Old 12-29-2022, 10:25 AM
Foggy Foggy is offline
local client hangs, HD300's work fine
Odd issue started this morning after windows hung/rebooted. The sageTV local client was minimized. (I was watching youtube when the system hung)
My local sageTV client is on the same computer as the sageTV server.
The local sageTV client splash image appears and hangs with the message "SageTV Service is initializing...".
The local sageTV client start up process appears to be in an endless loop.
The HD300's work as expected.
I do have a Wiz.bin.corrupt2 file, dated today.
Any thoughts or suggestions?
- restore the wiz.bin file from the bak? from the wiz.bin.sagetv v9.2.1.826 dated a month ago or restore from my wiz.bin backup in sept?
The sagetv_0.txt file shows the following messages, repeating constantly.
SageTV received connection from:Socket[addr=/127.0.0.1,port=8120,localport=42024]
Thu 12/29 10:59:33.479 [SageTVServer@1551126] Suspending DB writes while we send the DB to the client...
Thu 12/29 10:59:33.479 [SageTVServer@1551126] Sending DB to client of size:56311779
Thu 12/29 10:59:35.169 [SageTVServer@1551126] Logging 0 DB xcts to file and sending them to the new client...
Thu 12/29 10:59:35.170 [SageTVServer@1551126] DONE sending DB to the client and client is now added as a DB sync listener
Thu 12/29 10:59:35.441 [SageTVServer@1551126] Error w/SageTV client connection:java.io.EOFException
Thu 12/29 10:59:35.441 [SageTVServer@1551126] java.io.EOFException
Thu 12/29 10:59:35.441 [SageTVServer@1551126] at sage.SageTVConnection$MyDataInput.readByte(SageTVConnection.java:3708)
Thu 12/29 10:59:35.442 [SageTVServer@1551126] at sage.SageTVConnection.readLineBytes(SageTVConnection.java:2584)
Thu 12/29 10:59:35.442 [SageTVServer@1551126] at sage.SageTVConnection.initializeListenerData(SageTVConnection.java:569)
Thu 12/29 10:59:35.442 [SageTVServer@1551126] at sage.NetworkClient.acceptFromClient(NetworkClient.java:217)
Thu 12/29 10:59:35.442 [SageTVServer@1551126] at sage.SageTV$4.run(SageTV.java:718)
Thu 12/29 10:59:35.442 [SageTVServer@1551126] Cleaning up c/s connection
The sagetvclient_0.txt file contains the following messages, also repeating.
I see the "error in db file ... " message in all of the sagetvclient files.
Thu 12/29 11:08:02.729 [main@9e54c2] Cleaning up c/s connection
Thu 12/29 11:08:02.731 [main@9e54c2] Error establishing server connection to 127.0.0.1 of:tv.sage.SageRuntimeException: kind=1; Wizard no longer supports Widgets
Thu 12/29 11:08:02.732 [main@9e54c2] NetworkClient fullCleanup null
Thu 12/29 11:08:05.243 [main@9e54c2] SageTV received connection from:Socket[addr=/127.0.0.1,port=42024,localport=8295]
Thu 12/29 11:08:05.245 [main@9e54c2] Setting c/s connection state to: CONNECTION_ESTABLISHING
Thu 12/29 11:08:05.251 [main@9e54c2] Wizard allocating table for Year of size 116
Thu 12/29 11:08:05.252 [main@9e54c2] Wizard loading main index for Year bytes=1630
Thu 12/29 11:08:05.252 [main@9e54c2] Load time for Year 0 msec 0.0 msec/object
Thu 12/29 11:08:05.253 [main@9e54c2] Index check time for Year 0 msec
Thu 12/29 11:08:05.253 [main@9e54c2] Wizard allocating table for Network of size 968
