Go Back   SageTV Community > SageTV Development and Customizations > Customization Announcements
Customization Announcements Announcements from SageTV customization developers.
Old 09-18-2009, 02:56 AM
michaeldjcox michaeldjcox is offline
Web Radio and TV encoder Announcement Thread
Announcement: Web Feed Encoder version 0.9.4
Introduction
The webfeedencoder is a means to get web based streaming TV and radio and device output available in SageTV and its extenders as if they were regular channels.
As far as SageTV is concerned the webfeedencoder behaves like another TV tuner.
The excellent VLC media player software is used to tune to the internet TV or radio station, add video to the radio, and dump to an MPEG2 file for SageTV.
The means of tuning and detuning is completely configurable so any source of video or audio could be fed to SageTV via the webfeedencoder.
The webfeedencoder also includes an EPG grabber to harvest schedules from the web pages and other sources and update SageTVs program guide without need for an XMLTV importer.
A configuration tool is provided which allows you to:
  • Find and configure new channels.
  • Test the channels and EPG harvest.
  • Perform ad-hoc EPG updates.
  • Manage your channel lineup up in SageTV.
Installation of the encoder requires installation of a single plugin jar file to your SageTV installation and updates to the Sage.properties file.
A comprehensive install wizard performs the whole installation task and provides options to downgrade to your previous version and uninstall.
Prerequisites
  • The VLC media player. Version 0.9.8 and 0.9.9 work. Versions 1.0 and 1.1 do not work currently.
  • Version 6.4 of SageTV or later.
Known problems
  • Some users reported sound is choppy if listening on the PC that hosts the SageTV server.
  • Tuning can be slow.
  • VLC sessions sometimes do not die when recording has finished.
  • VLC session sometimes crash when they are being closed down.
Future directions
The aim of the webfeedencoder is provide a basket of tools to get anything into SageTV. Future plans involve configuring new online sources, access to the server DVD, and tools to extract stream URLs from flash based players.
Installation and upgrade from earlier versions
Download the file from here
Unzip the download file in a location of your choice and double click on the jar file to install.
The zip file also contains the user guide.
Support and updates
Support is available on this thread.
Version History
0.9.4 - 5th release (Beta).
  • Direct injection of EPG data and lineup to SageTV eliminating the need to go via XMLTV and XMLTV importers.
  • Installation wizard which performs all installation, deinstallation, upgrade, downgrade and setup tasks.
  • A configuration tool eliminating the need for manual configuration of lineup which allows direct injection of lineup and EPG to SageTV and provides test tools for channels and web harvests.
  • Inclusion of direct show devices as a type of channel.
  • Substantial cleanup of config files and some renaming of properties to be more consistent.
  • Introduced the concept of a seed plugin - which knows how to browse the channel listings of external websites and grab initial channel config from them. This "seed" channel config can then be further overridden to add missing information or correct web site mistakes.
  • Existing code for direct show devices and radiotime stations recast as seed plugins.
  • A new seed plugin for www.allinternettv.com added so internet TV channels can be configured.
0.9.3 - 4th release (Beta).
  • Ability to tune to internet TV channels.
  • Support for unix specific tuning commands - not fully tested yet - beta tester required.
  • To support the above sagetv.dir and vlc.dir become sagetv.logos.dir and vlc.exe to point to the required resource.
  • Made tuning and detuning script driven per channel to allow custom tuning instructions.
  • To support TV and custom tune commands the lineup channel ids need to be prefixed with a name that corresponds to a properties file that specifies properties common to a group of channels and other data e.g. radio/977HItz, tv/i3interactive
  • The generic grabber now allows stop times. This fixes problems where stations do not broadcast 24 hour.
  • The web-based now playing text processing now allows incremental advance to the beginning of track now playing data in the source html.
  • If web-based now playing text is not specified the encoder will look for ICY meta data or ID3v2 tags to get the track now playing.
  • Fixed paths for config and log files in unix.
  • Removed surplus file separators.
  • Provide a substitute image for the video if no channel logo is available.
  • Fix the issue where sometimes the logo image file name on www.radiotime.com was prefixed with the wrong channel id.
  • Fix sample WMNF channel properties where the EPG was configired to be a day behind.
