Old 03-01-2010, 10:16 PM
KipKasper's Avatar
KipKasper KipKasper is offline
Question Dual Home Server
Has anyone ever tried to dual home there sage server?
I find that I can kill the network connection to my MVP when I move multi-gigs of data to the server from my desktop, and I'm thinking, if I pop in a second NIC for the MVP it should keep up even when I'm moving something to/from the server....
any thoughts?
- Greg
Server:P4 3.2Ghz, Win XP Pro, 2xPVR-500 V7.0.20.243 Java 1.6.0_22
Client:Optiplex sx280 Win7 Pro 32bit
MVP
Old 03-01-2010, 10:17 PM
KipKasper's Avatar
Also, I know I'll need DHCP for the MVP, no worries
MVP
Old 03-01-2010, 11:30 PM
jredwine2857 jredwine2857 is offline
NIC Multi home
Greg, You should easily be able to that, but I'd bet it's not network related. If you're link is Gig E you likely aren't saturating that, but, rather, your disk i/o is likely high.
Run perfmon and watch the avg disk queue. It should be very low. The line graph should be below 20 and avg should be under 4 or 5.
Old 03-02-2010, 09:57 AM
KipKasper's Avatar
Thanks jredwine,
I should have mentioned, I'm still running a 100mbit network. But I will have a look at the performance monitor.
- Greg
MVP
dual home, mvp, network, server
Sage TV for Windows Home Server Software, HPMediaSmart Server, and HD homerun tuners c309 SageTV Software 15 08-17-2008 06:03 AM
How Does SageTV Media Server for Windows Home Server work? PhillTheChill SageTV Software 7 11-16-2007 01:46 PM
Dual server and dual client Setup sticky Hardware Support 7 08-24-2006 08:51 AM
Architecture - Dual Server or Server/Client ? Berg Hardware Support 3 08-17-2006 05:58 PM
