Old 06-17-2011, 05:45 AM
ThePaladinTech's Avatar
ThePaladinTech ThePaladinTech is offline
SageDCT Ceton and Comskip / placeshifter
For those that have this working I am wondering what kind of files SageDCT/Ceton creates? everything I have outside of the HD-PVR create mpg files. Where the HD-PVR creates ts files. and it seems that the ts files are more problematic with comskip / showanalyzer. and can be sluggish via placeshifter.
So does the SageDCT/Ceton combo create mpgs or what?
Does they work with current donator version of comskip? or Showanalyzer?
and can you effectively watch something remotely (WAN) via placeshifter that was recorded with the SageDCT / Ceton combo?
Thanks for looking
(current) SageServer: SageTV Open Source V9 - Virtual Ubuntu on Win10 HyperV MSI 970A-G46, AMD FX-8370 , SD Prime via OpenDCT, Donater ComSkip
Clients: HD-200, Nexus Player w/ Android miniclient
Storage: "nas" 16 drive Win10 w/ DrivePool running Plex, Emby, & SD PVR
Retired - Hava, MediaMVP, HD-100, HD-PVR, HVR-2250, Ceton InfiniTV4, Original (white) HDHomeRun Died - HD-100, HD-300
Old 06-21-2011, 09:46 AM
Still wondering about this - anyone?
Old 06-21-2011, 11:24 AM
Endymion's Avatar
Endymion Endymion is offline
-Yes. Standard MPEG2 PS files I believe.
-Yep. I'm back a few versions from the latest donator comskip and it works quite accurately. I should upgrade to the latest, just haven't gotten around to it.
-Yep, works great for me. Some don't seem to want to play over placeshifter, but I have the same problem on some shows recorded by my HVR-2250, so I don't think it's specific to the Ceton recordings.
My only issue with Ceton/SageDCT/SageTV so far has been that the latest SageDCT versions (1.3/1.4) don't work right (cause tuners to go missing, etc), so I'm using 1.1 right now I think. Only problem with 1.1 is the massive memory leak, so I have a task setup in Windows to restart the SageDCT service about every 4 hours. Doesn't really cause me any problems as I've scheduled the restarts around my usual recordings.
Old 06-21-2011, 10:58 PM
sflamm sflamm is offline
I believe it produces .ts (transport stream) not .ps (program stream).
Running 1.4 SageDCT no problems whatsoever...
ceton, sagedct
Ceton, SageDCT, and FiOS ***SUCCESS*** King of Bayonne Hardware Support 71 01-13-2012 08:45 AM
sagedct, ceton in one box, Sage on another Deacon Crusher Hardware Support 17 06-17-2011 04:50 PM
SageDCT/Ceton dedicated box requirements sflamm Hardware Support 2 06-13-2011 08:49 AM
SageDCT/Ceton with Win7 WMC sflamm Hardware Support 0 06-12-2011 11:01 PM
sagedct/ceton and sageTV 6 sflamm Hardware Support 2 06-12-2011 03:37 PM
