Old 06-08-2016, 04:27 PM
bialio's Avatar
bialio bialio is offline
Phoenix 3.0
Just gonna leave this here...
PHOENIX 3 is here!
Old 06-08-2016, 07:42 PM
bialio's Avatar
PHOENIX 3 is here!
Old 06-08-2016, 07:59 PM
EnterNoEscape's Avatar
Very nice! I may have a hard decision to make between this and when Gemstone 2 comes out.
Old 06-08-2016, 09:43 PM
bialio's Avatar
I think Phoenix and Gemstone are different enough that you will have an easy decision if you get to the point of comparing them side by side.
Gemstone has so much customization that is built right into the UI that it boggles my mind. That was a lot of work. Those guys are full on awesome.
Phoenix is customizable to an extent - but it involves a bit of XML wrangling and other mods done outside the UI. I think most people that ended up using and liking P2 didn't change much at all. Even though these people are paragons of extreme taste and refinement -simple isn't for everyone.
PHOENIX 3 is here!
Old 06-08-2016, 10:01 PM
Gemstone is awesome, there is clearly a lot of work that went into it and I have my install nicely customized. I really like how much can be done within the UI.
I was looking at Phoenix 2.0 for months to replace SageMC and got it really working well for my needs. The only thing that kept it off my TV's was the default fonts were a bit on the small side (my wife did not approve) and the only way I could fix it was to modify the STV which really isn't the way to go if you want to be able to upgrade with minimal effort. If there was a better way, I didn't find it.
Old 06-09-2016, 04:39 AM
I could be wrong... but Phoenix uses a skin.properties file to control colors, fonts, etc... I would think the font sizes would be there as well... but maybe not.
@bialio - looks good.
Old 06-11-2016, 07:02 PM
skiingwiz skiingwiz is offline
This is interesting. I still use and love the original Phoenix. I've been playing with Gemstone, but Phoenix 3 is intriguing...
Old 06-16-2016, 03:45 PM
LJSSageUser LJSSageUser is offline
Originally Posted by bialio View Post
This is monumental! Gemstone may be great, but the number of options is mind-numbing to someone who only uses Sage for TV. I have stubbornly held onto Phoenix 2 and anxiously await 3.
Old 06-16-2016, 07:57 PM
Well, I'll be following this too, there are a few usability niggles with Gemstone that I just don't like* (no offense intended to the great work that it's creators have put in).
I also prefer the simple visual style I'm seeing above too. It reminds me of of the Ace skin for Kodi which I'm quite fond of.
I'll just throw out my issues with Gemstone so they can be food for thought:
  • It modifies the default Sage recordings view and makes it so that single items are in folders.
  • The VFS views/flows don't handle "back" correctly, hitting back in a flow returns to the main SageTV menu, instead of the parent view level
  • VFS views/flows don't remember where you were when you leave and come back.
FWIW, what I really want is something that styled a bit more modern, (like Ace and what you've got above), but doesn't radically change the stock Sage operation of main features (recordings, guide, etc), and adds handling of imported TV and movies with fanart.
That's basically what I have now, but it's split across Sage (recorded TV) and Kodi/Ace, which I use just for my ripped TV and Movies. I'd love to have something that combines the best of both.
Old 06-16-2016, 08:28 PM
That all sounds like it'd be more suited to just creating a new theme for the default STV (theming is something that the community never really got too serious with, as the few UI saavy developers were focusing on changing the UI's function as well, but the support is there).
Old 06-16-2016, 10:01 PM
panteragstk's Avatar
Wow. Good to have you back sir. Unless you've been back a while and I missed it...either way
Old 06-17-2016, 05:43 AM
Yeah, other than the TV show grouping isn't really there in the stock STV. You can sort of do it with folders, but it's not as nice as when it's based on metadata.
Anyway, I like what I'm seeing in the screenshots above, and look forward to giving Phoenix a try, hopefully it will fit my wants
Old 06-17-2016, 06:31 AM
The one thing I like about Gemstone and Phoenix is that they both use the VFS. So, in moving from Phoenix to Gemstone, or vice versa is an easy task. For me, Media really falls into 4 categories (or views).
1. Unwatched TV
2. All TV
3. Unwatched Movies
4. All Movies
The only other "view" I care about is "Upcomming Recordings" since that just helps be plan my viewing for the week.
Everyone is different, but, at least with the VFS you can tailor your experience to your needs. For things like TV I don't care if it's recorded or ripped, just that it's watched or unwatched. Similar to movies.
Looking forward to taking Phoenix 3 for spin. Is Phoenix 3 still using the menus xml?
Old 06-17-2016, 07:50 AM
bialio's Avatar
Yeah, it'll use all the same framework as the previous Phoenix releases.
PHOENIX 3 is here!
Old 06-17-2016, 09:30 AM
Skirge01's Avatar
Skirge01 Skirge01 is offline
Strange... the image you posted isn't showing up in my browser (Pale Moon). I was reading the thread and realized people were talking about something they'd SEEN, so I opened the thread in IE and saw the screenshot. I thought this was just a text tease all this time.
Software: SageTV 7
Old 06-17-2016, 03:23 PM
OneOfMany OneOfMany is offline
I'll take that as a great way to enlist me as a beta tester again haha
Grant
Old 06-24-2016, 11:28 AM
samgreco samgreco is offline
I'm just switching to P2 to sort of get prepared.
I have been using Gemstone since it became available. And on my full client, it's pretty good. But on an old HD-200, it's sluggish, to say the least. So I setup P2 and it is WAY faster. I am quite pleased. As good as Gemstone is, it is far heavier than I need.
So I am looking forward to P3. Although the only thing I really need in the current P2 setup is a good PlayOn solution.
Old 07-21-2016, 04:38 PM
bialio's Avatar
Couple of more shots.
PHOENIX 3 is here!
Old 07-21-2016, 08:09 PM
mdnttoker mdnttoker is offline
Looks sweet!!
Old 07-21-2016, 09:58 PM
Very nice!
Utility: Phoenix Tools - Phoenix Renamer stuckless SageTV v7 Customizations 116 04-27-2017 10:42 AM
Went from Phoenix to Gemston - Phoenix UI keeps loading uberpixel Gemstone for v7 4 12-28-2012 01:27 AM
Phoenix Error after deleting Phoenix UI wayner Phoenix 9 01-03-2012 11:08 PM
Is this possible in Phoenix? Kirby Phoenix 0 10-22-2011 10:20 AM
Phoenix Source (and how to rebuild Phoenix from sources) stuckless Phoenix 2 09-22-2011 10:26 PM
