Old 12-20-2008, 11:24 PM
BobMax BobMax is offline
Restoring a Remote Control Setup
I am using a USB-UIRT IR receiver/Blaster and need to know how to restore the key setup for my remote control after an Un-install/Re-Install. I can't find a file that is changed when I make changes to the remote setup. I have saved the full sagetv directory so I hope it is just a matter of finding the correct file.
The Un-install/Re-Install is the only fix I have found so far for the transfer from my HDHomeRun stopping after 30 seconds or so and freezing the picture.
Old 12-21-2008, 01:16 PM
Are you talking about the blaster portion to control an STB or just the remote to control the SageTV interface?
The IR codes assigned to each command for the UI are stored in the properties file on the ui/rc_mappings/<command name> lines.
reinstall, remote control, restore setup
Remote control - change IR frequency?? glennsantacruz SageTV Media Extender 1 12-18-2008 09:40 AM
JP1 Universal Remote Control (URC-1067) for Hauppauge MVP krasev Hardware Support 0 12-22-2007 12:02 PM
Using a universal remote control mmac911 Hardware Support 2 12-13-2006 07:21 AM
Remote Control To Use (Harmony setup help?) TheraEdge Hardware Support 66 04-20-2006 06:21 PM
