Plugin-Library: jsoup by routerunner fails update
I noticed this is the only plugin that I am showing as needing an update. When I try to update it I get a failed resource download message.
From sage_0.txt
Sun 12/12 20:10:35.895 [ReProcessHook@6e5ea4] Plugin installation is starting for SageTVPlugin[jsoup state=Repository name=jsoup version=1.11.3 type=Library desc=Java HTML parser by Jonathan Hedley (DO NOT INSTALL SEPARATELY). author=routerunner screenshots=null videos=null created=11/10/2012 modified=11/11/2018 resPath=null webpages=null implementation= desktopOnly=false serverOnly=false OS=Win,Linux,Mac dependencies=[PluginDependency[Java minVer=1.7 type=JVM], PluginDependency[SageTV minVer=7.1 type=Core]] packages=[Package[type=JAR url=ftp://stv:stv@www.rossisoft.co.uk/plugins/jsoup/jsoup_1_11_3.zip md5=c954ef49534bd987b4b7b4fb2ac754b0 overwrite=true]]] ver=1.11.3
Sun 12/12 20:10:35.896 [ReProcessHook@6e5ea4] Checking for compatability of the new plugin...
Sun 12/12 20:10:35.897 [ReProcessHook@6e5ea4] Plugin is compatible!
Sun 12/12 20:10:35.899 [ReProcessHook@6e5ea4] Plugin package Package[type=JAR url=ftp://stv:stv@www.rossisoft.co.uk/plugins/jsoup/jsoup_1_11_3.zip md5=c954ef49534bd987b4b7b4fb2ac754b0 overwrite=true]
Sun 12/12 20:10:35.900 [ReProcessHook@6e5ea4] Plugin asset name is ftpstvstv@wwwrossisoftcoukpluginsjsoupjsoup_1_11_3zip
Sun 12/12 20:10:35.900 [ReProcessHook@6e5ea4] Now downloading the plugin package from ftp://stv:stv@www.rossisoft.co.uk/pl...oup_1_11_3.zip to local cache file PluginInstallers\jsoup\1.11.3\ftpstvstv@wwwrossisoftcoukpluginsjsoupjsoup_1_11_3zip
Sun 12/12 20:10:35.901 [ReProcessHook@6e5ea4] Download requested for files server=ftp://stv:stv@www.rossisoft.co.uk/plugins/jsoup/jsoup_1_11_3.zip src=null dest=PluginInstallers\jsoup\1.11.3\ftpstvstv@wwwrossisoftcoukpluginsjsoupjsoup_1_11_3zip
Sun 12/12 20:10:35.922 [FinalRender-0023a50011bf@14588d8] MiniClient did not succeed with menu hint change to:menuName:Plugin List, popupName:Install/Update Plugin, hasTextInput:false, errcode=1
Sun 12/12 20:10:37.830 [ReProcessHook@6e5ea4] ERROR with file download of:java.net.SocketException: Connection reset
Sun 12/12 20:10:37.830 [ReProcessHook@6e5ea4] Resource download failed from ftp://stv:stv@www.rossisoft.co.uk/pl...oup_1_11_3.zip
I also tried to use FTP client FileZilla with address: ftp://stv:stv@www.rossisoft.co.uk/plugins/jsoup
Status: Resolving address of www.rossisoft.co.uk
Status: Connecting to 89.242.2.42:21...
Status: Connection established, waiting for welcome message...
Status: Insecure server, it does not support FTP over TLS.
Status: Server does not support non-ASCII characters.
Status: Connected
Status: Retrieving directory listing of "/plugins/jsoup"...
Command: CWD /plugins/jsoup
Response: 250 Directory changed to /plugins/jsoup
Command: PWD
Response: 257 "/plugins/jsoup" is current directory
Command: TYPE I
Response: 200 Type I OK
Command: PASV
Response: 227 Entering Passive Mode (89,242,2,42,5,20)
Command: LIST
Response: 425 Can't open data connection.
Error: Failed to retrieve directory listing
SageTV running on: Win10 21H2
SageTV 9.2.6.976 (64 bit)
Java 1.8.0 311 (64 bit)
OpenDCT 0.5.32 (64 bit)
Clients: HD300 (x2)
HDHR3-CC Prime 20220203 (Comcast CableCard) - 3 Tuners
HDFX-4K Flex 20220203 (OTA) - 4 Tuners