  • Fix issue where radiotime day epg urls where being created only for the first seven days of after the channel first appears.
  • Set the now playing text size before presenting it rather than after.
0.9.2 - 3rd release (Beta).
  • Fixed bug where images did not get downloaded when a channel offset is in force.
  • Fixed bug where an empty channel properties file is always created when an unknown id is used in the channel lineup.
  • Changed sample channels callsigns to be in agreement with radio and hence also renamed them.
  • Added some debug and a possible fix to the properties file not found message in linux.
0.9.1 - 2nd release (Beta).
  • Integrated the webepggrabber release with webfeedencoder. While still useful separately I no longer which to manage it in a seperate distribution.
  • Correct port number in the instructions.
  • Fix various problems caching the channel logo and temporary video image. If you delete either they are now correctly reproduced.
  • Moved the channel configuration from tuning.props and lineup.props lineup.props which now simply maps channel number to channel id
  • The channel id can now be a RadioTime station id. If this is used no other channel configuration is necessary.
  • Created a channels directory where seperate per channel properties files serve the purpose of the old tuning.props and lineup.props
  • A separate cache directory now holds cached images and radio time properties files. The tmp directory now holds disposable files.
  • Improved the housekeeping of temporary files.
  • Improved the recording state machine to cope with odd behaviours resulting from the time it takes to tune.
  • Added a shutdown hook to stop recording if the process is shutdown.
  • Added a service wrapper so the encoder can be run as a windows service.
  • Remove HTML escape codes from titles, descriptions and now playing text.
  • Now playing html parsing now recognises that there may be a seperator between artist and title to be removed.
  • Fixed a bug in the default grabber which caused programmes to still be of 24 hour length when Daylight Savings occurred.
  • A channel timezone can now be specified for the generic grabber so programme times are correctly calculated for foreign stations can converted to UTC in the XMLTV.
  • The generic grabber can now handle the programme description being accessed via another URL.
  • The generic grabber now allows multiple time formats for schedule pages that mix and match time style e.g. 3pm-5.30pm.
  • The generic grabber can now handle a different order of items in the schedule. Sometimes they can appear time, title, desc and sometimes its a different order.
  • Add a category "Radio" to the radio programmes.
0.9.0 - Initial release (Beta)
Credits
Many thanks to Deanm, Ianhud, Matt91, Brent, Doc, Slipshod, latino, bcjenkins, tmiranda, robogeek and kha for beta-testing and feedback.
Old 10-21-2009, 09:59 AM
Arrow Web Radio and TV Encoder - 0.9.4a
Following a recent round of beta-testing the download zip file has been updated.
The following fixes are included:
  • Use of the EPG plugin will be disabled by the installer when configuring SageTV whereever native SageTV EPG sources are used.
  • Sample station Kiss105108 grabber type has changed to use day-long programme for EPG.
  • The installer now takes a backup of Sage.properties as insurance.
  • The installer now has a "Refresh" option allowing to refresh all installed components the distribution jar excluding config directory files. WARNING if you have edited the delivered channel types or command files your changes will be overwritten.
  • Setting of file permissions in windows now copes with file paths with spaces.
  • The installation jar file can be run from a directory with spaces in.
  • The installer will check the version of Java being used to run it and report and error if its too old.
  • The installer will now catch and display any errors found in initialization - previously these were not being reported.
  • The installer will not repeat configuration of the epg_import_plugin sage property once configured as this leads to infinite loop in SageTV.
  • The installer fixed so that windows file separator are not doubled when writing the encoder.props file.
  • Device seed plugin fixed - was using the wrong device name in the tuning URL.
  • Command files have been updated to be compliant with VLC 1.0.0 onward transcoding parameters - radio still does not work with these versions.
Many thanks to all beta testers for their patience and persistence
Michael
Web Feed Encoder developer
SageTV Catchup developer
Old 11-13-2009, 02:28 AM
Web Radio and TV Encoder - 0.9.4b
Minor upgrade to encapsulate fixes resulting from recent beta testing.
  • Updated user guide to advise Vista/Win7 users to run installer with elevated command prompt.
  • EPG grab will now push times to SageTV in GMT rather than local time
  • EPG grab will now make program times have zero seconds if seconds.