Thu 12/29 11:08:05.254 [main@9e54c2] Wizard loading main index for Network bytes=15620
Thu 12/29 11:08:05.255 [main@9e54c2] Load time for Network 1 msec 0.0010330578 msec/object
Thu 12/29 11:08:05.255 [main@9e54c2] Index check time for Network 0 msec
Thu 12/29 11:08:05.256 [main@9e54c2] Wizard allocating table for Title of size 25919
Thu 12/29 11:08:05.256 [main@9e54c2] Wizard loading main index for Title bytes=779394
Thu 12/29 11:08:05.279 [main@9e54c2] Load time for Title 23 msec 8.873799E-4 msec/object
Thu 12/29 11:08:05.282 [main@9e54c2] Index check time for Title 2 msec
Thu 12/29 11:08:05.282 [main@9e54c2] Wizard loading alt index 1 for Title bytes=103682
Thu 12/29 11:08:05.287 [main@9e54c2] Load time for alt index 1 for Title 5 msec
Thu 12/29 11:08:05.292 [main@9e54c2] Index check time for alt index 1 for Title 4 msec
Thu 12/29 11:08:05.293 [main@9e54c2] Wizard allocating table for Channel of size 681
Thu 12/29 11:08:05.293 [main@9e54c2] Wizard loading main index for Channel bytes=100385
Thu 12/29 11:08:05.294 [main@9e54c2] Load time for Channel 1 msec 0.0014684288 msec/object
Thu 12/29 11:08:05.295 [main@9e54c2] Index check time for Channel 0 msec
Thu 12/29 11:08:05.295 [main@9e54c2] Wizard allocating table for Bonus of size 1558
Thu 12/29 11:08:05.296 [main@9e54c2] Wizard loading main index for Bonus bytes=31005
Thu 12/29 11:08:05.297 [main@9e54c2] Load time for Bonus 1 msec 6.4184854E-4 msec/object
Thu 12/29 11:08:05.298 [main@9e54c2] Index check time for Bonus 0 msec
Thu 12/29 11:08:05.298 [main@9e54c2] Wizard allocating table for People of size 109979
Thu 12/29 11:08:05.299 [main@9e54c2] Wizard loading main index for People bytes=5915717
Thu 12/29 11:08:05.408 [main@9e54c2] Load time for People 109 msec 9.910983E-4 msec/object
Thu 12/29 11:08:05.418 [main@9e54c2] Index check time for People 9 msec
Thu 12/29 11:08:05.419 [main@9e54c2] Wizard loading alt index 2 for People bytes=439922
Thu 12/29 11:08:05.445 [main@9e54c2] Load time for alt index 2 for People 26 msec
Thu 12/29 11:08:05.470 [main@9e54c2] Index check time for alt index 2 for People 24 msec
Thu 12/29 11:08:05.470 [main@9e54c2] Wizard loading alt index 16 for People bytes=439922
Thu 12/29 11:08:05.494 [main@9e54c2] Load time for alt index 16 for People 24 msec
Thu 12/29 11:08:05.508 [main@9e54c2] Index check time for alt index 16 for People 14 msec
Thu 12/29 11:08:05.509 [main@9e54c2] Wizard allocating table for SubCategory of size 189
Thu 12/29 11:08:05.509 [main@9e54c2] Wizard loading main index for SubCategory bytes=3674
Thu 12/29 11:08:05.509 [main@9e54c2] Load time for SubCategory 0 msec 0.0 msec/object
Thu 12/29 11:08:05.510 [main@9e54c2] Index check time for SubCategory 0 msec
Thu 12/29 11:08:05.510 [main@9e54c2] Wizard allocating table for Rated of size 8
Thu 12/29 11:08:05.510 [main@9e54c2] Wizard loading main index for Rated bytes=105
Thu 12/29 11:08:05.511 [main@9e54c2] Load time for Rated 1 msec 0.125 msec/object
Thu 12/29 11:08:05.511 [main@9e54c2] Index check time for Rated 0 msec
Thu 12/29 11:08:05.511 [main@9e54c2] Wizard allocating table for ParentalRating of size 0
Thu 12/29 11:08:05.512 [main@9e54c2] Wizard allocating table for ExtendedRating of size 11
