Go Back   SageTV Community > SageTV Development and Customizations > Customization Announcements
Customization Announcements Announcements from SageTV customization developers.
Old 10-01-2010, 06:34 PM
tmiranda's Avatar
tmiranda tmiranda is offline
Plugin: PodcastRecorder
PodcastRecorder is a plugin that allows you to manually record podcasts or create Favorite podcasts that can be automatically downloaded. See the wiki for detailed instructions and explanations:
http://code.google.com/p/tmiranda/wiki/PodcastRecorder
To install: Go to the "UI Mod" section of the plugin manager and select "Podcast Recorder UI". After it's installed you can press Record (Ctrl-y) or Favorite (Ctrl-k) on one podcast or a group of podcasts.
Recorded podcasts will appear in the "Videos" menu.
Known issues:
- Will not work with EvilPenguin's PlayOn/Hulu plugin.
- No matter what subdirectory you download to, when in the Folder view of the Video browser all podcasts will appear at the root level.
This is a beta release, do not expect perfection. Do expect me to address bugs as they are reported.
Plugin: PodcastRecorder tmiranda SageTV v7 Customizations 135 01-07-2013 05:14 PM
Plugin: MizookLCD (Alternate SageTV LCDSmartie Plugin) cslatt SageTV Customizations 48 06-11-2012 10:44 AM
Plugin Manager: Configure plugin medwynd SageTV Beta Test Software 0 05-29-2010 08:43 AM
Hulu: Possible to Use XBMC Hulu Plugin to create SageTV Plugin? Brent SageTV Customizations 8 02-24-2009 04:16 PM
