Old 07-05-2009, 07:13 AM
dooferlad's Avatar
dooferlad dooferlad is offline
Question Cleaning out old lineups and channels
Hi,
Over the years I have had the same channel called several different things, for example BBC TWO has been known as BBC 2, BBC-Two and BBC 2 East. Is there any way to just erase all the line up information and start again? I know that some custom program rules will get messed up by this and I will have to be careful updating them, but it is just a mess.
Old 07-05-2009, 07:45 AM
StephaneM's Avatar
StephaneM StephaneM is offline
If you are using my XMLTV Importer, this shouldn't be an issue (unless you have done some remapping in SageTV).
During the import the whole lineup is replaced and you don't have any leftovers.
The only thing that matters in the Importer is the channel ID, the channel name can be changed without disrupting any favorites.
Otherwise the sage.properties file contains all lineup reference (though channel name are in Wiz.bin)
Regards,
Stéphane.
Old 07-05-2009, 08:38 AM
dooferlad's Avatar
Ah, well I am using your importer, but with a name that is the same as a lineup form an old XMLTV source. Perhaps that is the problem. I have set up a source with a different name and once I am confident that nothing has gone wrong I will try deleting the old one. May do the trick!
channel, clean, lineup
Spring Cleaning Time lakeman SageTV Customizations 3 04-03-2009 11:45 AM
Analog channels missing from EPG lineups? wirecreative Hardware Support 2 03-13-2009 12:10 AM
How to combine channels on two lineups? mariOwing SageTV EPG Service 3 09-17-2008 03:52 PM
Cleaning up Snow Help ToyMaster458 Hardware Support 4 11-22-2006 10:02 AM
Cleaning up Harddrive ascv General Discussion 2 04-01-2005 07:47 AM