Thu 12/29 11:08:05.512 [main@9e54c2] Wizard loading main index for ExtendedRating bytes=250
Thu 12/29 11:08:05.512 [main@9e54c2] Load time for ExtendedRating 0 msec 0.0 msec/object
Thu 12/29 11:08:05.513 [main@9e54c2] Index check time for ExtendedRating 0 msec
Thu 12/29 11:08:05.513 [main@9e54c2] Wizard allocating table for Category of size 192
Thu 12/29 11:08:05.513 [main@9e54c2] Wizard loading main index for Category bytes=3891
Thu 12/29 11:08:05.514 [main@9e54c2] Load time for Category 1 msec 0.0052083335 msec/object
Thu 12/29 11:08:05.514 [main@9e54c2] Index check time for Category 0 msec
Thu 12/29 11:08:05.514 [main@9e54c2] Wizard allocating table for PrimeTitle of size 0
Thu 12/29 11:08:05.515 [main@9e54c2] Wizard allocating table for Show of size 46374
Thu 12/29 11:08:05.515 [main@9e54c2] Wizard loading main index for Show bytes=14646103
Thu 12/29 11:08:06.437 [main@9e54c2] Load time for Show 922 msec 0.01988183 msec/object
Thu 12/29 11:08:06.441 [main@9e54c2] Index check time for Show 3 msec
Thu 12/29 11:08:06.442 [main@9e54c2] Wizard loading alt index 3 for Show bytes=185502
Thu 12/29 11:08:06.451 [main@9e54c2] Load time for alt index 3 for Show 9 msec
Thu 12/29 11:08:06.460 [main@9e54c2] Index check time for alt index 3 for Show 9 msec
Thu 12/29 11:08:06.461 [main@9e54c2] Wizard allocating table for Airing of size 105459
Thu 12/29 11:08:06.462 [main@9e54c2] Wizard loading main index for Airing bytes=4112907
Thu 12/29 11:08:06.517 [main@9e54c2] Load time for Airing 54 msec 5.120473E-4 msec/object
Thu 12/29 11:08:06.521 [main@9e54c2] Index check time for Airing 4 msec
Thu 12/29 11:08:06.521 [main@9e54c2] Wizard loading alt index 6 for Airing bytes=421842
Thu 12/29 11:08:06.533 [main@9e54c2] Load time for alt index 6 for Airing 12 msec
Thu 12/29 11:08:06.541 [main@9e54c2] Index check time for alt index 6 for Airing 8 msec
Thu 12/29 11:08:06.541 [main@9e54c2] Wizard loading alt index 5 for Airing bytes=421842
Thu 12/29 11:08:06.551 [main@9e54c2] Load time for alt index 5 for Airing 10 msec
Thu 12/29 11:08:06.560 [main@9e54c2] Index check time for alt index 5 for Airing 8 msec
Thu 12/29 11:08:06.561 [main@9e54c2] Wizard allocating table for ManualRecord of size 36
Thu 12/29 11:08:06.561 [main@9e54c2] Wizard loading main index for ManualRecord bytes=2094
Thu 12/29 11:08:06.562 [main@9e54c2] Load time for ManualRecord 1 msec 0.027777778 msec/object
Thu 12/29 11:08:06.562 [main@9e54c2] Index check time for ManualRecord 0 msec
Thu 12/29 11:08:06.562 [main@9e54c2] Wizard allocating table for MediaFile of size 6602
Thu 12/29 11:08:06.563 [main@9e54c2] Wizard loading main index for MediaFile bytes=2217361
Thu 12/29 11:08:06.611 [main@9e54c2] Load time for MediaFile 48 msec 0.0072705243 msec/object
Thu 12/29 11:08:06.612 [main@9e54c2] Index check time for MediaFile 1 msec
Thu 12/29 11:08:06.613 [main@9e54c2] Wizard loading alt index 10 for MediaFile bytes=26414
Thu 12/29 11:08:06.614 [main@9e54c2] Load time for alt index 10 for MediaFile 1 msec
Thu 12/29 11:08:06.615 [main@9e54c2] Index check time for alt index 10 for MediaFile 0 msec
Thu 12/29 11:08:06.616 [main@9e54c2] Wizard loading alt index 12 for MediaFile bytes=26414