  • Fix issue where EPG grabber assigned incorrect day to a days EPG within generic grabber.
  • Fix EPG grab test null pointer causing "Run" button to fail.
  • When adding channels channel timezone now defaults to local time rather than GMT to assist in Radiotime EPG.
  • Better defaulting of installation directory and SageTV directory in the installer.
  • Got rid of annoying exception messages printed out by installer
  • Uninstalling will not try to delete files that are not there
New users - follow the installation instructions in the user guide.
Upgraders - this is not a full release so install/upgrade instructions do not apply. You need to run the installer and use the "Refresh" option. This will overwrite previously delivered files with new versions. The config directory is not touched but previously delivered channel types and commands will be overwritten so if you have tinkered with these you may wish to take a backup. Ensure configtool and webfeedencoder are shutdown.
Many thanks to all beta testers for their patience and persistence.
Michael
Old 11-27-2009, 01:47 AM
Web Radio and TV Encoder - 0.9.4c
  • Add quotes to delete of temporary files when detuning radio.
Michael
Old 01-20-2010, 04:41 AM
Arrow Announcement: Web Feed Encoder version 0.9.5
Introduction
Feeds can also be added to online services menu in SageTV.
  • Find and configure new channels and online services.
  • Manage your SageTV channel lineup and online services.
Prerequisites
  • Version 6.4 of SageTV or later. Version 6.6 and the latest STV update if you wish to use online services.
Known problems
Future directions
Unzip the download file in a location of your choice.
The zip file contains a user guide and a jar file.
To install or upgrade run:
java -jar webfeedencoder_0_9_5.jar
On windows vista and windows 7 you should run this in an elevated command prompt or from your admistrator account.
Support and updates
Credits
Many thanks to all those who have given WebFeedEncoder a try and provided valuable feedback.
Special thanks to Mikeg for pre-release testing.
Version History
0.9.5 - 6th release (Beta).
  • Added management of extra services and their categories on SageTV online services menu.
  • Added a seed plugin for www.podcastdirectory.com to seed online services.
  • Made seed plugins data driven so more can be easily added and existing ones maintained.
  • Fixed issues with VLC processes not been killed on webfeedencoder shutdown.
  • Exceptions thrown on configtool/encoder start up are handled rather than causing silent death.
  • Bad channels found during configtool/encoder startup are skipped rather than causing silent death.
  • The EPG plugin no longer shares the same management port as the encoder. This caused the encoder or SageTV to appear down after either had been restarted.
  • The configtool and encoder will correctly reconnect to SageTV after it is restarted.
  • The configtool channel test log file names have been improved.
  • The configtool device seed plugin now uses the correct device name in the tuning URL.
  • The configtool now disables the webfeedencoder EPG plugin when remove lineup is selected to allow configuration of video sources with native EPG.
  • The configtool occasional failures in start and stop of webfeedencoder now fixed.
  • The configtool output from starting/stopping services is now recorded in the log file.
  • The configtool EPG grab test 'Run' button now works.
  • The configtool channel addition now defaults timezone to local time rather than GMT.
  • The configtool will now show the correct channel icon after addition of or editing of a channel.
  • The configtool will periodically check for presence of SageTV and the encoder.
  • The configtool now has a menu option to reload the channel database from disk.
  • The configtool on moving channels up and down the lineup will also move the channel selection so a continued move further up or down the lineup is possible with reselection.
  • The configtool will no longer allow deletion of a channel without it first being removed from the lineup.
  • The configtool will now terminate any channel test when the channel test dialog is dismissed.
  • The configtool now disallows edits rather than crashing if in remote mode and webfeedencoder not running.
  • The configtool can now start up webfeedencoder via SageTV in remote mode.
  • The configtool now indicates in the title bar if it is remote mode.
  • The configtool will now create a logs directory if one is not present and will not require presence of DLLs when working in remote mode.
  • The configtool the seed selection dialog now allows the external web site to be searched for feeds.
  • The configtool issue where EPG harvest test cached and incorrectly used downloaded content for both first day and weekly EPG harvests has been fixed.
  • The configtool issue where sending the lineup twice had the effect of removing knowledge of any existing EPG plugin has been fixed.
