Old 01-06-2009, 02:46 PM
electrofex electrofex is offline
MVP-Model 1000
I have small 13" a older LCD tv. Thinking of buying a MVP 1000 for it. I can get one cheep but it is the older unit when it first came out with the older remote. Does anybody know if there is much differance from a newer one?
Old 01-06-2009, 02:52 PM
Brent Brent is offline
As far as I know the older model was basically the same as the newer model except for the remote control - just older.
Old 01-06-2009, 03:45 PM
Correct. The newer model also added a spdif to the MVP but for your use it wouldn't matter. You could also pick up a newer remote with more buttons realitively cheap from the hauppague site if you want more buttons/better remote. $9.95 remote
Old 01-06-2009, 05:05 PM
TechJunkie TechJunkie is offline
I use the very first version of the MVP. Purchased it when it first came out. SageTV breathed new life into it. I use SageMC with without any issues.
The Remote that comes with the HD-PVR works on the MVP with the SageTV interface running on it. So if you have a HD-PVR, no need to purchase the larger remote for it.
Old 01-06-2009, 05:06 PM
spdif
spdif?
Old 01-07-2009, 07:55 AM
spdif?
Sony/Philips Digital Interface
It can be either an optical or a cable jack out to connect to a receiver to receive 5.1 digital dolby surround sound.
So you would have this in addition to the analog RCA stereo jacks. The older models just had the analog jacks.
Old 01-07-2009, 08:52 AM
CollinR CollinR is offline
There is a difference in the firmware that makes them harder to get connected. I personally will not use the older ones however they do seem to normally work just fine.
Old 01-07-2009, 10:07 AM
matt91's Avatar
matt91 matt91 is offline
Wasn't there a version that had a coax output as well as composite video/audio?
It may have been branded as something other than a "Hauppauge MVP", but I'd think that under the hood, it was the same.
Matt
Old 01-07-2009, 12:20 PM
Matt
The Coax output was made by Hauppauge for Helix. They work just fine (have one) other than the fact you have to give it a static IP address and set it in the properties (otherwise it constantly looks for the Helix software)
Edit: I should also mention that I still love my MediaMVP's. In fact I am using one right now in my office hooked to a Samsung 20" CRT.
1000, model, mvp
MVP and Powerline Networking: Incompatible? mdnttoker SageTV Media Extender 24 11-07-2007 12:11 AM
Hauppauge MediaMVP 86001 Rev D3A vs. model 1000 COLO_PVR_GUY Hardware Support 1 08-23-2007 01:31 PM
MVP Model / Revision Questions Xiggy SageTV Media Extender 9 05-08-2007 05:03 AM
SageTV software with Hauppage MVP problems continued dbritton SageTV Media Extender 4 11-07-2006 06:59 AM
MVP Never Progresses past "Starting Application" MrApollinax SageTV Media Extender 49 01-03-2006 04:25 PM
