Old 09-28-2005, 01:01 PM
Boxpin's Avatar
Boxpin Boxpin is offline
How to play DIVX movies in Sage
I am reading that DIVX is supported in Sage. I have created a couple files and put them in my import directory, refreshed but still do not see them. Is there something special I need to do to get sage to see them?
I have installed DIVX player which I assume has the required Codec.
Is this a setting? configuration? version issue? Duh factor?
Using Sagetv 2.1
Old 09-28-2005, 03:00 PM
nielm's Avatar
nielm nielm is offline
file extension? (avi's should work fine)
Old 09-28-2005, 03:54 PM
dbfresh23's Avatar
dbfresh23 dbfresh23 is offline
I think with divx 6 they started changing the extension to .divx from .avi - so maybe just add .divx to the sage props file.
Old 09-30-2005, 08:26 AM
Boxpin's Avatar
The file I created is .divx and here is my seeker entry from sage props:
seeker/video_library_import_filename_extensions=.mpg,.mpeg,.mp2,.mpeg2,.mpe,.avi,.divx,.mpg1,.ts
Any thoughts?
Old 09-30-2005, 08:35 AM
dbfresh23's Avatar
yeah, as i said in the previous post, just add .divx to that line - I did and it works perfectly fine. I'm using the newest v3 beta - not sure if that matters.
Since sage doesn't support the divx 6 extra features anyway, you can just rename the files to have a .avi extension and they should still work fine.
Old 09-30-2005, 09:29 AM
Boxpin's Avatar
Ok, this is strange. The DIVX extension has been in the seeker line since day one yet it would not display the file. I was on a client machine and selected the medial refresh and it now shows! I did this on the server two days ago and it did not show. Strange but who cares...it works!
Thanks for the suggestions!
