Old 06-25-2021, 11:03 AM
phelme's Avatar
phelme phelme is offline
Windows 11 announcement
Still early of course, but discovered using the Windows PC Health checker that my server won't be able to run Windows 11, as the AMD A10 processors won't be supported (and I doubt the motherboard in there does TPM 2.0 anyway).
Maybe this will get me to upgrade to something of this era.
Old 06-25-2021, 12:42 PM
I did the Check and not of my PC's came back able ... My Intel i7 i5 ... So i would not put much stock in that Health Check.
Old 06-25-2021, 12:46 PM
Telecore's Avatar
Telecore Telecore is offline
I read that the CPU requirement is not a "hard requirement" and most decent CPUs can run Win 11 - check and see if your BIOS has “PSP fTPM” (AMD) or "PTT" for Intel and enable it and re-run - those are effectively a built-in TPM. I can't seem to find a list for Intel but I read that almost all CPUs since Gen 4 have PTT.
SageTV-V9(64bit): Win10/i3-4370/OpenDCT/HDHR-Quatro (OTA)
AndroidTV+Miniclient: Nvidia Shield(x3)/FireTV-4K(x8)
Channels-DVR:Win10/i3-4340/HDHR Quatro 4K/TVE(YTTV)
Old 06-25-2021, 01:04 PM
This came back as unsupported ....
Old 06-25-2021, 01:57 PM
Telecore's Avatar
The official Win 11 CPU list indicates an 8th generation or newer Intel CPU is required - It looks like the software is factoring in the "soft requirement" of the CPU - I'll try my 9th gen when I get home and post - this morning the health checker said my core i5 9600K was not ready either, but I have since learned about turning on PTT in the BIOS, which I am fairly certain is currently off
Update: After turning on PTT, my PC is now Windows 11 ready - conclusion: PC Health App is checking for TPM/PTT and checking the CPU list
Old 06-26-2021, 03:24 AM
I think if history has taught us anything, then Windows 11 will be a dud, Windows 12 will fix everything wrong with Windows 11, and not to fret, because the Linux PC Health Checker says that it'll run on your old hardware just fine.
Old 06-26-2021, 10:19 AM
The announcements didn't talk too much about what is advancing on WSL. Presumably the Android emulator on Win11 will use WSL. WSL is becoming more and more useful and I have been using it a fair bit and it has added a lot more functionality. You can now get at least three Linux distros as well - Ubuntu, Kali and Suse.
It will be interesting to see if the Win11 Android emulator will run the SageTV Android client.
Old 06-26-2021, 10:21 AM
You can find the list of supported CPUs here: https://docs.microsoft.com/en-us/win...tel-processors
Many people will not be able to run Win11 as this is a pretty high bar in terms of having a fairly new PC.
From TheVerge:https://www.theverge.com/2021/6/25/2...e-requirements
Originally, Microsoft noted that CPU generation requirements are a “soft floor” limit for the Windows 11 installer, which should have allowed some older CPUs to be able to install Windows 11 with a warning, but hours after we published this story, the company updated that page to explicitly require the list of chips above. We’ve reached out to Microsoft to clarify its CPU requirements and support, and we’ll update you accordingly.
Old 06-26-2021, 03:40 PM
There are already videos on installing on any hardware.
Old 06-26-2021, 03:53 PM
Tiki's Avatar
Tiki Tiki is offline
That page only lists the intel processors. There is another page for amd:
https://docs.microsoft.com/en-us/win...amd-processors
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 06-28-2021, 07:35 AM
sic0048 sic0048 is offline
I suspect this has more to do with the announced Windows 11 requirement of TPM 2.0 support (Trusted Platform Module) than anything else.
TPMs support is a fairly new thing, so many of the older processors/motherboards aren't going to support it.
It will be interesting to see if Windows backs down from this at all or if it ends up being a mandatory requirement for Windows 11 to work at all.
SageTV v9 (64bit)
OpenDCT
Using CQC to control it all
Old 06-28-2021, 09:57 AM
How will this affect running Windows 11 in VMs, like under unRAID as a host OS. Will you still need TPM or can that be "emulated" by the host OS in a WM?
Old 06-28-2021, 10:57 AM
I think this video Linus (Linus tech tips) installs windows 11 on unraid.
https://www.youtube.com/watch?v=odZSCdNTFPw
Old 07-02-2021, 07:43 AM
I'm much more concerned that Windows 11 might introduce some new "features" we have to work around to keep SageTV running.
ASRock B450M Pro4 AM4 MB, Ryzen 5 2600 3.4ghz, Crucial Ballistix Sport LT 16GB (2 x 8GB) DDR4-3200, EVGA GT 1030SC, WD Black NVMe SSD 250GB, 1x WD120EFAX 12TB, 1x WD80EFAX 8TB, 1x WDBH2D0040HNC 4TB, USB-UIRT, Colossus 2, WinTV-DualHD USB, Windows 10 64bit
Old 07-04-2021, 10:32 AM
RonBoyd's Avatar
RonBoyd RonBoyd is offline
https://www.ghacks.net/2021/06/29/mi...-requirements/
Microsoft's Windows 11 operating system may support more processors than initially announcement by Microsoft through the system requirements. Microsoft released the first Windows 11 Insider build on June 28, 2021 for testing.
Old 07-06-2021, 11:53 AM
Zogg Zogg is offline
Really depends on how you want to set up your system.
For me, I want as few updates and changes as possible on certain systems that will never or rarely interface to the interweb, so I've been installing Win 8.1 and setting it to no updates. I have a Win 8.1 VM that serves as an HDPVR2 network tuner server set up this way, and I don't want it getting mucked up.
Old 07-14-2021, 02:10 PM
valnar valnar is offline
Almost ditto for me, although I do updates.
I have two servers running at home and both are Windows 8.1 64-bit. I don't need or want any of the Win10 garbage on those. One is SageTV, Plex and assorted AV stuff. The other is BlueIris.
Client 2: HD300 on Vizio 40"
Old 08-21-2021, 03:46 AM
I just tried that on my desktop. The site says it's "coming soon".
Old 09-03-2021, 11:17 AM
Install on older hardware.
https://www.theverge.com/22644194/mi...essors-changes
Comskip Monitor: Announcement Steep SageTV Customizations 340 09-26-2020 09:23 AM
Narflex Announcement tvmaster2 SageTV Software 11 07-27-2015 12:06 PM
SageTV Announcement mightyt SageTV Software 34 09-15-2004 04:20 PM
Plextor announcement x[corwyn] General Discussion 4 09-14-2004 08:38 PM
Where is the 2.0.11 announcement? JJarmoc SageTV Beta Test Software 8 01-30-2004 05:32 PM