  • The configtool seed selection dialog branch children are now alphabetically sorted.
  • The configtool channel test now shows the video in a VLC window.
  • The configtool TV channel test now shows the VLC test log in “Stream to mpeg” rather than “Save as mp3” tab.
  • The encoder now tidies any channel test files on exit.
  • EPG grab will now push times to SageTV in GMT rather than local time.
  • EPG grab now assigns correct day to a days EPG within generic grabber.
  • Tune command files have been updated to be compliant with VLC 1.0.0 onward transcoding parameters - radio still does not work with these versions.
  • Windows detune commands now contain file paths in quotes to deal with files with spaces.
  • The installer now tidies up EPG plugin log files on deinstall.
  • The installer will no longer try to delete files that are not there.
  • The installer will disable use of the EPG plugin on video sources where native SageTV EPG is users by the installer when configuring SageTV whereever native SageTV EPG sources are used.
  • The installer now has a "Repair" which refreshes non-config delivered components.
  • The installer now copes with file paths with spaces when setting file permissions.
  • The installer will now catch and display any errors found in initialization.
  • The installer fixed so that windows file separators are not doubled in the encoder.props file.
  • The installer now removes extra backslashes that appear in windows pathnames when configuring webfeedencoder but take account of UNC pathnames.
  • The installer no longer prints out exception messages when operating system tasks complete.
  • The installer will correctly default installation directory and SageTV directory.
  • The installer now contains a better test of whether webfeedencoder is still in use prior to upgrade as uninstall and upgrade would fail.
  • The installer will now restore SageTV configuration for an earlier version in two phases separated by restoration of the previous webfeedencoder directory.
  • The installer now provides manual instructions and information prior to uninstall, restore and repair.
  • The installer now provides helpful next step instructions after install or upgrade.
  • The installer will now choose unique characters to choose buttons in headless mode.
  • The installer will allow key configuration parameters to be reviewed and edited in subsequent runs.
  • The installer no longer requires '\\' to be used as directory separators in paths.
  • The installer in headless mode no longer goes into an infinite loop of 'Does not exist' if the destination directory for the installation does now exist.
  • The installer now recommends the version of VLC to install and provides a URL that can be cut and paste.
  • The installer no longer overwrites encoder details added for other plugins e.g. slimplayer.
Screenshots
The installer
The config tool
Adding a new channel - the essentials page will get you going
Even easier - grab the information you need from external directory sites
Optional extras: harvest the web for programme guides and now playing text
Test tools for all channel configuration
Michael
Old 06-23-2010, 05:11 AM
Arrow Announcement: Web Feed Encoder version 0.9.6
Introduction
The excellent VLC media player software is used to tune to the internet TV or radio station, add video to the radio, or audio to video where its missing, and dump to an MPEG2 file for SageTV.
Headline changes this release
  • Support for latest VLC.
  • Support for IP cameras.
  • Support for MPEG2 IP TV.
  • Support for Audio only devices.
  • New feature to ensure VLC sessions die.
Installation Prerequisites
  • The VLC media player. Use the latest version.
  • Version 6.4 of SageTV or later. Version 6.6 and the latest STV update if you wish to use online services. Also works with version 7.
java -jar webfeedencoder_0_9_6.jar
Support and updates
Credits
Special thanks to everybody who helped with pre-release testing.
Version History
0.9.6 - 7th release.
  • Accommodate the latest VLC release 1.0.5 removing the need to run the old 0.9.8 release.
  • New channel type: TV (silent) and tuning commands to cater for IP cameras.
  • New channel type: Device (audio), tuning commands and seed plugin to cater for audio input devices.
  • New channel type: TV (MPEG) and tuning commands to cater for IP TV channels that require no transcoding to MPEG2.
  • New radio tune/detune commands to allow use of later versions of VLC where input slave does not work.
  • To accommodate the above a tuning URL is expanded at encoder startup so that it is refers to a playlist then the playlist is converted to a list of streams. This is to get around a VLC bug where this is not done automatically.
  • Add feature where detuning automatically kills any spawned (VLC or other) processes that refuse to stop when asked.
  • New grabber type: None.
  • New grabber type: XMLTV file to allow EPG data to be sourced from an XMLTV file.
