Capture Error in playback
For the past few weeks, I have been sporadically getting "Capture Error in playback" messages displayed on my HD300s, client and miniclients. Sometimes I'll go for several days without getting one, other times I get several within 15-30 minutes. The frustrating thing is, there are no details provided in the message (see attached screenprint). It started around the same time that I had a cable outage that affected both cable TV and internet. However, around the same time I downgraded from the java 11 docker container to java 8, so that may have something to do with it. Or it could be something else entirely. Any suggestions on where to look? I did some searching on this forum, most of the posts talk about not having enough disk space, but I have 12TB free space so I don't think that's the problem.
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, Unraid 6.11.5, sagetvopen-sagetv-server-opendct-java11 Docker (version 2.0.7) Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners, SiliconDust HDHomeRun CONNECT 4K OTA Tuner Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K Max w/MiniClient Miscellaneous: Multiple Sony RM-VLZ620 Universal Remote Controls |
A couple of additional pieces of information that I realized I left out of the original post. When the error message is displayed, it is displayed on all active (meaning powered up) extenders/clients/miniclients, which also makes it hard to narrow down the root cause of the problem. And after it is displayed, any content being watched on any of the extenders/clients/miniclients continue to play; the error message is more of an annoyance than a disruption. The error messages also stack up, you might have to press OK multiple times to dismiss several messages that have stacked up.
Hopefully some of this additional information may trigger thoughts on next steps.
Strange there are no details. What is your tuner/capture device? Or it looks to be a hard drive and/or permissions issue.
A few posts that may help: https://forums.sagetv.com/forums/showthread.php?t=29747 https://forums.sagetv.com/forums/showthread.php?t=52845 https://forums.sagetv.com/forums/showthread.php?t=63909 Just to clarify, the error shows on PC clients, too? |
Yes, the error message is displayed on my PC client, as well as my HD300s and Fire TV Stick 4K running the miniclient.
Any chance there could be a permissions issue or problem otherwise with the 12TB hard drive? Could you temporarily move your recording directory to another drive on your server for testing?
Edit: It appears that I can run some SMART self-tests on the m.2 drives from within Unraid. I will plan on doing that once Sage is not being used for a period of time. Edit #2: I ran SMART self-tests on both drives, both passed and nothing jumped out at me in the SMART report(s). I think I will try switching back to the java11 docker to see if that makes any difference.
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, Unraid 6.11.5, sagetvopen-sagetv-server-opendct-java11 Docker (version 2.0.7) Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners, SiliconDust HDHomeRun CONNECT 4K OTA Tuner Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K Max w/MiniClient Miscellaneous: Multiple Sony RM-VLZ620 Universal Remote Controls Last edited by KeithAbbott; 11-14-2022 at 06:32 AM. |
Error Capture in playback | javierperalta | Hardware Support | 2 | 12-31-2014 07:44 AM |
There was a capture error in playback | brandypuff | Hardware Support | 0 | 12-14-2014 12:58 PM |
Capture Error in playback | jvl711 | SageTV Beta Test Software | 3 | 10-06-2006 12:35 PM |
Capture Error In Playback | bryent | SageTV Software | 3 | 11-06-2005 08:27 PM |
Capture error in playback | hjalmar | Hardware Support | 2 | 04-28-2005 09:09 PM |
