Old 03-17-2019, 06:27 AM
Beaker's Avatar
Beaker Beaker is offline
Wiz.bin 162GB -Filled Disk
So something went crazy yesterday and I woke up to a full hard drive. Wiz.bin is 162GB. I don't know how to diagnose this or even what info might be helpful. I can say this seemed to happen out of the blue. No changes were made in the days leading up to this. Any ideas?
Windows 10
Latest Java
Latest SageTV Windows build
Weather plugin
Youtube plugin
I'm having a hard time getting much to start so I can't see version numbers for some of these.
"Worry does not empty tomorrow of its sorrow; it empties today of its strength." Corrie Ten Boom
Core-i5 6600k
16GB RAM
Hauppauge WinTV-QuadHD
Win10
Old 03-17-2019, 08:20 AM
tmiranda's Avatar
tmiranda tmiranda is offline
Windows 10
Latest Java
Weather plugin
Youtube plugin
You are probably getting bitten by the YouTube API failure. Look at the last few posts in the YouTube support thread in this forum.
Basically the "sort by date" function is broken which is causing the YouTube plugin to record WAY too many videos.
Old 03-17-2019, 12:01 PM
NoodleNT NoodleNT is offline
Yep... my 4TB of storage is almost full!
Old 03-17-2019, 01:01 PM
Beaker's Avatar
I think you are right. When I uninstalled the YouTube plugin, particularly the Youtube Downloader, it stopped growing. Thanks for pointing me in the right direction!
Core-i5 6600k
16GB RAM
Win10
Old 03-17-2019, 02:06 PM
tmiranda's Avatar
YW. This is not a condition I ever imagined when I wrote this plugin.
Old 03-18-2019, 10:31 AM
MattHelm MattHelm is offline
BTW, I just turned off all recording (did NOT uninstall) and that fixed it for me.
Old 03-18-2019, 06:33 PM
Beaker's Avatar
Please do tell how you did that. Does it still provide a way to show what has not been watched - I presume this would stream or download upon pressing play?
Core-i5 6600k
16GB RAM
Win10
Old 03-19-2019, 12:26 PM
I'm not at home, so I can't give you step by step details, but basically this is what I did:
I went to each channel I was recording and adjusted the favorite to not record (there are 3 settings, and I set all to off/none/???) I then deleted all the recordings made.
You are just going to get a garbage listing until YouTube fixes things. This is 100% on YouTube, not tmiranda's program. The old saying garbage in garbage out applies. This is the stupidest thing I've heard a company like this do. I can think of 20 different and better ways to temporary fix the issue they had Friday. Oops, rant off.
sage.properties file filled with junk src666 SageTV Software 8 05-10-2011 04:31 PM
DVD title and duration not filled by .properties? cncb SageTV Customizations 9 12-11-2009 10:05 AM
Disk bar jpaddock3000 SageMC Custom Interface 2 02-07-2009 09:37 AM
2nd disk? stevech SageTV Software 3 01-24-2006 03:24 PM
Static filled recordings on my 2d card matt91 Hardware Support 2 09-19-2005 10:13 AM
