Old 12-18-2008, 09:28 PM
bigbill's Avatar
bigbill bigbill is offline
Updating Sage on WHS
What's the correct process to upgrade SageTV on WHS server? I put the .msi on the share and install it from the web page.. is that the right way?
Sage Server: SageTV v9.2.1(64)
Hardware Dell T20 Mini Tower, 4th Gen Pentium, 8GB RAM, Win10 Pro 64 bit, 3 x 4TB WD Green, 128GB SSD boot drive. Capture: 1 Quad HDHR, 2 Dual HDHR, (OTA Winegard HD8200U, CM4221HD), 2 @ STP-HD200's, 1 @ HD300, 1 @ Nvidia Shield 2017, 1 @ Mibox. TV's: 70", 55" & 40" Sony's - Playon/PlayLater, Blue Iris.
Motorhome Sage Server: SageTV v9.1.8 Intel NUC6CAYH, HD200, Nvidia Shield 2017, 1 Dual HDHR 4TB Passport storage, Winegard BatWing RV antenna.
Old 12-18-2008, 10:00 PM
S_M_E S_M_E is offline
Uninstall the old version using the console,
remove the old .msi from the software/add-ins share,
reboot,
Copy the new msi to the software/add-ins share,
install the new version from the console...
Old 12-19-2008, 09:51 AM
If you uninstall does it keep all of the properties stuff or do you have to redo your whole config such as sources, etc.?
Old 12-19-2008, 10:02 AM
bigbill's Avatar
I tried it and yes it kept all shows and other setup. Went very smoothly. -Bill
NO USB UIRT Configuration Controls in SAGE!!!! OldPCGUY Hardware Support 9 10-28-2008 09:14 PM
HP Mediasmart, WHS, Sage and USB tuners hjalmar Hardware Support 2 10-18-2008 12:37 AM
Sage is relying on its cached metadata too much bastafidli SageTV Beta Test Software 6 08-06-2008 05:46 AM
Sage and WHS PP1 Performance AtariJeff SageTV Software 7 08-01-2008 08:16 PM
How To: In-place recompression of Sage Recordings nielm SageTV Customizations 39 02-18-2006 11:32 PM
