Old 09-09-2020, 01:18 PM
jvl711's Avatar
jvl711 jvl711 is offline
Exclamation WARNING: SageTV Android Client and Android 11
I upgraded my phone last night to Android 11 and the SageTV client no longer has images or fonts loading. I am pretty sure that this is an issue with the upgrade.
I am going to need to look into this. Not sure what is going on. It might take me a little while to figure out. This is an area of the code I am not very familiar with. So, if you do not want it to break, you may want to hold off on upgrading.
Josh
Projects I am currently maintaining
SageTV Andoid Client
Media Format Parser Plugin
JavaFFmpegLibrary
If you like the work I am doing and would like to support it you can become a Patreon member.
Old 09-10-2020, 04:19 AM
Josh
Did you re-install the app after upgrading? The miniclient will cache textures and fonts (which are textures as well) and I've seen where sometimes these can get corrupted. Do you see any images or just blackness?
Old 09-10-2020, 05:29 AM
jvl711's Avatar
At first I was getting some objects that did not have images or fonts. Then after reinstalling I get just a black screen. I was thinking that maybe there is a error loading images.
JavaFFmpegLibrary
Old 09-10-2020, 07:27 AM
jvl711's Avatar
Stuckless I think I stumbled upon the issue by luck. I was wondering if you could give me some insight on this code block, and why you added this change. It seems like it was working perfectly until Android 11. It looks like Adroid 11 does not like Bitmap.Config.HARDWARE. Kinda odd.
public ImageHolder<GdxTexture> readImage(InputStream fis) throws Exception {
        long st = System.currentTimeMillis();
        BitmapFactory.Options options = new BitmapFactory.Options();
        if (Build.VERSION.SDK_INT >= Build.VERSION_CODES.O)
            // this appears to work better since Android O (documentation says it's prefferred
            // for bitmaps that are only used to render to the screen (immutable)
            //options.inPreferredConfig = Bitmap.Config.HARDWARE;
            options.inPreferredConfig = Bitmap.Config.ARGB_8888;
        else
        final Bitmap bitmap = BitmapFactory.decodeStream(fis, null, options);
        long time = System.currentTimeMillis() - st;
        totalTextureTime += time;
        longestTextureTime = Math.max(time, longestTextureTime);
        final GdxTexture t = new GdxTexture(bitmap);
        invokeLater(new Runnable() {
            @Override
            public void run() {
                t.load();
        return new ImageHolder<>(t, t.width, t.height);
JavaFFmpegLibrary
Old 09-10-2020, 08:58 AM
tvmaster2's Avatar
Josh
Thanks for the warning, as I usually upgrade too soon....
Old 09-10-2020, 11:51 AM
sic0048 sic0048 is online now
Edit - well apparently I'm an idiot. I took the Android 11 OTA update, but something must have gone wrong and the phone must have rebooted into the old Android 10 partition. I didn't notice I was still on Android 10 for a couple of days. (I was killing myself trying to root the phone and every time I booted the Android 11 modified boot image, I got a bootloop. Once I realized it was still on Android 10, I manually upgraded to 11 and rooted the phone just fine).
Long story short, this post of mine was made when I was still unknowingly on Android 10.
I've also upgraded to Android 11 and I don't have any font/display issues with either version (1.54 or the older 1.4) of the Mini-client.
Everything (menu, guides, live TV, etc) looks normal and works as expected.
SageTV v9 (64bit)
OpenDCT
Using CQC to control it all
Old 09-10-2020, 12:46 PM
        else
            @Override
            public void run() {
                t.load();
I vaguely remember doing this, and likely it was done an as optimization when I moved to Oreo, but, I guess gess 11 doesn't like it. I assume you commented out the HARDWARE is is using ARGB888 and it works? If so, then I'd just remove the HARDWARE flag entirely and always use ARGB888
Old 09-10-2020, 01:05 PM
jvl711's Avatar
Thanks Stuckless That is exactly what I did. I see why you added that code. It is supposed to be a good performance enhancement. I am going to push a fix to play store.
Josh
JavaFFmpegLibrary
Old 09-10-2020, 01:07 PM
jvl711's Avatar
Interesting. What hardware are you using? I am using Pixel 3xl. It might be specific to that hardware.
JavaFFmpegLibrary
Old 09-11-2020, 10:51 AM
I have a Pixel 3aXL. EDIT - that was apparently still on Android 10 (the Android 11 OTA must have failed and unknowingly rebooted into the old Android 10 partition).
SageTV v9 (64bit)
OpenDCT
Old 09-11-2020, 10:58 AM
jvl711's Avatar
They are really similar, but there is hardware differences in GUP/CPU. I wonder if this is a driver bug on my phone.
Regardless, I fixed the issue and pushed a new release just in case someone else has the issue I had.
Josh
JavaFFmpegLibrary
Old 09-22-2020, 09:46 AM
I just wanted to update my original posts with an idiotic mistake I must have made.
Long story short, my phone was still on Android 10 when I posted that I didn't have any issues with the app. My only guess is that the OTA update failed, or something else caused the phone to reboot into the Android 10 partition. It may have been when I was trying to root it.
SageTV v9 (64bit)
OpenDCT
Old 09-23-2020, 11:02 AM
jvl711's Avatar
Thanks for the followup. Just out of curiosity, did you see the issue? Were you able to get your phone updated.
Josh
JavaFFmpegLibrary
Old 09-28-2020, 09:02 AM
alfi33 alfi33 is offline
I experienced the issue after upgrading to Android 11 on my Pixel 4a. The issue was fixed for me in the newer release.
Server: SageTV v9 on unRAID Docker; i5-2400; 16GB RAM; 9TB storage array; SiliconDust HDHR3
Client: Windows10; Intel Core2Duo; 4GB RAM; NVIDIA GeForce GT 1030
Client: NVIDIA ShieldTV
Client: Fire TV Stick 4K
Old 09-28-2020, 10:50 AM
jvl711's Avatar
Just out of curiosity, when you say fixed in newer release, you are talking about the android mini client, and not a patch to android 11?
Josh
JavaFFmpegLibrary
Old 10-03-2020, 11:43 AM
Josh
Yep, your newer release of the android mini client (that you said includes a fix for this issue on 9/10) did, indeed, fix it for me on my Pixel 4a. Prior to updating to your fixed version of the mini client, I was just getting a black screen.
SageTV Android mini client on an android based TV: Viable? Slack SageTV Software 32 08-26-2019 07:57 PM
SageTV Android Client up and running on Tinkerboard Redhawk56 Hardware Support 1 05-21-2017 05:57 PM
[Android Mini Client] Integrate with Android TV 'Live Channels' dinki SageTV Clients Development 11 01-31-2016 09:43 AM
Finally, a fully functional SageTV client on android and iphone! mkanet SageTV v7 Customizations 12 01-12-2013 12:22 AM
Android client? equalize SageTV Placeshifter 1 07-22-2010 09:37 AM
