The first beta version of Sage Recording Extender is now available for download.
Sage Recording Extender (SRE) will monitor certain types of recordings (live sports) and extend (or shorten) the recordings based on the real time status of the event being recorded. More details available from the download page. Feedback welcomed. Last edited by Slugger; 03-09-2009 at 12:30 PM. Reason: Update subject |
Sounds extremely useful in certain situations, I rarely record sports, usually watch them if I am interested. One thing I would suggest, only from experience with my dvr's that annoyed the hell out of me, the show right after a sporting event. If the event ran long and you were set to record that show, you record 20 minutes of the event, and 40 minutes of the show, missing the last 20.
I don't know if it's feasible, but try and include something like that that picks up recordings also affected by a long running show and extend those also? my 2¢ Good luck with it. |
When dealing with the live event itself, it's easy to determine when to stop or extend the recording of that event. The source I parse to tell me if the event is over is telling me about the event itself so when it says the game is over I know I can safely stop recording or if it tells me the game isn't over I can extend the recording if needed. But to use the info to determine when the show following the game should start/stop is not the same. In this case, just because I now know the game is over doesn't mean the show is going to start immediately. Is there a post game show on the network? If so, how long does it run? Usually networks (thinking of Fox/CBS with the NFL here) will run the post game show to the top or bottom of the hour, but it's hardly a rule to be followed so without knowing when the show following the live broadcast will start, it's nearly impossible to pad the recordings after the event. One could try something like rounding to the next half hour, but that's a crap shoot at best and will likely result in just as many partial recordings as doing nothing. Then there's the issue of identifying all the shows affected by the live event running over. Take Fox and the NFL, again. If the late game runs to 8:15 then not only is The Simpsons 15 minutes late, but all programs for that night. But this isn't always true. Sometimes if it's just 5 or 6 minutes, Fox will cut a commercial or two so that by 9:30 everything is back on schedule. But then they don't always do that either. So after thinking about this, I decided there's just no reliable way to modify recordings following live events with any certainty. Of course, I'm open to ideas and would have no problems trying to implement this if a reliable way to determine what to pad and how can be determined. In the meantime, at the very least, when I record the afternoon ball game to watch after work I won't be left in the dark when the recording ends after the 8th inning. ![]() |
O, I definitely see your point. On those times I would like to watch something after a game though, I would rather have recorded 2 hours of show and been sure to pick up what I wanted to record rather than miss it or only end with a partial recording.
I think the last time it happened to me was this last superbowl I think? I believe it was 24 that was on after it, so come the next like Monday when I finally had time to sit down and watch it right before the next episode came on, here I am popcorn in hand and a bunch of crap about the superbowl was recorded and really screwed my evening. I fixed the problem though because now I am just downloading the tv shows I would normally record and streaming them through Sage. That wasn't the only time something like that happened and I wished my dvr at the time would have recorded another hour or whatever. I am really like the peanut gallery, I probably won't be able to help you do anything, but by god I will sure try and tell you what I think you should do! So take it for what it's worth. |
How come SRE won't monitor Favorites? Is it a technical barrier to implement it or something that will be added at a later time? Also, what internet sources is it checking for extended periods?
I always pad more than needed to my NBA favorite, this is the safest way to make sure I record OT periods.
Mayamaniac - SageTV 7.1.9 Server. Win7 32bit in VMWare Fusion. HDHR (FiOS Coax). HDHR Prime 3 Tuners (FiOS Cable Card). Gemstone theme. - SageTV HD300 - HDMI 1080p Samsung 75" LED. |
As to the sources used for monitoring games. All current monitors (NHL, NBA, MLB) use ESPN.com as the source. |
Sage Recording Extender (SRE) Beta2 Now Available
Beta2 of SRE is now available for download.
Changes from Beta1 to Beta2
In addition, I also now use server properties to store details about the plugin. I was even able to modify the standard STV to include all these configuration options in the Detailed Settings menu, but my attempts to create an STVi failed horribly. I can provide anyone my modified STV if you want access to the SRE config menu, but unless you're developing/testing the plugin then the defaults should be fine so there probably isn't any need for the conf menu. The server properties relating to SRE are:
If anyone wants to guide a newbie through creating an STVi from a modified default STV then I'd appreciate it. All I did was modify the Detailed Settings menu to include an "SRE" section. My mods work great within the modified STV, but I don't have a clue as to how to export the changes into a loadable STVi. Feedback on SRE welcomed. |
There are some step-by-step instructions for creating an STVI in my Studio Tools documentation, but they do assume a certain level of familiarity with Studio and with how an STVI works. If you want to discuss it in more depth, the Studio forum is the best place for that.
-- Greg |
Just in time for MLB's opening day, SRE Beta 3 is now available. It seems ESPN.com decided to make a change to their scoreboard format effective yesterday so MLB support is broken in the first two betas. You will need Beta 3 to monitor MLB games.
Changes from Beta2 to Beta3
Very cool idea.. thanks!!!
My systems: Server: AMD Phenom Quad-Core 2.3Ghz, 4GB RAM, ECS A780GM-A MB, 2x HD-PVRs (connected to DirecTV HD STBs using ethernet channel changing), 1x AverMedia A180, OS RAID-1 mirror - 2x250GB 7200rpm SATA, Media RAID-1 mirror - 2x1TB 7200rpm SATA, USB-UIRT (remote control) Main Client: Sage STX-HD100 Media extender Second Client: Athlon XP 4000+, 2GB MB PC3200 DDR, Asus A8N5X MB, 512MB PCI-E ATI HD Radeon 3650, 160 GB SATA - hardware mirrored |
SRE v1.0.0 is now available for download. See download page for changelog. All documentation, including system requirements and installation instructions included in javadoc overview as part of the zip file download.
Does this work with SageMC?
thx mike |
This plugin does not rely on any STV. The plugin runs in the background so yes, the plugin works with SageMC (or any STV).
If you're referring to the STVi that was included in v1.0.0 and older versions of SRE, then no, the STVi will only work with the default STV. However, starting with v1.1.0 I've removed the STVi and no longer support it. Instead, I've included a servlet class in the jar file that can be used with nielm's webserver plugin to configure SRE. The servlet is the only supported method of configuring SRE from here on out. See the installation instructions for details on installing the servlet and feel free to ask questions here if you're having any problems with the servlet (or the plugin in general). |
Thanks, Mike |
When you unzip the download it created a directory called sre_javadoc under C:\Program Files\SageTV\SageTV\ - load index.html in your web browser then read the overview section - it contains the install instructions.
I haven't loaded this yet, but come football season this will come in handy for me.
I was thinking that a good enhancement would be a default end padding in case something went wrong with ESPN's site, like an outtage or like their formatting change that you mentioned. In my case I would want something like an hour or so default padding, just to be sure that if the game goes into OT, and ESPN's site is not working, I will still get the entire game. |
How to edit plugin settings when using a HD extender? | blade | SageTV Customizations | 1 | 12-08-2008 10:21 PM |
IMDB Plugin for Extender | tonysathre | SageTV Customizations | 6 | 08-20-2008 09:15 PM |
Online Radio plugin for Extender | koelec | SageTV Customizations | 23 | 02-28-2008 12:27 PM |
Media Extender and Anders' DVB plugin | Mahoney | SageTV Media Extender | 4 | 03-21-2006 01:19 AM |
