Old 12-29-2007, 03:59 PM
Muchacho Muchacho is offline
Playback of blu-ray backups
We like to hide all the kids DVDs so they cant break them and then watch them through the sageTV extender. I just got a LG bluray/HD-DVD combo drive and would like to play backups of blurays on the HD extender.
When I try to watch the .m2ts file or a .m2ts file remuxed into a mkv wrapper on the HD extender, it will either hang, show a blank screen, or stutter severely. Is there a way to do this, preferably without having to re-encode the whole video?
If this discussion is beyond what is considered appropriate, I apologize and am only trying to watch movies that we own.
Old 12-30-2007, 01:58 AM
jpporter jpporter is offline
I just found a way to at least play blu-ray discs using "Elecard Converter Studio AVC HD Edition".
http://www.elecard.com/products/prod...-studio-avchd/
There is a demo version available.
re-enncoding to mpeg2 to DV 1080i works, I have been playing around with settings to see what gives the best overall output.
Old 12-30-2007, 09:12 AM
Thanks- About how long does it take for a typical movie? It sounds like that method will do a complete re-encode?
Old 12-30-2007, 12:48 PM
bialio's Avatar
bialio bialio is offline
Most BD's that use the AVC codec have a video bitrate that is too high for the HD100.
In theory, any VC-1 encoded (ie HDDVD) mkv will work, as long as you get the audio into a format that is HD100 friendly.
There's a thread about some of this in the General Discussion area :
http://forums.sagetv.com/forums/showthread.php?t=29015
btl.
EDIT : So VC-1 isn't only found on HDDVD - but from what I've seen more often than not BD uses MPEG2 or AVC, and HDDVD uses VC-1.
PHOENIX 3 is here!
Old 12-30-2007, 01:35 PM
Thanks for the info-
So I should have better luck in general with HDDVD? I am currently working on encoding the files a mkv with x264 compression. So far I have not had much luck, but if anything works I will let you know.
Old 12-30-2007, 01:55 PM
After more testing, if the blu-ray movie is in mpeg2 format already, you can just copy the streams and put them in an mpg wrapper (using converter studio). Time is based on your hard drive speed.
If the movie is AVC you will need to re-encode as mpeg2. That takes 2-3 hours with basic settings at 1080i (on intel 6600). Not sure about 1080p
pvr-350 playback issues bq2 Hardware Support 2 04-24-2007 08:30 PM
64 bit processor *required* for Vista hd-dvd & blue ray playback korben_dallas Hardware Support 3 08-25-2006 05:52 AM
Playback Error Capture Error in playback: TheraEdge Hardware Support 2 02-07-2006 04:36 PM
