Old 11-09-2009, 06:18 PM
koan00 koan00 is offline
ComSkip not working..
I am not sure what I am doing wrong here, but I can't seem to get ComSkip working on my clients.
My setup is 1 main server running latest default STV. I have DirMon2 and ComSkip working fine on my HD-PVR recordings. I loaded ComSkip STVi on the server and it seems to be working.
Now I have 2 clients running SageMC 6.3.9a. They are also running the iTV theme (not sure if that matters). I don't see any ComSkip information for any of my recordings..
Am I missing something obvious?
[SageTVServer] AthlonII X4 920|ATI 3450/Passive 256MB|4GB PC2-1066|Gigabyte MA770-UD3v2|Seagate 320GB/DB35.3 750GB (DVR HD)|Win7/Ult/x86
[SageTVClient1] AthlonX2 5400|ATI 4550/Passive 512MB|4GB PC2-800|Gigabyte MA770-UD3v1|Creative X-Fi|Seagate 320GB|Win7/Ult/x86|42" LCD
[SageTVClient2] AthlonX2 5400|ATI 4550/Passive 512MB|4GB PC2-800|Gigabyte MA770-UD3v1|Realtek HDA|Seagate 320GB|Win7/Ult/x86|32" LCD
SageTV 6.6.2|SageMC 6.3.9b_24 (clients)|
3x HD-PVR (FiOS) - Firewire Tuning|1x HDHomeRun
Old 11-10-2009, 07:17 AM
Make sure the paths are defined as UAC (\\server\share).
Old 11-10-2009, 09:05 AM
Sory for the noob questions but:
Set paths on the server or the clients?
Which path do I set, the regular sage setting for the recordings folder?
Old 11-10-2009, 11:00 AM
Your comskipping your recordings so it would be the recordings path. Just use UNC paths everywhere. Server and clients need to see the recordings on the same path. I don't think mapped drives work but you can try the same drive letter for both of them also.
gerry
Old 11-10-2009, 03:40 PM
Thanks for your replies gplasky
I have one more question if you dont mind. Since I now have to share the folders on the network, can I share them read-only?
I ask because I am curious if when I delete a recording, does it also delete the .edl and text files? If so, it is the server deleting the files or the client? I assume that when a client normally deletes a recording, it's a message from client -> server and then the server deletes it. I wasn't sure if this woudl hold true for the comskip data files.
Old 11-10-2009, 05:16 PM
You can set Dirmon2 to delete the files left over if the cooresponding .mpg or .ts files doesn't exist. If you share as read-only you won't be able to delete them. It's the client and the ID that is logged in that will delete the file.
Old 11-10-2009, 06:47 PM
Thanks again Gerry,
I wasn't sure how to open the directories up read/write for the server, but still read only for the clients since you have to have the same path in bot.
So I did just decide to use a mapped drive. My recordings folders on the server is D:\SageTVShows. So I shared the entire drive read only, and then mapped the d share to d: on my clients (after re-ordering some drives in disk management). Voila, things work
Can't get comskip working 73cuda SageTV Customizations 23 03-18-2008 09:45 PM
comskip monitor not working after updgrade to 6.3 LaoChe SageTV Customizations 2 12-22-2007 10:25 PM
SA/COMSKIP on HD files not working... twieder SageTV Customizations 10 02-21-2007 10:51 PM
Comskip not working BBCritical SageTV Customizations 2 07-25-2006 07:11 AM
Comskip not working on client dbfresh23 SageTV Customizations 7 05-05-2005 08:28 PM
