Old 04-21-2013, 12:36 PM
bigo93bronco's Avatar
bigo93bronco bigo93bronco is offline
HDPVR2 (1512) VS HDPVR2 GE PLUS 1504
OK,
I've been reading posts and testing results about the 1512's audio issues for hours now, but I haven't seen anything about the 1504 GE PLUS used with sagetv. Is there any difference or reason the 1504 might be better, or is it the same thing as the 1512 minus the IR blaster?
I'm about to bite the bullet and grab either the 1512 or the 1504 so that I can pipe a 1080P signal from my security DVR into the EPG, and have enough resolution to see multiple camera angles without a drop in quality. Obviously sound won't be an issue for this application, but I do plan on transitioning to HD STB at some point this year, and I'm looking for a Hauppauge HDPVR that will do the job through sage.
Windows 10 X64 ASUS Z270 TUF2 MOBO
Intel I5 Kaby Lake @3.3 Corsair H65 AIO water cooler
16GB GSkill DRR4 10 SATA hotswap bays in 4U RM case
Redundant power supply, dual UPS's, etc
Samsung EVO 850 SSD X2 OS drives
WD 4TB Purple drive for recordings, various other drives for archives
Tuners are a work in progress
Old 04-26-2013, 10:11 AM
SHS's Avatar
SHS SHS is offline
It one in same device there only few diff in the two software and cabling parts and diff led color
1504 GE PLUS Green LED
1512 Blue LED
Old 05-04-2013, 09:32 AM
I can't seem to get my HDPVR 2 setup in sagetv, it says it can't continue setup without a selected audio input, but doesn't give me any audio inputs to select from. It is working through showbiz though.
How do you use the built in IR blaster through sagetv?
Old 05-04-2013, 07:34 PM
SHS's Avatar
SHS SHS is offline
It help if install the HD-PVR 2 patch first
http://forums.sagetv.com/forums/showthread.php?t=58983
And re start your system
HD PVR Model 2 1512 tvmaster2 Hardware Support 155 09-17-2015 05:59 PM
