Go Back   SageTV Community > SageTV Development and Customizations > Customization Announcements
Customization Announcements Announcements from SageTV customization developers.
Old 01-17-2010, 02:02 PM
STV Import: TVExplorer for SageMC new version notification Thread
TVExplorer is an extremely flexible and customizable replacement screen for the My TV screen in SageMC. It duplicates most/all of the functionality on the My TV screens. It is similar to Windows Explorer and/or the Malore Menus.
Get the latest version here.
Release Notes:
1.01.025 01/17/2010
New Features:
  • Rework UI to add more customization options
  • Rework Options screen for better navigation
  • Movies can be grouped into a single item
  • Protect Options screen with password. The default password is "0000" (no quotes). The password is disabled by default.
  • Ability to load/save TVEOptions.properties files. Makes saving different configurations a snap and it can be used to deploy settings across multiple machines
  • Auto generation of playlists for "Play All" functionality
Bug Fixes:
  • Group operations (Set All Watched, Archive All, Delete All, etc) work as expected
  • Preview Window display issues fixed
  • original air date sorting issues fixed
  • sorting by season episode fixed
  • Removed the incorrect property item for the Load Fanart Deley
Check out TVExplorer
Old 02-04-2010, 09:59 PM
TVExplorer 1.01.028. Get it here.
Installation/Upgrade Instructions:
See download page here.
Release Notes:
1.01.028 2/4/2010
-Make Left Selection Panel scrollable to make sure all options are displayed
-Fix bug where Imported TV that was a DVD object would not display (or group correctly)
-add Disc information in episode panel when displaying tv dvd discs (follows same format as Season Episode information)
-use ortus method ( ortus_api_GetFilePathForSegment(mf, 0) ) to return the path to the mediafile
-add segment information (number of segments) to expanded episode info
-add ortus logging options (TVE Options -> Ortus Config)
-Fix menu highlighting to use Scaling Insets
-Expand "Play" and "Group/Select" Navigation options (TVE Options -> Navigation)
-When an Episode Title is unknown (ie no mediatile, episode title, or description) display the filename instead of "Unknown"
-Load and Save TVE Options method name updated to latest ortus method names
-Update ortus.api version (0.5.03.254)
Old 03-03-2010, 09:36 PM
TVExplorer 1.01.038. Get it here.
Suport Thread
Release Notes:
1.01.038 3/3/2010
-Fix "Episode Sorting" menu title so it makes sense
-Store the UIContext after a fork where it sometimes would not get passed properly to the fork
-Add grouping option "Title: Original Air Date". Update Cell Time Display for new grouping option so the time displayed is the original airing date when grouping by that date.
-Left Selection Panel Width is now configurable from the UI (TVEOptions -> Browser -> Left Selection Panel Width)
-Update some ortus api metadatamethod names for consistency
-Fixed bug where when a show was deleted it would remain visible in TVE until TVE was reloaded
-Group Options is now wholly TVE and not linked to SageMC options menus.
-Episode Options is now wholly TVE and not linked to SageMC options menus.
-Group Options available from EpisodeFilterPanel for the currently Selected Filter (ie the currently display Episode List)
-Added Option to NOT display recorded TV (that is not a filter). TVEOptions -> ImportedTV -> Display Recorded TV (Default Enabled)
-Added Option to Disable Deleting mediafiles. TVEOptions -> Main -> Allow MediaFileDeletion (Default Enabled)
-Fixed some bugs with navigation to/from Episode Filter Panel.
-updated ortus api (0.5.03.263)
Other Notes:
-this release does not include the Group quick navigation popup or number shortcut discussed in the support thread
-it also does not fix the bug in the method that cleans titles for sorting when ignoring A, An, and The discussed in the support thread
Old 03-06-2010, 07:45 PM
TVExplorer 1.01.040. Get it here.
Suport Thread
Release Notes:
1.01.040 3/6/2010
-add Alpha option for overlay transparency setting in Group cell (TVE Options -> Browser -> Overlay Alpha)
-Fix bug where the watched count and/or banner for a group would not display (or show null) when entering TVE.
-Fix bug where ignoring indefinite articles during sort was sorting things it shouldnt. For example (A.I... was sorting with I, rather then A). the method will only use " " as a word separator now. previously it also used "." and "_". At the programmers discresstion they can optionally pass additional separators to the method.
-fixed bug where when a mediafile was deleted at the end of playback navigation was corrupted when returned to TVE. If a mediafile is deleted and the group no longer exists TVE will apply default focus. If the group still exists TVE will remove the deleted mediafile from the list and set focus to next episode in the episode list.
-fixed bug where if you deleted the only episode in a group (Focus on Episode -> Options -> Delete) navigation would get corrupted
-updated ortus api (0.5.03.265)
STV Import: TVExplorer for SageMC razrsharpe SageMC Custom Interface 704 01-23-2011 01:36 PM
STV Import: iMovies for Default STV (Notification Thread) Tiki Customization Announcements 1 01-17-2010 04:51 PM
STV Import: BMI Tools for Default STV (Notification Thread) Tiki Customization Announcements 0 01-08-2010 01:17 PM
Plugin:MovieTimes New Version Notification Thread rsagetv99 SageTV Customizations 1 12-03-2009 08:30 PM
SageMC 16x9 New Version Notification Thread dflachbart Customization Announcements 21 08-02-2009 03:19 AM
