Old 12-03-2003, 12:10 AM
ertman's Avatar
ertman ertman is offline
Sage thinks I changed the system clock...
When I try to launch SageTV (1.4.10), I get an error panel that pops up and says:
Your system clock appears to have changed, possibly in an attempt to defeat the security system on this program...
(Report Code CCB-A)
The funny thing is, I have not changed the system clock. A reboot (as the warning suggested) did not fix the problem. Uninstalling and reinstalling did not do anything either.
It was working fine until I uninstalled SnapStream in an attempt to fix the IR200L issues I was having. Now I can't even run the setup!
Anyone have any ideas what I can do to fix this?
thanks...
Old 12-03-2003, 09:12 AM
dkardatzke's Avatar
dkardatzke dkardatzke is offline
SageTV Co-Founder
I'm assuming you are using the trial version. If so, send an e-mail to support@freytechnologies.com for a fix.
Dan Kardatzke, Co-Founder
SageTV, LLC
