Go Back   SageTV Community > SageTV International User Forums > SageTV Australia/New Zealand
SageTV Australia/New Zealand SageTV and SageTV Recorder Users from the Land Down Under - This forum is for you to post about specific issues using SageTV software in Australia and New Zealand.
Old 09-21-2010, 09:59 PM
Vaughan Vaughan is offline
XMLTV importer
Hi can anyone help with this problem?
Ive got a freeview to XMLTV graber but can find a improter that works with sage 6.6
has anyone got a importer that will alow me to import the EPG data into sage
Old 09-22-2010, 01:29 AM
bunch92 bunch92 is offline
Hi,
I recommend using StephaneM software that does exactly what you are looking for : XMLTV Importer
Cheers
Server : Asus M4A79XTD Evo / AMD Phenom II X4 955 @ 3.2GHz / 4Gb RAM / Win 10 64-bit / Cinergy 2400iDT (French Freeview - TNT) / 2 * Hauppauge NOVA-HD-S2 (UK Sky) / TT CT-3650 CI / HDD : 4.5 To / Sage V7 / XMLTV Importer / EPG from WebGrabPlus+/ LM DVB Recorder for all tuners / 2 Clients : STP-HD300
Old 09-22-2010, 06:22 AM
DylanHall DylanHall is offline
I went through this exercise a while back, details in the following thread.
http://forums.sagetv.com/forums/showthread.php?t=44688
Couple things to note, I'm using the Linux version of Sage so my choices are considerably more limited (most of the XML TV plugins are Windows only).
The solution is pretty primitive but have been working nicely now for around a year now
Note, the source of the guide data has changed a little since then. I'm getting my data from http://nzepg.org/freeview.xml.gz
Dylan
Problem with Stephane's XMLTV importer and Sage 6.2.2 brewston SageTV EPG Service 9 09-22-2009 08:55 AM
er... how do i run the xmltv importer sfag SageTV United Kingdom 4 01-20-2009 07:14 AM
XMLTV importer not closing down after import harryf SageTV EPG Service 1 08-17-2008 07:12 PM
LM Gestion XMLTV Importer + lost program guide crollorc SageTV Beta Test Software 7 12-06-2006 09:55 AM
StephaneM's XMLTV importer Question gerberdude SageTV EPG Service 11 07-31-2006 06:50 PM
