Old 04-22-2019, 04:44 AM
DigiDAD DigiDAD is offline
Feature Request - Record specific season
Having missed a number of episodes of the current season of one of our favorite shows, I thought I might try and setup a favorite to record those episodes from the current season when they air again. Problem is that the earlier seasons are in syndication and air regularly. I want to record 'All Episodes' but be able to select 'Season 12', 'Current Season' or maybe 'Season 12 & newer' when setting up the favorite. I believe Sage has all the data to support this feature request - just needs a bit of logic and a UI change. What do you think?
Old 04-22-2019, 04:54 AM
tmiranda's Avatar
tmiranda tmiranda is offline
The scheduler is one of the most complicated parts of the core. It certainly could be done but will take some effort.
It could also be done via a plugin that would inspect each completed recording and delete the ones that did not meet the Season criteria specified.
Old 04-22-2019, 07:35 AM
SHS's Avatar
SHS SHS is offline
Make sure there not all ready mark as watch and another problem is it could be Guide data it self
Old 04-22-2019, 11:08 AM
RangerZ RangerZ is offline
I would vote for this. I have wanted it to catch up on a particular season of things like Law and Order or Hawaii 5-0, though I would like to also be able to do "Season 12 and Older" to get the classic 5-0.
SageTV Server\Client V9 (9.1.5.683)
on Intel i5-4570 3.20GHZ, 4GB RAM, Windows 7 Pro 64 bit SP1
OpenDCT .5.28
SD HDHR3-CC w/ RCN Cable FW:20161116
SD HDHR-US (OTA) FW:20150615
Old 04-23-2019, 05:04 PM
KryptoNyte's Avatar
At one time I was in the same boat, missing about 4 episodes in a single season. Then I realized that I could set up a favorite with a keyword/keyphrase that got me one of the episodes that I needed. I did it 3 more times with episode keyword and that took care of it.
If I needed to isolate and record more than about 6 episodes, I just set up a favorite to record everything that was unwatched, which also allowed me to set old episodes that I watched on a streaming service to "watched" in SageTV as I deleted those episodes.
Old 04-24-2019, 12:21 PM
MattHelm MattHelm is offline
When I run into this issue, this is what I do.
1. Add show as favorite.
2. Go into favorite and select past airings. (step 3 is done from inside this menu)
3. Mark all of them Watched.
4. Sort them by original air date.
5. Find the ones I missed and mark them unwatched.
Done.
Feature Request: Channel-Specific or Favourite-Specific Remove Back-To-Back Padding rickgillyon SageTV Github Development 0 03-21-2018 05:18 AM
Feature Request: Recordings sorted by Season / Episode jpaddock3000 SageTV Beta Test Software 4 04-14-2011 07:42 AM
Feature Request-Input specific default aspect ratios jwillsey SageTV Software 2 06-13-2007 07:39 PM
Feature Request: Tunner specific IR control Deadbolt SageTV Beta Test Software 0 02-12-2004 05:46 PM
Feature request: record partial shows mattchapin SageTV Beta Test Software 12 02-11-2004 02:54 PM