Thu 12/29 11:08:06.617 [main@9e54c2] Load time for alt index 12 for MediaFile 1 msec
Thu 12/29 11:08:06.622 [main@9e54c2] Index check time for alt index 12 for MediaFile 4 msec
Thu 12/29 11:08:06.622 [main@9e54c2] Wizard allocating table for Watched of size 21734
Thu 12/29 11:08:06.623 [main@9e54c2] Wizard loading main index for Watched bytes=1304046
Thu 12/29 11:08:06.639 [main@9e54c2] Load time for Watched 16 msec 7.361737E-4 msec/object
Thu 12/29 11:08:06.641 [main@9e54c2] Index check time for Watched 1 msec
Thu 12/29 11:08:06.642 [main@9e54c2] Wizard loading alt index 7 for Watched bytes=86942
Thu 12/29 11:08:06.645 [main@9e54c2] Load time for alt index 7 for Watched 3 msec
Thu 12/29 11:08:06.647 [main@9e54c2] Index check time for alt index 7 for Watched 2 msec
Thu 12/29 11:08:06.648 [main@9e54c2] Wizard allocating table for Agent of size 69638
Thu 12/29 11:08:06.648 [main@9e54c2] Wizard loading main index for Agent bytes=6826857
Thu 12/29 11:08:06.767 [main@9e54c2] Load time for Agent 119 msec 0.0017088371 msec/object
Thu 12/29 11:08:06.773 [main@9e54c2] Index check time for Agent 5 msec
Thu 12/29 11:08:06.773 [main@9e54c2] Wizard loading alt index 11 for Agent bytes=278558
Thu 12/29 11:08:06.785 [main@9e54c2] Load time for alt index 11 for Agent 12 msec
Thu 12/29 11:08:06.799 [main@9e54c2] Index check time for alt index 11 for Agent 14 msec
Thu 12/29 11:08:06.800 [main@9e54c2] Wizard allocating table for Wasted of size 16357
Thu 12/29 11:08:06.800 [main@9e54c2] Wizard loading main index for Wasted bytes=212647
Thu 12/29 11:08:06.803 [main@9e54c2] Load time for Wasted 3 msec 1.8340771E-4 msec/object
Thu 12/29 11:08:06.804 [main@9e54c2] Index check time for Wasted 0 msec
Thu 12/29 11:08:06.805 [main@9e54c2] Wizard allocating table for Playlist of size 73
Thu 12/29 11:08:06.805 [main@9e54c2] Wizard loading main index for Playlist bytes=15729
Thu 12/29 11:08:06.806 [main@9e54c2] Load time for Playlist 1 msec 0.01369863 msec/object
Thu 12/29 11:08:06.806 [main@9e54c2] Index check time for Playlist 0 msec
Thu 12/29 11:08:06.806 [main@9e54c2] Wizard allocating table for TVEditorial of size 0
Thu 12/29 11:08:06.807 [main@9e54c2] Wizard allocating table for SeriesInfo of size 25858
Thu 12/29 11:08:06.807 [main@9e54c2] Wizard loading main index for SeriesInfo bytes=16711371
Thu 12/29 11:08:06.980 [main@9e54c2] Load time for SeriesInfo 173 msec 0.0066903858 msec/object
Thu 12/29 11:08:06.984 [main@9e54c2] Index check time for SeriesInfo 3 msec
Thu 12/29 11:08:06.984 [main@9e54c2] Wizard loading alt index 13 for SeriesInfo bytes=103438
Thu 12/29 11:08:06.989 [main@9e54c2] Load time for alt index 13 for SeriesInfo 5 msec
Thu 12/29 11:08:06.992 [main@9e54c2] Index check time for alt index 13 for SeriesInfo 3 msec
Thu 12/29 11:08:06.993 [main@9e54c2] Wizard loading alt index 15 for SeriesInfo bytes=103438
Thu 12/29 11:08:06.997 [main@9e54c2] ERROR in DB file index table, invalid index of:-1191112191 size=25858
Thu 12/29 11:08:06.998 [main@9e54c2] ERROR in DB file index table, invalid index of:359869952 size=25858
Thu 12/29 11:08:06.998 [main@9e54c2] ERROR in DB file index table, invalid index of:6902528 size=25858
