Old 04-03-2019, 10:35 PM
Denali Denali is offline
Hauppauge Colossus 2 not detected
I run Sage x64 as service v9.2.1. Tried to run without Service an the Hauppauge Colossus 2 is not seen any more. When I started using Sage the Service would crash so I ran without Service but I would occasionally get a crash in Sage &/or Java. I tolerated this for a while and then found that Service would start without crashing so ran under Service. The UI would still occasionally crash but I could restart Sage and not lose current recordings. So have run under Service ever since. Now trying to run without Service and find the Colossus 2 is no longer detected properly in 64 bit or 32 bit it appears. This looks suspicious, don't know if this is just a logging problem or indicates something real.
Tue 4/2 15:10:05.829 [main@70177ecd] Device found--'Hauppauge Siena Video Capture'
Tue 4/2 15:10:05.829 [main@70177ecd] MergeNameList() Entry: DevName[0] 'P,öc', numDev=0, new DevName1[0] 'Realtek HD Audio Mic input', numDev1=5
Any thoughts why the Colossus 2 only works in Service mode?
HTPC: Gigabyte GA-Z170XP-SLI, I7-6700, 16GB, Windows 10 Pro x64, Hauppauge HVR-1600, WinTV-dualHD, Colossus 2, Samsung 850 EVO 120GB, Seagate 3TB, WD 3TB, 3TB, 5TB, Java v1.8.0_231, SageTVx64 v9.2.1.826, Samsung UN60EH6003F, Dish ViP222K, ViewHD 1x2 HDMI Splitter.
Old 04-04-2019, 12:47 AM
wnjj wnjj is offline
That part you show in red looks normal. Since numDev=0, the array will have uninitialized data in it.
Old 04-04-2019, 05:43 PM
OK, Thanks for looking. Strange that Colossus 2 is only seen in Add New Source when in Service mode.
Old 04-04-2019, 05:52 PM
Maybe there's some kind of user permissions needed?
I looked at your log file and it shows this:
Tue 4/2 15:10:05.958 [main@70177ecd] Encoder failed the check:Hauppauge Siena Video Capture
What the check does is call into the native code which in turn looks for registered capture device filters. That's in the realm of device drivers at that point.
Old 04-05-2019, 06:06 PM
Thanks for the heads up. Remember reading of problems after Win 10 update that required Camera permissions for some tuners to work properly. Win 10 update .1803 added select able Camera permissions for user privacy. I turned ON Camera permissions in Settings : Privacy : Camera : Allow Apps to access your camera. Now the Colossus 2 is shown in Add New Source. Now I can run without Service Mode on and have full use of the USB-UIRT and remote for both transmit & receive until a solution for Service mode is found. I wonder if the problem with the USB-UIRT in Service mode with Win 10 is not also some permission setting since it has been confirmed to work in Win 7.
Hauppauge Colossus HD-PVR SHS Hardware Support 2011 04-11-2022 09:39 AM
controlling more than one Hauppauge Colossus (or any Hauppauge product) tvmaster2 Hardware Support 6 12-03-2012 08:06 PM
Hauppauge Colossus richardhood36 Hardware Support 5 12-12-2011 12:06 PM
HD-PVR USB or Hauppauge Colossus HD-PVR DRB Hardware Support 16 11-17-2011 06:00 AM
Hauppauge 250 not detected by Sage 2.1 Choy Hardware Support 6 12-05-2004 08:15 AM
