Old 03-21-2010, 10:46 AM
Ericft Ericft is offline
Ceton Infinity-4 new multicard recorder compatible with SageTV????
With the new ceton card announced for preorders shipping may 31 does anyone have any idea if it will be sageTv compatible. so far seems like only media center but would love to use this instead of all my hdPVRs...
Old 03-21-2010, 11:42 AM
davephan's Avatar
davephan davephan is offline
I sent Ceton an e-mail to find out more about their product. I found a Youtube video and some product information with a web search for Centon.
I'm not sure you cable providers like Comcast would be willing to accept the device, which is not owned by them, on their cable system. Comcast would loose $10 a month from every HD cable box that they would not be renting. I would jump at the price of about $400, if it worked, and the $10 per HD box monthly rental price could be avoided.
Dave
Extenders: 1-HD-300, 2-HD-200
Old 03-21-2010, 12:01 PM
Tiki's Avatar
Tiki Tiki is offline
Dave
Comcast has no choice but to allow it. That's the whole point of Cable Card - it was mandated by the FCC. This is no different than using a TiVo with Cable Card. Comcast freely publishes the rates for renting a cable card now.
As for whether Sage will support it, there has been a lot of speculation and many threads on this forum regarding that topic. It appears that there is no way for Sage to support any cable card tuner natively right now due to DRM restrictions. The best chance of support in the immediate future is through the use of a a 3rd party add-on.
There is at least one add-on currently available that is designed to make any tuner installed under Windows Media Center appear as a network encoder to Sage. In theory, Sage would be able to send a command through this plug-in to tell Windows Media Center to use the Ceton device to record a show. WMC would record the file in its standard format which includes DRM and cannot be played by Sage. The plugin would then transcode the video in real-time back to a MPEG-2 stream that Sage could accept and play back. The limitation is that this would only be possible on recordings that had been flagged as "Copy Freely" any recording marked "Copy Once" or "Never Copy" could not be trans-coded and would still not be playable by Sage.
Obviously this hasn't been tested with the Ceton cards yet, since they haven't been released. But, it should work. The big question is, which shows will be marked "Copy freely"? This seems to be largely up to the cable companies and could vary from market to market, plus they could change their policies at any time. You can bet any "premium" content, like HBO movies will not be marked "copy freely".
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 03-21-2010, 05:34 PM
tmiranda's Avatar
tmiranda tmiranda is offline
I called my cable company and spoke to the techs who told me it was no problem. They just had to some to my house to install the CableCard and that would cost me a one time charge of $35.
Too bad the darn thing is so expensive.
Tom
Old 03-23-2010, 01:12 PM
ericscottf's Avatar
ericscottf ericscottf is offline
Be very wary of any product that enforces copy protection flags. Some cablecos will blanket-flag everything (time warner does this AFAIK), while others do it on a per show basis that could change at any time (FIOS does this). All of that could change overnight, rendering your $400 box and $35 install fee worthless.
I got my parents a tivo HD awhile ago, and they're running it with two cablecards. I showed them how to use tivo2go or whatever the pull-it-to-the-pc program is called these days. Back when they were on TWC, every show was DRM-ed when they pulled it off the unit, and once they switched to fios, only the premium channels have DRM.
Sage Server(7): Win7SP1 32bit Quad core 2.6ghz 4gb ram (~3.2ish)
1TB RAID 10 Promise TX4310, 1TB external USB
2x HD PVR (1.05.301 whql working flawlessly) <-Verizon FIOS HD QIP7100 2 cable box controlled by USB-UIRT 2 zones
1x HDHR (dual tuner) <- Verizon wire
3x HD200 wired latest beta fw
Gig-E wired network
Old 04-09-2010, 10:56 PM
sflamm sflamm is offline
Ceton quad cable card?
Is there any chance SageTV can support this?
http://www.cetoncorp.com/products.php
* merged *
Old 04-29-2010, 06:59 AM
hufnagel hufnagel is offline
subscribed. hopefully sage announces something in here. this could be very nice.
Setup #7.6 Hyper-V (again!)
Hardware: Comcast Basic Digital Cable, (1) HDHR3-CC 20170815 firmware, 36GB "system" drive, 2TB laptop drives, a buttload of archive drives, HP DL380G6 2x X5660 processors (4 cores to VM), 4GB ram
Software: Windows 7 Ultimate SP1 x64, SageTV v9.1.2.662, Java v1.8.0_131, STV 2017052101, HD300 extenders
Old 04-30-2010, 12:24 PM
dfitz43 dfitz43 is offline
If you haven't already seen, there is a long thread about a plugin from babvgant which uses cablecard via WMC as a network encoder.
Thread here:
http://forums.sagetv.com/forums/show...ight=cablecard
As pointed out by Tiki, obviously no one has tested this with the Ceton quad card yet, but it should work.
