Old 06-26-2011, 06:59 AM
JonL JonL is offline
SageTV on Unraid server
Hi,
I'm currently using my HD300 in media player mode. It's been ok, but I want to try out the SageTV server software to try some plugins, improved UI, etc.
My NAS is an Unraid box, so I wanted to try the server software on this box.
Has anyone tried to install SageTV MC software on an UnRaid box? Is it doable?
Old 06-26-2011, 07:05 AM
graywolf's Avatar
graywolf graywolf is online now
First off. Do you already have a licensed copy of SageTV? (linux version)
If not, you might as well stop now since they are not selling anymore licenses.
Otherwise, good luck. I'm windows based for Sage and wouldn't be much help on the Linux side, although I do have unraid server for storage.
Old 06-26-2011, 08:10 AM
Well, thanks for the heads up on the SageTV license issue. I thought that they were available.
The idea of having 2 servers online (unraid + Windows) is quite unattractive, though.
Don't know if I can run a XP virtual machine off unRaid. Any ideas?
Old 06-26-2011, 08:19 AM
graywolf's Avatar
On the UnRaid forums, there are a couple threads dealing with Virtualizations. You might want to check them out. I haven't done any playing with them.
Old 06-26-2011, 08:22 AM
I'll check those out and report back here if I get something working.
Old 06-26-2011, 09:18 AM
You do know that Windows SageTV licenses are also no longer available, right?
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i3-7100T CPU, 32GB Memory, unRAID 6.8.3, SageTV & OpenDCT Dockers
PiX64's Avatar
PiX64 PiX64 is offline
Also unraid if installed using the prebuilt binaries is extremely stripped down. Do it might now function how you want if using those binaries. It is also built on slackware so u could certainly do a full slackware install, install sage, and the load up the unraid modules...
Old 06-26-2011, 09:39 AM
Huh, didn't know it.
So, what's available right now?
Old 06-26-2011, 09:56 AM
Pretty much nothing, at least brand new. You did see Jeff's announcement, didn't you?
http://forums.sagetv.com/forums/showthread.php?t=56074
Old 06-26-2011, 10:05 AM
Well, I didn't see it, I didn't even know it.
So, I guess I'll try the software out and see what happens next.
Old 10-27-2019, 02:01 PM
cerickso88 cerickso88 is offline
I've been trying to get the latest Unraid Sage Docker running. (Stuckless Sage Server-Java10) Are you saying its not going to work without a license?
Old 10-27-2019, 02:48 PM
This is an extremely old thread. SageTV became open-source software quite a number of years back, so a license is no longer needed. However, you will need a license for unRAID.
New Server - SageTV+unRAID under ESXi 4.1 stanger89 Hardware Support 211 01-07-2012 10:38 PM
My Improved SageTV + Home PC + unRaid Server + Backup Plan. Suggestions Requested… rdellar17 Hardware Support 12 02-22-2011 12:37 PM
No playback of files on UnRAID server ckewinjones SageTV Software 10 02-12-2011 10:44 AM
Media Player from UNraid Server? skibumdc SageTV HD Theater - Media Player 4 09-23-2010 03:15 PM
Unraid Server BBCritical Hardware Support 5 01-16-2007 09:13 PM