  • Added “lineupIsExternallyManaged” property which if set true allows the old style use of a separate XMLTV importer tool and disables the updating of SageTV EPG and lineup from the config tool and encoder. An XMLTV file is output instead.
  • The configtool arguments used to run remotely now must be prefixed with -host=, -port= and -sagePort=. A help message is output if incorrect arguments are used.
  • The configtool now accepts a -console argument which forces logging output to be output to the screen as well as to a file.
  • The configtool now correctly saves new user defined day URL suffix formats creating while specifying an EPG harvest and offers it as a choice for new channels.
  • The configtool now longer loads the channels twice.
  • The configtool now no longer blocks user actions while waiting for a timeout in circumstances where SageTV or the encoder are not available.
  • The configtool chanel dialog now has three seperate buttons for testing the channel, EPG and now playing.
  • The configtool now allows all types of EPG grab to be tested rather than just web based ones.
  • The configtool EPG grab test run will now perform programme merging like the actual EPG test run does where programmes that cross day boundaries are joined and stop times are added if they are not present in the source web page.
  • The configtool grabber test dialog now shows start and stop days separately from start and stop times.
  • The configtool channel test can now generate any number of log files visible in tabs as may be required by custom tuning commands
  • The configtool channel dialog now sorts many combo box lists for ease of locating required values.
  • The configtool channel dialog will now correctly set the id to be the same as the callsign for channel types with no seed plugin.
  • The configtool channel dialog now correctly saves the timezone no matter what the grabber type.
  • The configtool channel dialog now defaults the channel timezone to “Local” rather than the actual local timezone to allow portability of radiotime sample channel properties.
  • The configtool channel dialog now correctly defaults Grabber type to the default day long programme.
  • The configtool now allows actions on a channel can now be launched when a channel is selected in any tab.
  • The configtool now allows a single channel to be selected and reloaded from file.
  • The configtool now allows the user to view any seed channel properties and refresh them from the source web site.
  • The configtool now allows the channels tests to be launched from anywhere.
  • The configtool channel dialog now allows editing of the output video and audio stream parameters in an “Advanced” tab.
  • The configtool now displays an “about” box with version information.
  • The configtool now allows channel testing in standalone mode.
  • New channel types property: “type.name” which provides a user friendly name for the channel type.
  • Removed channel properties: nowplaying.command.text, nowplaying.command.position, nowplaying.command.color, nowplaying.command.size, nowplaying.prefix, nowplaying.suffix channel properties.
  • New channel properties: subtitle.text, subtitle.name, subtitle.pos, subtitle.color, subtitle.size channel properties..
  • New channel property: subtitle text allows reference to other channel properties within it.
  • New channel property to specify an XMLTV file to source EPG data has been added.
  • New channel property to specify a supplementary URL that will provide missing audio or video from the primary tuning URL.
  • New channel property to specify the type of supplementary URL.
  • Channel properties are now saved with unicode characters escaped to cater for channels of non-Latin origin.
  • Channel properties are now saved with improved processing of comments.
  • The grabber can now be run standalone to produce an XMLTV file.
  • The grabber will automatically create a “guide” directory will be created to contain EPG guide output as XMLTV if not already present.
  • The grabber now sets the timezone for XMLTV start and stop times as UTC.
  • The grabber now correctly formats of the start and stop times to include the timezone.
  • The grabber now correctly processes timezones of grabbed programmes.
  • The encoder will now longer log worrying “SageTV has possibly died” log messages.
  • The encoder will accept a new tuning command: “Vlc” to be used instead of Exec cmd /c “VLC” “%vlc%”.
  • The encoder will accept a new tuning command: “ExecAndWait” where the requirement is to launch an OS command but wait for it to finish.
  • The encoder will accept a new tuning command: “VlmConf” which allows a VLC VLM conf file to be created from a template substituting channel properties.
  • The encoder will now replace a reference to “%commands%” in a tuning command with the file path of the commands directory.
  • The installer now saves upgraded config files in the same format as the config tool.
  • The installer now processes custom properties added by user in an old installation correctly.
  • The installer now recommends the latest version of VLC be installed.
