in the converted records.
(Sorry for my bad english language)
Old 01-11-2019, 11:43 AM
egeller egeller is offline
If I am hearing you correctly, I would use Handbrake, instead of SageTV's functionality, to convert recordings. SageTV's functionality is not easily controllable, when compared to Handbrake.
With a little practice you can control which audio tracks are included on the output. You can even re-order their "priority" (if that is what it's called). For example, if French is the third language, you can make it first in the output, so that it becomes the default for the output recording. Good Luck.
SageTV Extender:3x HD200 1x HD300
Sage TV: 9.1.10, Standard STVi, Comskip Playback, Web Interface, 24 Hour Clock, SRE, YouTube2015, Playon
All in lovely Drexel Hill, PA
Old 01-11-2019, 12:56 PM
trk2 trk2 is offline
I agree with egeller although Sage might improve at this process in the future since work is ongoing to update FFMPEG in Sage.
Old 01-11-2019, 01:30 PM
It's a good news. Convert facility in SageTV is easier than Handbrake (automatic vs manual conversion). Thus, wait and see...
Thanks for your answers.
Convert Multiple Audio streams Alfiegerner SageTV Software 1 09-18-2007 10:24 AM
Multiple MP4 video/audio streams native support jimbruskalski SageTV Software 2 09-01-2007 09:27 AM
Multiple Audio Streams mayamaniac SageTV Media Extender 0 03-11-2007 05:27 PM
Multiple audio streams in Sage XXXterra SageTV Software 0 07-06-2006 02:18 PM
Multiple Audio Streams ChePazzo SageTV Software 0 01-24-2006 09:43 AM
