Old 05-29-2018, 05:45 AM
gdippel gdippel is offline
SJQ Agent problem
I'm finalizing my transfer of Sage to my Ubuntu server that I'm running as a VM on unRAID. I'm stuck trying to register a SJQ agent on the host system. I can register an agent as a plugin but when I try to run the SJQ agent outside of Sage I get the following:
 sjqagent.sh: line 2: $'\r': command not found
: No such file or directory
sjqagent.sh: line 5: syntax error near unexpected token `$'do\r''
'jqagent.sh: line 5: `for jar in `ls ../lib/*.jar` ; do
The agent installs ok on another Ubuntu box were I'm running Ubuntu Desktop. The reason I want an agent running outside Sage is to use a groovy script to backup the Sage installation which I have used on my windows machine successfully. Any suggestions?
Old 05-29-2018, 07:20 AM
Looks like you may need to strip the carriage return (\r) from the script. Try this in the directory with the sjqagent.sh file:
sudo cp sjqagent.sh sjqagent.sh.save
sudo dos2unix sjqagent.sh
You may also have to install the dos2unix command.
Old 05-29-2018, 09:54 AM
That worked. Thanks.
Plex Scanner and BMT Agent for SageTV PiX64 SageTV v7 Customizations 1406 06-25-2020 12:41 PM
Browser Agent Issue [BMT 4.100.0] Skirge01 SageTV v9 Customizations 3 10-05-2016 10:59 AM
Need help with SJQv4 remote agent coppit SageTV v7 Customizations 4 12-19-2010 11:03 AM
SagetTVService Virus Win32.Agent.dwo Ponchera SageTV Software 6 02-04-2008 06:33 PM
NVIDIA Boot Agent loads after Sage freezes; doesn't see hard drive popechild Hardware Support 8 08-24-2007 07:27 PM
