Old 10-07-2010, 08:06 AM
PLUCKYHD PLUCKYHD is offline
New Build v1.20 api / 1.16 stvi REQUIRES MYMOVIES 3.17 R3 OR LATER!!
Heading says it all don't install the new build without making sure your mymovies version is at the recommended or later.
It won't work if not!!!
and visa versa the old version won't work with the new mymovies!!
WHS users
My Movies for Windows Home Server 1.61 Pre Release 1. Since you can't grab 3.17pr3 anymore you will need that to install 3.18pr1
cheers
Old 10-07-2010, 08:15 AM
From the WHS perspective is there any requirement or will 1.60 (1.6.0.3) be sufficient? (As opposed to 1.61 (Pre Release 1))
Old 10-07-2010, 08:23 AM
Good call it is suppose to be My Movies for Windows Home Server 1.61 Pre Release 1. Since you can't grab 3.17pr3 anymore you will need that to install 3.18pr1.
Thanks for pointing that out.
Old 10-07-2010, 09:32 AM
kkelley929 kkelley929 is offline
Plugin now broken...
Well, unfortunately, I didn't see this before doing the upgrade within SageTV.
After reading this, I went back and updated MyMovies to .18 PR1. MyMovies seems to be working fine...
I then removed and reinstalled the plug-in. It defaults to Disabled and when I try to enable it says "a required dependancy is missing or plug in is broken.."
I restarted windows and have tryed the process over again but to no avail...
Any suggestions?
Thanks!!
Old 10-07-2010, 09:34 AM
Remove the UI plugin
Remove the General smm-api plugin
stop the sagetv service
delete the database directory from mymoviesshare\sagetv\
restart the service and reinstall the ui that should do it.
Old 10-07-2010, 09:51 AM
Sorry, getting there but I can't see to find mymoviesshare\sagetv\
Where should I look for this?
Old 10-07-2010, 09:56 AM
wiki
under the Where is the MyMoviesShare Located that is listed here several times? heading
Check out TVExplorer
Old 10-07-2010, 10:08 AM
Thanks RAZRSHARPE!! I was able to find and delete the folder called DataFiles which contained the file "MyMoviesDataBetaV1.06.data". Unfortunately, it still doesn't work.
Wenthrough the process agian and still no dice...
Old 10-07-2010, 10:13 AM
Is the api show as failed? (under general). If so send me a mymovies log.
Old 10-07-2010, 10:38 AM
d2globalinc's Avatar
d2globalinc d2globalinc is offline
THANKS!!!!
And..... HERE GOES NOTHING!
-D2G
Server Hardware: 34TB Total using Custom Intel Q6600, 20tb storage w/ 3ware SATA2 RAID, bluray R/W, 3x hd300 clients, 5xhd200 clients, HDHR Prime 6, 7TB RAID5 w/ Synology DS1010+ NAS, 7TB RAID5 w/ Synology DS1511+ NAS Server Software: Win 7 64bit w/ SageTV 7.1.9
Primary Workstation: Custom AMD Phenom II X6 1055T 6xCore 2.81Ghz, Asus Crosshair IV, 8GB DDR3, 1xCorsair 128GB SSD for OS, 4x WD Velociraptor 300gb HDD, 2xATI Eyefinity 6 Edition GPU's w/ CrossFireX - connected to 6x20" LCD, 1500w PSU
Old 10-07-2010, 11:07 AM
Originally Posted by d2globalinc View Post
THANKS!!!!
-D2G
I hope not nothing....
Old 10-07-2010, 12:53 PM
Since there are three items to upgrade (WHS MM, MM Client, SMM) can you tell us the prefered upgrade order?
My guess is
1. upgrade WHS MM to 1.61 Pre Release 1
2. upgrade MM Client to 3.18pr1
3. upgrade SMM to v1.20api/v1.16stvi
Windows 7 64bit Home Premium
1tb 3 disk Recording Pool
all in a beautiful Antec 1200
HD100/HD300 extenders
Old 10-07-2010, 12:57 PM
That is the order I would do it in yes.
Old 10-07-2010, 02:49 PM
sabre sabre is offline
Hi, I still show failed after these steps. Log file sent. Thanks
Old 10-07-2010, 02:53 PM
You have my log file as well.
Thanks!!
Old 10-07-2010, 03:43 PM
So far the ones I have seen are not running the new Database
Once you install you need to open mymovies at the server on on a client (not smm) to get it to rebuild the database to the new version.
cheers
Old 10-07-2010, 03:46 PM
RetroBox RetroBox is offline
Hey Plucky,
I performed the upgrade and everything seems to be working properly, except the "Collection Number" and "Date Added" sorting filters don't seem to do anything anymore... I performed the upgrade a couple hours ago, should I wait for everything to "update" for this to be fixed or do I really have an issue.
Also, I did upgrade MyMovies Collection Management to 3.17 - there is a 3.18 BETA version available - how can I tell it is R3?
Server: SageTV 7 (latest), Windows 7 (32-bit); Core2 Q8200, Asus P5N-D, ATI Sapphire HD5670 with Bitstreaming; DVD/BD Drive, 4GB Ram, 8TB Storage Internal
Tuners: Clear QAM Dual Tuner; HD-PVR -- Time Warner Cable / Control STB via Firewire; use USB-UIRT with LM Gestion Remote KeyMap
Old 10-07-2010, 03:56 PM
When you open the collection manager the splash screen should show the version .
Collection number and date added where two fields that changed so I am guessing you are not a high enough version...
Old 10-07-2010, 04:01 PM
batwater batwater is offline
Also failed to check the forum prior to updating What directory, is it the ..\sagetv\DataFiles folder??? (which is empty by the way) I'm seeing multiple directories, extender, etc, really don't want to loose my current configuration settings if possible or do I need to nuke the whole thing?
BTW I uninstalled both plugins now they are not showing up in the install plugins menu, will recycle everything and check again once I upgrade MyMovies. Manually backing up the MyMovies database now just in case.
SageTV 7- OTA only, PlayOn, 1x HD300, 2x HD200, MyMovies, taSageTV (Android phone remote for SageTV!)
CQC - w/integrated SageTV, taRIVA (Android phone client for CQC!)
Logitech Media Server - Multizone audio (6 zones)
Old 10-07-2010, 04:17 PM
The properties folder is your settings so keep that and you will be ok. The databse file holds no settings.
Sage API - sagetvmsg.txt - Can API tell if HDPVR Crashed? personalt SageTV Customizations 4 08-25-2010 04:56 PM
Sage 6.5.1 requires .Net 3.5? waltraud SageTV Beta Test Software 4 11-16-2008 09:11 PM
Tuning a STB that requires OK or Enter backset SageTV Software 2 09-02-2004 04:49 PM
