Old 07-17-2019, 12:14 PM
MattHelm MattHelm is offline
HD200 having issues with HD streams
All,
I've run into an issue just recently. When playing back high bit rate streams (maybe some would call them Blue Ray movies) I start getting video and audio issues every 10 minutes. This include older streams that worked fine about a years ago. The 10 minute interval is very regular, and last from 20 seconds to 2 minutes.
I had someone else play them on his SageTV and HD200 extender, and he had no issue. I also played them on my NVidia Shield, and it played just fine. Oh, Shield is hook to the same switch as the HD200.
Most of my files are in the MKV container, but that hasn't been an issue for years. Low bit rate and TV HD all play just fine.
I've also turned off all virus scanning for my storage drive, and my new sever (working just for imports) did the same think. (Much more powerful system)
trouble shooting suggestions???
Old 08-21-2019, 04:35 PM
OK, found the issue. HD200 was set to bitstream, which my cheap receiver didn't like. Old receiver work fine. Time to look for a good receiver.
hd200 7.0.12 fix Add experimental dvb subpicture decoding in transport streams bjkiller SageTV Beta Test Software 10 07-21-2010 12:40 AM
HD200 Lipsync issues Techvet SageTV Media Extender 0 03-03-2009 08:26 AM
HD200 - cool, but 2 issues - memory & playback issues with hdpvr agover SageTV Media Extender 3 12-16-2008 12:50 PM
HD200 issues vexhold SageMC Custom Interface 3 12-12-2008 09:17 PM