Thu 12/29 11:08:06.999 [main@9e54c2] ERROR in DB file index table, invalid index of:793197148 size=25858
Thu 12/29 11:08:06.999 [main@9e54c2] ERROR in DB file index table, invalid index of:1414945857 size=25858
Thu 12/29 11:08:06.999 [main@9e54c2] ERROR in DB file index table, invalid index of:1835364969 size=25858
Thu 12/29 11:08:07.000 [main@9e54c2] ERROR in DB file index table, invalid index of:1667330893 size=25858
Thu 12/29 11:08:07.000 [main@9e54c2] ERROR in DB file index table, invalid index of:1869770345 size=25858
Thu 12/29 11:08:07.001 [main@9e54c2] ERROR in DB file index table, invalid index of:1852262501 size=25858
Thu 12/29 11:08:07.001 [main@9e54c2] ERROR in DB file index table, invalid index of:1633972597 size=25858
Thu 12/29 11:08:07.001 [main@9e54c2] ERROR in DB file index table, invalid index of:1634890853 size=25858
Thu 12/29 11:08:07.002 [main@9e54c2] ERROR in DB file index table, invalid index of:1920150833 size=25858
Thu 12/29 11:08:07.002 [main@9e54c2] ERROR in DB file index table, invalid index of:942683443 size=25858
Thu 12/29 11:08:07.003 [main@9e54c2] ERROR in DB file index table, invalid index of:825438765 size=25858
Thu 12/29 11:08:07.003 [main@9e54c2] ERROR in DB file index table, invalid index of:808350835 size=25858
Thu 12/29 11:08:07.003 [main@9e54c2] ERROR in DB file index table, invalid index of:1584068635 size=25858
Thu 12/29 11:08:07.004 [main@9e54c2] ERROR in DB file index table, invalid index of:1584219445 size=25858
Thu 12/29 11:08:07.004 [main@9e54c2] ERROR in DB file index table, invalid index of:345914 size=25858
Thu 12/29 11:08:07.005 [main@9e54c2] ERROR in DB file index table, invalid index of:1549030912 size=25858
Thu 12/29 11:08:07.006 [main@9e54c2] ERROR in DB file index table, invalid index of:326634496 size=25858
Thu 12/29 11:08:07.006 [main@9e54c2] ERROR in DB file index table, invalid index of:54810194 size=25858
Thu 12/29 11:08:07.006 [main@9e54c2] ERROR in DB file index table, invalid index of:1029767168 size=25858
Thu 12/29 11:08:07.007 [main@9e54c2] ERROR in DB file index table, invalid index of:79718 size=25858
Thu 12/29 11:08:07.007 [main@9e54c2] Repairing index due to error on load...
Thu 12/29 11:08:07.008 [main@9e54c2] Load time for alt index 15 for SeriesInfo 15 msec
Thu 12/29 11:08:07.026 [main@9e54c2] Index check time for alt index 15 for SeriesInfo 18 msec
Thu 12/29 11:08:07.027 [main@9e54c2] Cleaning up c/s connection
Windows 10 64bit, sageTV 32
Old 12-31-2022, 09:48 AM
Two days later I tried starting the local client again and it worked.
The computer had not been rebooted since my initial message.
I'm confused as to why it healed itself but happy.
John
Clients work great, but local, not so much oldmike60 SageTV Software 0 11-02-2011 06:42 PM
Placeshifter doesnt work over internet, client is an HD300 tanquef SageTV Placeshifter 6 09-29-2011 09:46 PM
Client can't connect, HD300 fine Q*bert SageTV Software 5 05-22-2011 04:13 AM
The instructions sound fine, but don't work. pjpjpjpj SageTV EPG Service 16 06-18-2009 02:40 PM
Why default UI works fine but SageMC occasionally hangs? t4uecker SageMC Custom Interface 0 03-25-2009 11:36 AM