Screenshots
The installer
http://www.keepandshare.com/userpics...r-15250299.jpg
The config tool
http://www.keepandshare.com/userpics...p-33006650.jpg
http://www.keepandshare.com/userpics...es-5655313.jpg
http://www.keepandshare.com/userpics...s-46267380.jpg
http://www.keepandshare.com/userpics...g-14215712.jpg
http://www.keepandshare.com/userpics...t-10604707.jpg
http://www.keepandshare.com/userpics...o-32905882.jpg
http://www.keepandshare.com/userpics...v-85003429.jpg
http://www.keepandshare.com/userpics...t-76230065.jpg
http://www.keepandshare.com/userpics...t-19878439.jpg
Extra tweaking if you need it
http://www.keepandshare.com/userpics...d-80493011.jpg
http://www.keepandshare.com/userpics...t-13315087.jpg
http://www.keepandshare.com/userpics...st-1647275.jpg
http://www.keepandshare.com/userpics...t-82900443.jpg
Last edited by Opus4; 06-23-2010 at 11:09 AM. Reason: images too wide to post inline; changed to links
Old 12-10-2010, 03:56 PM
Arrow Announcement: Web Feed Encoder version 0.9.7
Introduction
For SageTV V6 a comprehensive install wizard performs the whole installation task and provides options to downgrade to your previous version and uninstall.
For SageTV V7 or later the plugin manager can be used to perform the installation.
  • Support for multiple tuners.
  • Support for Linux.
  • Support for SageTV V7.
  • Addition of a web server to support remote config management from a web page.
  • Allow channel testing from a remote config tool.
  • Send logs to developer.
  • The VLC media player. Use the 1.0.5.
SageTV V6 - installation and upgrade from earlier versions
Download the user guide available here.
java -jar webfeedencoder_0_9_7.jar
SageTV V7 - installation
Use the SageTV plugin manager to install and manage upgrades.
SageTV V7 - upgrade a previous installation to be under control of the plugin manager
If upgrading from a Web Feed Encoder installation under SageTV V6 then:
  • Take a copy of the webfeedencoder directory.
  • FOllow instructions for SageTV V6 above but choose "deinstall" rather than "upgrade"
  • Use the SageTV7 plugin manager to install 0.9.7.
  • Go to plugin config settings and enter the path of you old installation backup to import settings.
More detail in the user guide.
Support and updates
Support is available on this thread for SageTV V6.
Support is available on this thread for SageTV V7.
Credits
0.9.7 - 8th release (Beta)
  • Created a web server within the webfeedencoder process providing a home page.
  • Allow config tool to be launched from the home page accessed from any networked PC via java web start.
  • Allow user guide to be accessed from the home page.
  • The configtool now additionally allows video playback during channel testing in remote mode by opening a URL on the server box rather than trying to open a local file.
  • New channel type: Podcast (Local) This allows creation of a locally served podcast of a web based file. In short a means to get more web content available in online services.
  • SageTV V7 support.
  • Allow installation and update via the SageTV V7 plugin manager.
  • Added a build number to the version number scheme to facilitate more frequent updates.
  • Support for multiple tuners so to allow simultaneous recording of several channels.
  • New configtool file menu option to add one of the delivered sample channels to the channel list.
  • Make sure we remove any additional encoder props added by SageTV on uninstall.
  • On disable tidy away any partially built network encoder entries
  • Add addSeriesInfoPublic method to the EPG plugin.
  • Improve code for finding free encoder numbers on install.
  • Make lineup send more resilient to internet connection issues.
  • Fix slowness in stopping plugin when SageTV service is stopped.
  • Many fixes to allow webfeedencoder operation in linux.
  • Fix stop encoder button which is occasionally enabled when it should not be.
  • Send logs to developer menu item added to help menu of the config tool.
  • Remove BBC Backstage EPG grabber which the BBC no longer supports.
  • Update the BBC sample channels so that the EPG comes from radiotime.
Utility: Web Radio and TV Encoder michaeldjcox SageTV Customizations 857 03-06-2016 09:59 AM
Latest SageMC Pre-Release Announcement Thread MeInMaui Customization Announcements 20 06-07-2010 03:26 AM
SageTV and web radio michaeldjcox SageTV Customizations 3 12-01-2008 11:09 AM
