Old 02-08-2023, 10:15 AM
mwittl mwittl is offline
Windows 11 & Spinning Circle of Death
Well, I went and did it...updated to Windows 11 last month and am regretting my decision. I now frequently get the spinning circle of death trying to move through menus. It's not all the time and I can't seem to get a handle on when/why it occurs but I definately did not see this under Windows 10. Anyone else experiencing this? Thoughts?
Old 02-09-2023, 10:27 AM
sic0048 sic0048 is offline
All menus, or just when browsing recordings?
I will say that I've had a situation when bad recordings caused the system to freeze (spinning wheel) anytime I went into a listing of recordings that had even a single bad recording in it.
For example, if I had a single corrupted recordings of "FBI" - anytime I browsed the list of FBI shows and that corrupted file was showing on screen in the list of shows, the system would freeze. I could browse other sets of recordings just fine however. The problem really occurs when you have multiple bad recordings across various shows. It seemed random when the system freezes or not, but it was actually very consistent and I finally figured it out and removed the bad recordings. I haven't had a problem with freezing since.
SageTV v9 (64bit)
OpenDCT
Using CQC to control it all
Old 02-09-2023, 12:20 PM
I hear about it from the wife when she goes to either 'Recordings' or 'Videos'. No bad recordings. After a reboot....everything works fine. If it was a bad recording, it would still give the spinning death wheel. Can't figure this one out.
Old 02-09-2023, 03:37 PM
If Possible, can you up the Java Heap size ?
Old 02-09-2023, 08:39 PM
Tiki's Avatar
Tiki Tiki is offline
Do you have your hard drives set to spin down after a period of inactivity in the Windows Power settings? If so, you will get spinning circles when you try to move through the recordings lists.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Spinning Circle of Death timeout on playback scoful SageTV Software 4 05-29-2015 11:19 PM
Another spinning circle of death t4runnr SageTV Software 24 03-07-2014 10:37 AM
Spinning circle of death and thumbnails?? jbuszkie SageTV Software 28 03-07-2012 03:22 PM
Circle of death tcomeau16 SageTV Software 13 01-13-2010 01:48 PM
