Old 01-16-2009, 11:39 AM
camtabor camtabor is offline
Problems setting up Sage WHS
Hello all,
I am a current Beyond TV user who frustrated with the lack of integration and meaningful feature changes coming from SS.
Anyway, I have been reading about Sage and I am excited about trying it out. So I installed the Windows Home Server version of it on my home server and hooked up my extra WINTV-PVR-USB2.
The problem I had was during the setup process, which I am doing through the sage client on a different computer, when I get to the part where it needs to download the channel lineup. After I pick the lineup to download, it sends the processor to 100% on my home server seemingly forever. I let it run all night, and this morning it was still pegged.
Any help with this would be greatly appreciated.
Old 01-16-2009, 11:58 AM
S_M_E S_M_E is offline
I don't use that tuner but it sounds like either a driver problem or it needs some other requirement like java or something else. Maybe somebody who uses that specific tuner might have other ideas...
Old 01-16-2009, 12:39 PM
Just to be clear, I believe the tuner is working correctly, I am able to watch tv without the channel lineup, but when I go back to setup and try to download it again, the processor pegs at 100% again.
Old 01-16-2009, 12:43 PM
Did you install the other SageTV requirements, like java and dx9?
Old 01-16-2009, 12:53 PM
Did you install the other SageTV requirements, like java and dx9? Are you trying to configure on the WHS desktop or through a client?
I did not install any pre-reqs. However, everything appears to work fine, except the downloading of the channel lineup. I can restart the sageTVService (to stop it from pegging my processor), then watch/record tv just fine, I'm just missing the guide data..
Then when I go back to the setup to download the guide data....bang, pegged again.
I am using the client on another computer to do the setup.
Just to be clear, I think I was using the wrong terminology before, I do have the channel lineup, meaning all the channels show up, but no guide data, and I think that is where Sage is choking.
Old 01-16-2009, 12:58 PM
I edited my previous post after I reread your first one.
Install java and dx9 on the server, reboot and try to configure it again. I'd also try to configure it from the WHS desktop. I assume it's the sagetvservice.exe process that gets pegged?
EDIT:
Also, I just looked at the FAQ:
EPG
My SageTV can't connect to the EPG Server to gather the guide information. What can I do?
Make sure you don't have any Firewall protection applications running. Something like ZoneAlarm or Windows XP built in Internet Connection Firewall. If you do, you can open a port on your Firewall protection program. The port needed is 7760.
Did you open that port?
Old 01-16-2009, 01:03 PM
Yes, sagetvservice.exe is the one that gets pegged. I'll try doing those installs and reply with the results.
Thanks for your help.
Old 01-16-2009, 02:01 PM
I downloaded the latest Java and directx. Then I ran the source setup again, from my home server.
When I get to the part of picking the lineup information and pick my cable provider I get the message "Please wait while channel lineup is downloaded for...[my cable provider]"
The processor on the home server has been pegged ever since, this was around 45 minutes ago.
This is exactly what I was seeing before.
I just saw your message about opening the port, I am behind a router which could be blocking that port, I'll try that out now.
Old 01-16-2009, 02:41 PM
I disabled the firewall completely on the home server, same thing.
I'm noticing that the CPU spikes at the "Select tuning option.." page.
I have attached a screenshot. As soon as it gets here the CPU goes to 100% and stays there for the duration.
Old 01-16-2009, 03:24 PM
I'm not sure but I don't use that tuner and I'm not having the same issues.
What are your WHS specs?
Old 01-16-2009, 03:54 PM
WHS is AMD 4000+ (single core) w/ 2GB ram.
I have another tuner I can try. I'll give it a shot tonight.
Thanks so much for your fast responses.
Old 01-16-2009, 04:03 PM
Another shot in the dark but if you're using the release version of Sage, try the beta or vice-versa...
Old 01-16-2009, 04:17 PM
robogeek robogeek is offline
If it still pegs out the CPU, enable the SageTV debug logging and check the log file for clues about what is hogging the CPU. You can enable debug logging by changing or adding this line:
debug_logging=TRUE
in your sage.properties file and it will generate a sagetv_0.txt log file. I believe the log only grows to about 9 or 10Meg and then it starts a new one, but it will keep the last 4 log files.
--Jason
Server Hardware: GIGABYTE GA-EP45-UD3R, Intel Q9550 CPU 2.83GHz, 11GB RAM, 1xHDHR, 1xHVR1600, 1xHVR2250
29TB Server Storage: 1TB SSD (OS), 1TB (data), 2x6TB+2x10TB (22TB FlexRaid storage pool), 2x2TB (recordings), 1x750GB (VMs).
Server Software: Win10 Pro x64 OS, SageTV 64bit v9.2.0.441, Java 1.8 u241, PlayOn, Comskip (Donator) v0.82.003, WampServer v2.5.
Clients: 3xHD300s, 2xHD100, 2xPlaceshifters
Old 01-17-2009, 12:41 PM
I think the problem was my tuner the whole time, I setup one of my hdhomerun tuners and everything worked perfectly. It seems like a strange problem that I can watch tv just fine until I try to download the guide data. I don't understand how the tuner can create this behavior. Thanks for the help.
home, lineup, server, setup, whs
Problems setting up and using USB-UIRT with toggle codes (Dish VIP211) popechild Hardware Support 2 12-14-2008 02:54 PM
Can I install Sage WHS version over Sage client rdefino SageTV Beta Test Software 1 12-04-2008 02:24 PM
New Setup - WHS - Sage (Converting from Media Center) wsturner SageTV Software 8 06-13-2008 05:30 PM
Java update on WHS version of Sage? Slipshod SageTV Software 4 04-14-2008 01:03 PM
Strange Hesitation problems with Sage Server srothwell SageTV Software 5 05-18-2006 03:35 PM
