Old 07-29-2017, 01:26 PM
edjames edjames is offline
Android TV app crashes when playing DVD dip
My Mi Box SageTV app exits when I try to play a DVD rip.
Server side (not helpful) says:
Sat 7/29 12:17:50.100 [TimeoutHandler@2ee7e114] TIMEOUT occurred - close the socket asynchronously for java.nio.channels.SocketChannel[connected local=/192.168.100.24:31099 remote=/192.168.100.137:37437]
Sat 7/29 12:17:50.101 [VideoFrame-46524f4d5854@29c07c8d] java.nio.channels.AsynchronousCloseException
Sat 7/29 12:17:50.101 [VideoFrame-46524f4d5854@29c07c8d] at java.nio.channels.spi.AbstractInterruptibleChannel.end(AbstractInterruptibleChannel.java:205)
Sat 7/29 12:17:50.101 [VideoFrame-46524f4d5854@29c07c8d] at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:407)
Sat 7/29 12:17:50.101 [VideoFrame-46524f4d5854@29c07c8d] at sage.MiniDVDPlayer.readIntReply(MiniDVDPlayer.java:1427)
Sat 7/29 12:17:50.101 [VideoFrame-46524f4d5854@29c07c8d] at sage.MiniDVDPlayer.getMediaTimeMillis0(MiniDVDPlayer.java:1503)
Sat 7/29 12:17:50.101 [VideoFrame-46524f4d5854@29c07c8d] at sage.MiniDVDPlayer.getCurrNAVTracker(MiniDVDPlayer.java:634)
Sat 7/29 12:17:50.101 [VideoFrame-46524f4d5854@29c07c8d] at sage.MiniDVDPlayer.getDurationMillis(MiniDVDPlayer.java:141)
Sat 7/29 12:17:50.101 [VideoFrame-46524f4d5854@29c07c8d] at sage.VideoFrame.timeSelected(VideoFrame.java:3375)
Sat 7/29 12:17:50.101 [VideoFrame-46524f4d5854@29c07c8d] at sage.VideoFrame.processJob(VideoFrame.java:2447)
Sat 7/29 12:17:50.101 [VideoFrame-46524f4d5854@29c07c8d] at sage.VideoFrame.run(VideoFrame.java:1614)
Sat 7/29 12:17:50.101 [VideoFrame-46524f4d5854@29c07c8d] at sage.Pooler$PooledThread.run(Pooler.java:254)
Sat 7/29 12:17:50.102 [VideoFrame-46524f4d5854@29c07c8d] java.nio.channels.ClosedChannelException
Sat 7/29 12:17:50.102 [VideoFrame-46524f4d5854@29c07c8d] at sun.nio.ch.SocketChannelImpl.ensureWriteOpen(SocketChannelImpl.java:270)
Sat 7/29 12:17:50.102 [VideoFrame-46524f4d5854@29c07c8d] at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:461)
Sat 7/29 12:17:50.102 [VideoFrame-46524f4d5854@29c07c8d] at sage.MiniDVDPlayer.getMediaTimeMillis0(MiniDVDPlayer.java:1502)
Sat 7/29 12:17:50.102 [VideoFrame-46524f4d5854@29c07c8d] at sage.MiniDVDPlayer.getCurrNAVTracker(MiniDVDPlayer.java:634)
Sat 7/29 12:17:50.103 [VideoFrame-46524f4d5854@29c07c8d] at sage.MiniDVDPlayer.getDurationMillis(MiniDVDPlayer.java:141)
Sat 7/29 12:17:50.103 [VideoFrame-46524f4d5854@29c07c8d] at sage.VideoFrame.getDurationMillis(VideoFrame.java:4052)
Sat 7/29 12:17:50.103 [VideoFrame-46524f4d5854@29c07c8d] at sage.VideoFrame.timeSelected(VideoFrame.java:3392)
Sat 7/29 12:17:50.103 [VideoFrame-46524f4d5854@29c07c8d] at sage.VideoFrame.processJob(VideoFrame.java:2447)
Sat 7/29 12:17:50.103 [VideoFrame-46524f4d5854@29c07c8d] at sage.VideoFrame.run(VideoFrame.java:1614)
Sat 7/29 12:17:50.103 [VideoFrame-46524f4d5854@29c07c8d] at sage.Pooler$PooledThread.run(Pooler.java:254)
Sat 7/29 12:17:50.103 [Pusher@164bcba6] java.nio.channels.ClosedChannelException
Sat 7/29 12:17:50.107 [VideoFrame-46524f4d5854@29c07c8d] VideoFrame.timeSelected2(Wed 12/31 16:00:00.000, true) currFile=MediaFile[id=962442 A[962444,962443,"ANIMUSIC",0@0907.20:16,0,D] mask=D host=hunter encodedBy= format=DVD 0:00:00 0 kbps [] /var/media/videos/ANIMUSIC, Seg0[Fri 9/7 20:16:39.999-Fri 9/7 20:16:40.000]] realDur=0
