Old 05-17-2007, 07:24 PM
zzmystique's Avatar
zzmystique zzmystique is offline
can't play WMA files on MVP (wmv files play ok)
How do you configure the MVP to play wma files?
The wma files are detected but nothing happens when I click play (MP3's play fine). WMA files play ok through the Sage Media Centre, SageTV client and through Placeshifter.
Have I missed something obvious?
ZZMystique
My setup: Server: SageTV v7, Intel i5, 8GB, 180GB SSD, 4TB HDD, Win7HP & (DVB Viewer Pro with DVB Viewer for SageTV using 2xTBS6281 DVB-T2).
Old 05-18-2007, 02:09 AM
rickgillyon's Avatar
Is there something weird about the files? My WMAs play back fine on the MVP...what Sage version are you on?
Old 05-18-2007, 07:36 AM
Taddeusz Taddeusz is offline
Are they protected WMA files? AFAIK, SageTV will only transcode unprotected files.
Old 05-20-2007, 07:31 AM
zzmystique's Avatar
my version of sage is SageTV v6.1.9 - I don't think the files are protected - is there a way to easily tell?
ZZMystique
Old 05-20-2007, 07:55 AM
Are these files you ripped yourself with Windows Media Player? If so, right click on the menu somewhere and go to Tools -> Options. The click the Rip Music tab. Make sure that "Copy protect music" is unchecked. If it is checked then all the music you've ripped has DRM applied to it and is unplayable in anything but WMP.
If it's not checked then where were these WMA files from? Did you rip them? Did you buy them from a service?
Old 05-20-2007, 08:20 AM
zzmystique's Avatar
The files were ripped from the original cd's on a pc which i have since reloaded xp. The files are protected, so looks like i will have to delete and redo them unless you know of a free utility to convert them to mp3.
will post results when i have re ripped them.
Thanks for your help
ZZMystique
Old 05-29-2007, 06:16 PM
joat joat is offline
Missing pre-requisites
You may also want to go back and ensure that you have the necessary files installed to support transcoding. For Linux (I'm not sure how it's done in Windows), you want to make sure that transcode (mine is 1.0.2) is installed.
- joat
MVP won't play Audio from HDHomeRun shows with 5.1 audio. mechling-burgh SageTV Media Extender 1 12-08-2008 03:52 PM
Codec help for viewing HD content on MVP waynedunham SageTV Media Extender 17 04-30-2007 08:12 AM
MVP Playback of .ts files dj7675 SageTV Beta Test Software 3 03-09-2007 08:38 PM
Problem with WMV Video Files jfgast SageTV Software 0 07-08-2006 02:43 PM
