Go Back   SageTV Community > SageTV Development and Customizations > SageTV v9 Customizations > Gemstone for v9
Gemstone for v9 This forum is for discussing the user-created Gemstone custom interface for SageTV.
Old 06-18-2021, 08:50 AM
Weather fix & data update
The free weather api provided by Yahoo was retired in Febuary & turned off on June 1,2021. That is why everyone is getting the 0 display. As far as I can determine our best option is to fix the darksky integration to use openweathermap.org instead. They offer instructions on their website for this very instance. It would mean getting a free api license similar to what we did with darksky.
https://openweathermap.org/darksky-openweather#match
I am not a coder or I would do the fix myself. I hope someone that can do so will see this.
I am not ready to give up on Sagetv yet!
Old 06-18-2021, 09:31 AM
This also may require different tweaks depending on the UI. I use Gemstone and I think it has separate coding for weather.
Old 06-18-2021, 11:05 AM
I figured it wouldn't be that simple. I am just hoping the respective codes can be reconfigured for replacement api.
Old 06-18-2021, 03:59 PM
garbageman garbageman is offline
Is there a way I can disable the weather feature in Gemstone until there is a solution? Gemstone trying to get darksky information is severely slowing down startup and menu navigation. Once I change to yahoo weather in the widget everything is fine although the weather info is incorrect. The widget keeps reverting back to darksky on a sagetv service restart.
Old 06-30-2021, 10:43 AM
jbuszkie's Avatar
jbuszkie jbuszkie is offline
Any more thoughts on this? Is there a way to disable it or get darksky to work?
It's been so long I forgot how everything works!!!
Old 06-30-2021, 11:33 AM
Changing the weather site to Yahoo gives me 0 as the temperature and thunderstorms but at least it doesn't cause slowness.
You can go into the Widget Manager and turn off the Weather Widget. You can also turn off Weather backgrounds, which I have done, but I still have a weather background. Maybe I need to go into the main Settings menu to turn on another background set.
I think I have turned everything off, but I still see a weather icon and temperature in the top bar of my menu.
Old 06-30-2021, 11:41 AM
After moving around the menu a bit the weather background has gone away but now I have no backgrounds. I will have to figure out how to add some sort of backgrounds into the system. If you go into Theme Settings - Background Manager you can add Custom Backgrounds and assign them to menus. I think that there should be some backgrounds on a SageTV install, if only from the default UI, but I haven't bothered to look for them yet.
Old 06-30-2021, 12:25 PM
jbuszkie's Avatar
Thanks for the info...
I killed the widget. Now, like you, I have it in the top bar. I can probably live with that. It will be accurate a couple times a year in the winter!! :-)
I do like the weather background images.. So I'll keep those... Until they cause me to have delays...
I wish we could get some sort of weather back on gemstone!
I assume most the developers have gone away... We still use sage a lot... but it is a lot less than a couple years ago!
Jim
Old 06-30-2021, 12:29 PM
I sent a PM to jusjoken who wrote Gemstone. I think he is still around - maybe he can get around to making a change to the openweather api. Going by that link posted in post 1 it shouldn't be too hard to make the change.
Old 07-02-2021, 01:47 PM
jusjoken jusjoken is offline
As a number of people are affected I will carve out some time to take a look at what is involved and work to resolve. No promises on how long it might take but at some time will need testers.
As I no longer use Sagetv I will need to setup a development and test environment
Ken
Old 07-02-2021, 06:08 PM
Thanks Ken, that's awesome. We really appreciate it.
Old 07-02-2021, 06:54 PM
KryptoNyte's Avatar
Maybe you could set up a donation page so that you aren't doing this for nothing. Of course 50 or 60 bux a month is probably equivalent to nothing, but ... you know.
I love Gemstone, I'd be in.
Old 07-02-2021, 10:11 PM
I am always open to any small donation to the cause through my PayPal account... Feel free either way.
jusjoken.us@gmail.com
I plan to update the gemstone weather and then possibly see what can be done in the default stv for getting weather back...but I cannot guarantee a quick turnaround, but I did make some progress today in reviewing the api amd getting my server vm running again.
Ken
Old 07-03-2021, 06:19 AM
deanm deanm is offline
Quick question. Is there a weather API for SageTV. Not really looked.
Just I have been playing around with the openweather api and it seams easy to get data out. Just never looked to see how I get that data into STV.
Deanm
Darkside: DVB-C x4 DVB-T2 x2 HD-300 x4
Lightside: DVB-C x2 DVB-T2 x4 HD-300 x3
Old 07-03-2021, 08:53 AM
jbuszkie's Avatar
Ken
Thanks so much for this!!!
Old 07-03-2021, 09:50 PM
I have also started a Patreon page for those that want to follow along a provide any support for my efforts...see my signature below.
I will post some details hopefully tomorrow
Ken
Old 07-05-2021, 07:30 PM
Can I suggest that those of us still using SageTV give Ken (aka jusjoken) "a little something for the effort" on his Patreon page. We can't all grant total consciousness on one's deathbed.
Old 07-05-2021, 07:46 PM
trk2 trk2 is offline
Big hitter, the jusjoken. Long.
Old 07-06-2021, 11:27 AM
Gunga galunga... gunga, gunga-lagunga
Old 07-20-2021, 12:13 PM
mdnttoker mdnttoker is offline
Added on Patron. Thanks Ken.
SageMC weather update? BigSwifty SageMC Custom Interface 14 04-03-2013 10:19 AM
Weather doesn't update. mike015pgh SageTV Software 3 12-06-2012 06:53 AM
The Weather Channel eliminating free weather data feed iolaus SageTV Software 69 08-26-2012 11:17 AM
Downloaded Google Weather Update, No weather? symgryph SageTV v7 Customizations 3 11-18-2011 08:55 AM
24-Hour Weather Update Only Beaker SageTV Software 6 06-16-2008 04:23 PM
