Old 11-21-2019, 11:01 PM
Android client 1.4.3 lost connection
Not sure what happened but after a security update on my phone running Pie I can't seem to connect to server now! What can I do to fix this?
Old 11-22-2019, 04:49 AM
I would try these things...
- Kill the app (not just close it) (or reboot phone again)
or
- Clear app cache for that app (means you have to set it up again)
or
- Remove the the app, and reinstall
Other things to look/try
-Nor sure if you are running some other vpn software on your phone, but, i'd check anything that might interfere with network.
-I'd verify that the IP of the server hasn't somehow changed
-I'd verify that my phone and the sagetv are still on the same network.
-I'd try to open a browser from the phone to sage web see if you can access that.
the connection to the SageTV service has been lost. The connection will be rest aboli tvmaster2 SageTV Software 2 12-05-2016 09:23 PM
Client Connection to Server Lost [RESOLVED] nwboater SageTV Beta Test Software 10 10-10-2010 04:27 PM
Installed MVP under 4.1.6 - no connection and lost client wrwaugh SageTV Media Extender 13 02-09-2006 05:02 PM
Wireless G, Network Client Connection Lost(Possible Bug?) hybridmedia SageTV Software 6 09-22-2004 08:38 PM
Client Connection lost msg with 2.0.13 ben_gb SageTV Beta Test Software 1 02-25-2004 09:44 AM