The biggest caveat as mentioned by Tiki, is whether your particular provider has marked content as "copy freely" or not. This will vary by provider, and may make the ceton card either a) an awesome solution to get multiple streams of non-network HD into sage or b) a complete nonstarter. Premium channels (HBO, etc) will almost certainly not be tagged "copy freely", but it will still be great to have an HDPVR or R5000 (which seems to be fading, at this point) alternative.
cheers,
Dave
Old 04-30-2010, 05:33 PM
doncote0's Avatar
doncote0 doncote0 is offline
Lightbulb Important Note On These Cards / Devices
http://forums.sagetv.com/forums/show...&postcount=292
Check before you buy.
Some cable companies use a technology called Switched Digital Video to transmit TV stations. If your cable provider uses Switched Digital Video, you will need to use an SDV adapter. Some cable providers only support two tuners with their SDV adapters. Please contact your cable provider to find out if you live in an SDV area and how many tuners their adapter supports.
You might want to look into this before looking at getting any CableCard device. If SDV exists and the cable company adapters only support two tuners, then it doesn't make sense to get a model with more than two tuners.
Old 07-06-2010, 10:31 PM
chosen_one chosen_one is offline
SageTV and Ceton InfiniTV 4
Will the Ceton InfiniTV 4 (including W7) work with SageTV (server)? Also, will I still be able to utilize my Hauppauge MediaMVP clients? I have no problem moving to an HD compatible device once I get everything up and running. My Comcast analog channels are dropping like flies and I don't want to make any moves until I know what SageTV can provide.
* merged *
GIGABYTE GA-8IPE1000G, P4 2.4c-800fsb HT, 1GB PC3200, (2) WINTV-PVR 250 PCI (latest drivers/codecs), and AIW ATI 9600 128M (latest drivers).
Old 07-07-2010, 08:01 AM
MitchSchaft MitchSchaft is offline
No, cablecard does not work with SageTV.
Old 07-07-2010, 09:18 AM
mr_lore mr_lore is offline
Directly, no. Indirectly? Yes.
http://babgvant.com/files/folders/sa...ntry14737.aspx
However, the whole "so you're saying there's a chance...one in a million talk" scene from Dumb and Dumber comes to mind...
Server: WMC Windows 7 64bit, SSD+2TB, Gigabyte 870G, AMD X6, 4GB DDR, ATi 5570
Capture Devices: HDHomeRun (OTA), 2x HD-PVR w/HTTP Tuning (DirecTV H21's)
NAS: Windows Home Server: Supermicro C2SBX, C2D 2.6Ghz, 4GB DDR, 32.07TB
Old 07-07-2010, 12:59 PM
doncote0's Avatar
Talking Nice Work Babgvant!
It would be more accurate to say that CableCard does not directly work with SageTV, yet.
It probably will though--Sage has already had a few conversations about this (with Silicondust and the FCC for instance).
Old 07-07-2010, 01:08 PM
yeah, I saw that post a while back. I would be nice to hear something official from SageTV regarding cable card support on the upcoming v7. Again, my biggest issue is the client/server ability.
Old 07-07-2010, 02:50 PM
GKusnick's Avatar
GKusnick GKusnick is offline
They've been pretty forthcoming about what's in V7, and so far CableCard hasn't been mentioned. I think it's pretty unlikely that they would add something that significant this late in the Beta cycle.
-- Greg
Old 07-07-2010, 06:33 PM
darcilicious's Avatar
Wowza, this might just work for my Hava tuner that's already integrated with WMC. That. Would. Totally. Make. My. Day.
Old 07-08-2010, 08:50 PM
mikejaner's Avatar
Which Hava are you using? I was using my Hava HD Wireless for about a year, natively with SageTV before the HDPVR came out.
BTW: Is it as hot on Venus as they say it is?
Mike Janer
SageTV HD300 Extender X2
Old 07-08-2010, 08:57 PM
That's what I have but the more recent firmware versions has screwed up channel changing from SageTV. I think. If I'm wrong, let me know Or maybe I'll try it now that I was able to figure out how to add network -- ah, that was the problem, I think, I couldn't quite figure out all the right settings when adding it as tuner...
Hotter
Old 07-08-2010, 09:04 PM
Okay, configured a new tuner to use the Hava and it won't change channels
Monsoon (the company) have supplied a nice virtual tuner that works with WMC which is why I was hoping the SageMCTuner bit would work -- I can get the Hava to work just fine with WMC.
Old 07-08-2010, 09:14 PM
mikejaner's Avatar
Ahh, I use a USBUIRT for tuning, so I never dealt with their stuff.
Mike Janer
cablecard, ceton
Is/will Xbox 360 be compatible with SageTV? LehighBri SageTV Media Extender 2 05-23-2007 05:29 AM
FYI: Talisman firmware on Linksys router not SageTV compatible stevech Hardware Support 3 01-14-2006 11:43 PM
Customizations Compatible w/ SageTV 4 mightyt SageTV Customizations 2 11-21-2005 01:41 AM
SageTV Compatible Output- Archos AV700 DavidStern Hardware Support 1 10-12-2005 05:39 PM
Kworld V-stream compatible with SageTV? mariner99 Hardware Support 10 02-11-2005 10:13 PM
