Old 09-21-2015, 08:31 AM
SHS's Avatar
SHS SHS is offline
New Hauppauge WinTV-dualHD TV Tuner USB and Soon a Quad Tuner PCIe
I heard there even have a Quad Tuner PCIe board which should be released maybe in October.
Old 09-30-2015, 06:09 PM
SHS's Avatar
SHS SHS is offline
I have it and work nice but not in SageTV still try what heck going on with
Old 10-16-2015, 12:01 PM
SHS's Avatar
SHS SHS is offline
Seem to be more less working now
Just no Dual Tuner
Old 11-12-2015, 10:24 AM
trallyus trallyus is offline
Just no Dual Tuner
Did you ever get that WinTV-dualHD usb tuner to work with both tuners in Sage TV yet or does it only able to use half the tuners in Sage TV?
Had to ask since I ordered one to see if I can use it to replace an old failing card.
Old 11-12-2015, 12:00 PM
SHS's Avatar
SHS SHS is offline
Nope it only see one of the tuner and has other issus as well but then agine SageTV it self need a bit work on windows side of thing any way.
How ever we have wait for the Linux driver which I heard we maybe getting just not sure when to see how that gose so as now there only 3 apps that work out the boxs NextPVR, SichboPVR as well as WinTV 8 I have not tested WMC as I don't have extxa Windows 7 OS for my old Dell 1440 laptop.
If need USB just get HVR-955Q
Old 11-12-2015, 02:39 PM
Thanks for the quick reply as I appreciate it.
Old 02-10-2016, 05:37 PM
Just a quick update SHS that Hauppage updated it's drivers for the WinTV-DualHD tuner at http://www.hauppauge.com/site/suppor...rt_dualhd.html
Date: Feb. 9, 2016
Note: this version fixes:
Error code 52 found on some versions of Windows
Resume from standby problems with some PCs
Clear QAM problem with Windows Media Center
does not fix the tuner only showing up as a single tuner instead of a dual tuner but supposedly fixes the above problems
Old 02-10-2016, 06:12 PM
SHS's Avatar
SHS SHS is offline
Date: Feb. 9, 2016
The problem has to with that way SageTV see the WinTV-DualHD which only look at BDA Receiver Component Hauppauge WinTV-dualHD TS Capture when SageTV should be look at BDA Source Filters then it would see both Hauppauge WinTV-dualHD ATSC Tuner and Hauppauge WinTV-dualHD ATSC Tuner 2.
Old 02-11-2016, 11:52 AM
Yep, I know all too well as I use the tuner too
Old 03-30-2016, 06:50 PM
peacemakerpro's Avatar
peacemakerpro peacemakerpro is offline
Well, crud, I should have read this first. I saw this at frys and scooped it up before thinking it might not be dual in sage, which of course is the only reason I wanted it.
Any luck getting it to recognize second tuner? It lists two new options named differently, but neither actually work.
If no one's having luck, back to frys it is.
"I would have liked to have seen Montana."
Old 03-31-2016, 09:12 AM
SHS's Avatar
SHS SHS is offline
Sorry the dualHD is only one tuner the quadHD PCIe will show you a pair of tuner just not all 4 tuner.
Hopely some some can fix SageTV so they work but more then likly by that time the Linux driver my get update and it should work like it should
Old 06-15-2016, 03:43 AM
Rapidlaser Rapidlaser is offline
WInTV dualHD
I have discovered that when using the winTv dual usb tuner, that it can be used in WinTV at the same time as being used in sage so whilst sage doesn't see both tuners they can be both used with different software at the same time, would be real nice if someone could work out how to get the WinTV EPG into SageTV.
Old 10-02-2016, 11:07 AM
cncb cncb is offline
Darn, I didn't see this before I picked up this tuner. I guess this still isn't sorted out. I wonder if Jeff could fix this easily or would be willing to fix this difficultly ?
-Craig
Hauppauge WinTV-DCR-2650 Dual Tuner Digital CableCARD Receiver ? rwc Hardware Support 1 07-13-2012 03:14 PM
Quad HD antenna tuner? snoopy Hardware Support 5 03-17-2009 08:04 AM
In Stock - Hauppauge WinTV-HVR-2250 Dual TV Tuner scat The SageTV Community 2 10-18-2008 08:55 PM
issues with Hauppauge WinTV-HVR-1600 1178, hdtv tuner just stops working.... maxxcool7421 Hardware Support 3 12-01-2007 08:47 PM
New Hauppauge ATSC USB2 Tuner: WinTV-HVR-950 mikejaner Hardware Support 6 09-27-2006 10:50 AM
