Go Back   SageTV Community > SageTV Development and Customizations > Customization Announcements
Customization Announcements Announcements from SageTV customization developers.
Old 03-03-2010, 06:22 PM
tmiranda's Avatar
tmiranda tmiranda is offline
STV Import: Restricted Access STV
Version 1.2 available:
  • Now has the ability to assign actions to categories. So now if you think that watching live TV should have "Local" privileges and setting the "Don't Like" status should have "Server" privileges you can set it as you like.
  • Added the "None" category for actions that you do not want to restrict.
  • Now has the ability to rename the 4 privilege levels to anything you like. If you think Server Config, Local Config, Record and Delete are inappropriate names you can call them Supervisor, User, Son and Daughter.
If you are looking for a way to prevent what actions placeshifter, extender or client users can perform, look no further. This STVi allows you to password-restrict option changes, configuration changes, recording schedule modifications and file deletions.
Each of these restrictions are independently controlled. So, for example, you can allow placeshifter users to view recordings and change the options that effect their placeshifter UI while restricting the placeshifter users from creating new recordings or modifying settings that effect all placeshifters/clients/extenders. You can also dis-allow extenders from accidentally changing settings that ought not be touched. (Having kids I know what a few errant remote-control presses can do!)
Download here: http://forums.sagetv.com/forums/down...do=file&id=332
Support here: http://forums.sagetv.com/forums/show...441#post376441
Old 08-21-2010, 07:04 AM
tmiranda's Avatar
Version 1.30
Version 1.30 for Sage7 is now available in the repository.
STV Import: Comskip Playback for Default STV (v1.5.4 30/August/2008 for SageTV 5/6) JREkiwi SageTV Customizations 600 11-23-2011 07:58 AM
STV Import: Restricted Access STV tmiranda SageTV Customizations 32 01-11-2011 06:50 AM
STV Import: Auto Compress for version 6 Default STV (V1.4.5 1/October/2008) JREkiwi SageTV Customizations 325 10-15-2010 03:06 PM
STV Import: Fan Art for Default STV by TiKi (v2.2 Feb 22, 2009) Tiki SageTV Customizations 102 01-05-2010 05:16 PM
STV Import: Condensed UpComingRec & DiskSpaceBar for Default STV wado1971 SageTV Customizations 4 08-18-2009 01:47 AM
