Go Back   SageTV Community > SageTV Products > SageTV Mac Edition
SageTV Mac Edition Discussion related to the SageTV Media Center for Mac edition. Questions, issues, problems, suggestions, etc. relating to the SageTV Mac edition should be posted here.
Old 12-28-2014, 02:30 PM
Ampd Ampd is offline
Question Placeshifter on iMac (Intel)
First off - I am not a Mac user - anyone that is has way more patients then I do !!
I'm trying to get Placeshifter 7.1.9 to work on an iMac OS X 10.8.5 (Intel). I get the client to connect to the server, select the program and then.... blank screen.
From what I can tell the version of mplayer that is in 7.1.9 is for the PPC and not Intel. I have spent a couple days trying to find a version of the mplayer compiled for Intel or the newer version mpalyer exteneded working with Sage with no progress.
Anyone else run into / find a solution for this problem or I'm I just doing something wrong?
Old 12-31-2014, 12:16 PM
will will is offline
I was never able to get video playback to work properly on my Mac.
Also I wasn't able to get through the placeshifter setup on a Mac. I had to copy the correct configuration from a working placeshifter install from Windows on the server and modify the MAC address of the file name. That way you can skip the entire setup process and just go straight into the client.
Hope this helps a little bit.
Will
OS: Windows 7
Old 03-24-2015, 09:30 AM
skyonic skyonic is offline
Use place shifter 6.6.2 i have it running on 3 i5 macs of all types... i'm running mavericks 10.9.5... it is connected to a xp server running sagetv 6 solid for over 10 years
Old 03-24-2015, 09:33 AM
i have included a screen shot in this image
File Type: png Screen Shot 2015-03-24 at 11.31.28 AM.png (650.5 KB, 356 views)
imac, mac client, mplayer, placeshifter
Which iMac video card best for HD playback? keboyle SageTV Mac Edition 0 05-09-2009 06:56 PM
SageTV client as iMac external display Yannai SageTV Mac Edition 3 05-07-2008 10:16 PM
SageTV on external display on current-gen iMac Yannai SageTV Mac Edition 0 07-26-2007 04:13 PM
Intel GMA 950 wrems Hardware Support 3 05-22-2007 06:57 PM
Intel Mac Placeshifter 6.1.8 No Music over Internets moonmastertang SageTV Placeshifter 2 04-11-2007 06:05 PM