Sat 7/29 12:17:50.107 [Pusher@164bcba6] java.nio.channels.ClosedChannelException
Sat 7/29 12:17:50.107 [Pusher@164bcba6] at sun.nio.ch.SocketChannelImpl.ensureWriteOpen(SocketChannelImpl.java:270)
Sat 7/29 12:17:50.107 [Pusher@164bcba6] at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:461)
Sat 7/29 12:17:50.107 [Pusher@164bcba6] at sage.MiniDVDPlayer.getMediaTimeMillis0(MiniDVDPlayer.java:1502)
Sat 7/29 12:17:50.107 [Pusher@164bcba6] at sage.MiniDVDPlayer.getCurrNAVTracker(MiniDVDPlayer.java:634)
Sat 7/29 12:17:50.107 [Pusher@164bcba6] at sage.MiniDVDPlayer$1.run(MiniDVDPlayer.java:1108)
Sat 7/29 12:17:50.107 [Pusher@164bcba6] at java.lang.Thread.run(Thread.java:748)
Sat 7/29 12:17:50.108 [VideoFrame-46524f4d5854@29c07c8d] Channel Change Time=1501355870108 NOTE: Not valid if this was not a direct channel change!
Sat 7/29 12:17:50.108 [Pusher@164bcba6] Error with MiniPlayer, closing UI: java.nio.channels.ClosedChannelException
Sat 7/29 12:17:50.108 [Pusher@164bcba6] java.nio.channels.ClosedChannelException
Sat 7/29 12:17:50.108 [Pusher@164bcba6] at sun.nio.ch.SocketChannelImpl.ensureWriteOpen(SocketChannelImpl.java:270)
Sat 7/29 12:17:50.108 [Pusher@164bcba6] at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:461)
Sat 7/29 12:17:50.108 [Pusher@164bcba6] at sage.MiniDVDPlayer.pushBuffer0(MiniDVDPlayer.java:1675)
Sat 7/29 12:17:50.108 [Pusher@164bcba6] at sage.MiniDVDPlayer$1.run(MiniDVDPlayer.java:1120)
Sat 7/29 12:17:50.108 [Pusher@164bcba6] at java.lang.Thread.run(Thread.java:748)
Sat 7/29 12:17:50.108 [Pusher@164bcba6] push loop terminating because pushBuffer failed
Sat 7/29 12:17:50.108 [PooledThread@7af0028c] Killing UIMgr UIManager:localhost@@46524f4d5854-439a2e62
Sat 7/29 12:17:50.108 [PooledThread@7af0028c] Killed UI Timers
Sat 7/29 12:17:50.109 [PooledThread@7af0028c] Clearing DVD watched info for MediaFile[id=962442 A[962444,962443,"ANIMUSIC",0@0907.20:16,0,D] mask=D host=hunter encodedBy= format=DVD 0:00:00 0 kbps [] /var/media/videos/ANIMUSIC, Seg0[Fri 9/7 20:16:39.999-Fri 9/7 20:16:40.000]]
How to debug android app?
Old 07-29-2017, 02:55 PM
If you are trying to play a DVD (ie, .iso or TS folder structure), then it's not supported.
You can check this page to compare the Android MiniClient with HD300 and a PC Client to review the features.
https://github.com/OpenSageTV/sagetv-miniclient/wiki
I should play a DVD rip if it's ripped to MKV file (or some other supported file like mp4, etc).
Old 08-01-2017, 08:59 AM
Thanks for the reply. Seems odd. Isn't the sageserver parsing the dvd format and sending an mpg2 stream? Why would that be unsupported? Or is it the audio that's the issue?
Old 08-01-2017, 11:26 AM
EnterNoEscape's Avatar
That's about what happens for Bluray, but for DVD, SageTV also works with the menus and the Android miniclient doesn't have support for that.
android
Watching or Playing any TV crashes Sage V9 Remo SageTV Github Development 2 06-25-2017 11:33 AM
SageTV crashes when playing HD-PVR videos dvd_maniac SageTV Software 0 02-22-2013 05:02 PM
HD300 crashes hard when playing a certain blu ray rip cord SageTV Media Extender 3 12-20-2010 05:23 PM
SageTv 6.5.1 Beta crashes when playing a recording UgaData SageTV Beta Test Software 6 12-26-2008 11:31 AM
Playing MP3 crashes Sage ukmgranger SageTV Software 0 11-22-2004 09:48 AM
