Go Back   SageTV Community > SageTV Development and Customizations > Customization Announcements
Customization Announcements Announcements from SageTV customization developers.
Old 07-26-2010, 04:33 PM
tmiranda's Avatar
tmiranda tmiranda is offline
Plugin: Install Disk Usage
Install Disk Usage v1.00 for SageTV 7. This plugin displays a small bargraph in the header indicating how much space is left on the drive where SageTV is installed.
To configure go to Setup->Detailed Setup->Customize and look for "Install Disk Usage" near the end of the list.
I have Sage installed on a small Hard Drive and several times the drive has unexpectedly filled up with large log files, fanart, and operating system leftovers. This STVi allows you to immediately see how full the install drive is and can optionally display System Messages if the usage exceeds user defined thresholds.
Old 08-07-2010, 06:54 AM
tmiranda's Avatar
v1.01
Version 1.01 is now available. Fixed an attribute initialization error.
Old 11-21-2015, 05:24 AM
tmiranda's Avatar
EOL?
Is anybody using this PlugIn? If not I will EOL it instead of migrating it from Google Code to GitHub.
Plugin: Install Disk Usage tmiranda SageTV v7 Customizations 21 11-22-2015 11:44 AM
High CPU Usage on virgin install of 7.0.11 personalt SageTV Beta Test Software 6 07-03-2010 04:53 AM
Need help avoiding HD-PVR install/usage troubles... t4uecker Hardware Support 2 01-06-2010 09:36 AM
Disk usage bar problem Axeman SageTV Customizations 0 05-17-2007 02:03 PM
Parental usage log plugin? Sam SageTV Customizations 1 10-24-2006 07:51 AM
