Old 01-15-2010, 09:32 AM
calibrate calibrate is offline
Client Lockup: java.nio.channels.AsynchronousCloseException
Every time my MVP's lock up I see this error in SageTV_0.txt. Any ideas as to the java exception?
Definition of lockup - "Playback freezes and MVP must be unplugged to reset"
Fri 1/15 10:29:33.422 [FinalRender-000dfe0c3f9c@30e4a7] deinitMini()
Fri 1/15 10:29:33.423 [MiniUIClientReceiver@3052ce] Exception in the MiniUIClientReceiver of: java.nio.channels.AsynchronousCloseException
Fri 1/15 10:29:35.126 [PooledThread@9aca82] Killed RootPanel
Fri 1/15 10:29:35.126 [PooledThread@9aca82] Saving properties file to clients\000dfe0c3f9c.properties
Fri 1/15 10:29:35.148 [PooledThread@9aca82] Disposed Window
*** 1/15 18:30 update
I have it tracked down to exactly 00:05:00 after the sageTV logo first appears on the extender, the lockup occurs. Just shutdown sagetv service and updated Java to build 1.6.0_17-b04.
java, lockups, mvp
HD-PVR lockup related to Java heap size? troll5501 Hardware Support 14 11-04-2009 02:03 PM
SageTV Client - Vista x64 Lockup lweidig SageTV Software 1 02-26-2009 10:34 PM
Client lockup only when server is running service pratt733 SageTV Software 4 04-21-2008 09:58 AM
Sage client lockup with Cayars 17 abbott_m SageTV Customizations 0 01-30-2005 01:54 PM
Beta Client Lockup flyingdog SageTV Beta Test Software 0 10-22-2004 11:18 PM
