Old 08-11-2005, 11:46 AM
orky7 orky7 is offline
Sage not updating EPG
Hi everyone,
I am using the XMLTV plugin and I have a problem: the LiveTV Guide is not being updated...
I have tried many things: I deleted my capture source and added it again, I pressed twice on a channel, as written in the FAQ, and even if I delete the epgdata.xml from the sagetv directory, I still see the same EPG in sage...
What else can I do?
please help!!
orky7
Old 08-12-2005, 12:33 AM
Somebody??
It's really important...
Old 08-12-2005, 05:10 AM
nielm's Avatar
nielm nielm is offline
Has Java been updated recently?
Check that xerces.jar is in the latest JRE/lib/ext directory or in the SAGETV/JARs directory (Java's automatic updater does not copy any extra Java libraries in JRE/lib/ext to the new directory)
(Note, if you are using V3, you may see startup errors relating to XMLTV in the sagetv_0.txt file)
